Process - Compare
Processus - Comparez les tableaux de bord pour comparer deux ensembles de chemins côte à côte ou combinés à l'aide d'un attribut sélectionné dans la version autonome de Process Mining.
Introduction​
The dashboards Process – Compare – Side by side and Process – Compare – Combined are meant to compare two sets of paths from your process.
You can select the attribute you want to use for the comparison from the Compare attribute selector.
Comparer - Côte à côte​
The Compare - Side by side dashboard shows the two sets of paths next to each other. See illustration below.
Comparer - Combiné​
The Compare - Combined dashboard combines the process sets in one graph and shows the overlap and differences between the processes in different colors. See illustration below.
  • Introduction​
  • Comparer - Côte à côte​
  • Comparer - Combiné​
