Analyse - Analyse de la cause première
Analyse: tableau de bord d'analyse des causes profondes dans TemplateOne pour Process Mining autonome, utilisé pour examiner le comportement indésirable des incidents et identifier les opportunités d'amélioration de l'automatisation.
Qu'est-ce que l'analyse des causes profondes ?​
L'analyse des causes profondes peut être utilisée pour analyser le comportement des cas, en particulier les comportements indésirables, et comment l'améliorer grâce à l'automatisation.
In the Analysis – Root cause analysis dashboard you can compare the occurrence of cases with a certain behavior relatively to a reference set of cases. The set of Reference cases is defined based on the Case start filter. Within this set of cases, you can select the behavior that you want to analyze. For example, cases with a certain tag. This selection is called the Selected cases.
Analyse - Tableau de bord de l'analyse des causes profondes​
The Analysis - Root cause analysis dashboard enables you to compare a set of cases selected by using a specific filter setting with the reference set of cases that is defined by the Case start filter. For the attribute selected in the dashboard a comparison of the absolute and relative frequency of the attribute value within the selected cases and the reference cases is displayed.
Influence​
The Influence is the deviation from the Reference %. The Reference % is calculated as the percentage of Selected cases in the Reference cases. A large deviation from the Reference % indicates a possible high influence on the selection.
Remarque :
Il est possible de sélectionner plusieurs attributs pour l'analyse des causes profondes. Voir également Travailler avec des graphiques.
Réalisation d’une analyse des causes profondes​
To perform a root cause analysis first define what you want to analyze. Then add user filters to define the cases for the analysis.
Display detail information​
Click on the Information icon in the upper-right corner of the Analysis - Root cause analysis dashboard to display detail information on the root cause analysis.
A popup window is displayed containing detailed information on the data actually displayed in the Analysis - Root cause analysis dashboard. See the illustration below.
