Architecture de la plate-forme
Architecture d'UiPath Process Mining autonome, décrivant les composants utilisés pour le chargement, le traitement et la présentation des résultats dans les navigateurs Web.
Introduction​
This guide describes the architecture of the UiPath Process Mining. In general, the UiPath Process Mining is used to load data and present results to end-users in web browsers.
System architecture​
UiPath Process Mining consists of several components for developing process improvement applications.
See the illustration below for an overview of the system architecture of UiPath Process Mining.
Below is a description of the elements of UiPath Process Mining.
Apps/Accélérateurs de découverte​
Process Mining provides ready-to-use apps and discovery accelerators for gaining insights on processes, carrying out root-cause analysis, and for continuous monitoring.
Using AppOne, the Purchase-to-Pay Discovery Accelerator and the Order-to-Cash Discovery Accelerator users can start analyzing processes immediately, without having to create a new app from scratch.
AppOne is a default dashboard template for generic processes. New process mining apps and discovery accelerators in UiPath Process Mining are made using AppOne, which is then configured to specific needs.
The functionality of apps and discovery accelerators can be extended with functions specific to your organization under its own brand identity. In case a different app is necessary altogether, the full functionality of UiPath Process Mining can be used to create a completely new app.
Git is used for storing dashboards and collaborative development on the UiPath Process Mining platform. For single-server deployments, the built-in Git server can be used which does not require any additional setup. For multiple-server deployments, an (existing) Git server within your organization or a cloud-based Git server (e.g. from UiPath Process Mining or GitHub) can be used.
TRACY​
TRACY is a technique that defines the layout of process graphs. TRACY lets process graphs look more like how you would draw a process yourself. When drawing a process, you normally begin with the start activity and finish with the end activity of the process. In between, you try to position all other activities in their executed order. TRACY takes the overall flow of the process into account and displays this as the main flow in your process graph. With TRACY all the activities of the process are positioned and ordered in a way that makes sense. This helps users to more easily understand their processes.
When changing data, TRACY minimizes changes to the process graph. When users add process filters to display happy paths or to filter out data, TRACY keeps the layout of the process graph as stable as possible. When analyzing a process, the process graph now always looks about the same, no matter which dashboard is used, or which filters apply. This makes analyzing the process easier.
TRACY smoothly animates the transitions between filter states. This helps users to understand what happens when filtering.
In-memory database​
The in-memory database stores all data for fast access by the process mining algorithms. In this way, the data can be accessed very quickly without using the input databases.
Sources de données​
UiPath Process Mining prend en charge les fichiers texte tels que .txt, .csv, .tsv pour lesquels le délimiteur et les guillemets peuvent être sélectionnés. Les fichiers texte ASCII sont pris en charge en codage Latin-1 (ISO-8859-1) et les fichiers UTF-8 sont pris en charge avec et sans nomenclature.
En outre, les fichiers Excel (.XLSX et .XLS) peuvent être importés. La feuille ou la plage à l'intérieur du fichier peut être spécifiée. Pour les feuilles, une détection automatique est effectuée pour la plage de données réelle ; si la détection automatique échoue, la plage doit être spécifiée dans Excel, puis utilisée. Unicode dans Excel est entièrement pris en charge.
All databases that can be accessed via a 64-bit ODBC driver can be used as a data source. Below is a list of commonly used databases.
  • MSSQL
  • Oracle
  • MySQL
  • MariaDB
  • PostgreSQL
  • Firebird
  • Accès
Script datasources (R/Python)​
UiPath Process Mining contains functionality that supports processing data with external tools, such as R script and Python, that can be used as a datasource. Application developers can define which attributes need to be exported to the external process.
