Envoi d’idées d’automatisation au Automation Hub d’UiPath
Intégration entre Process Mining autonome et UiPath Automation Hub qui transforme les idées d'automatisation découvertes en candidats d'implémentation exploitables.
Introduction​
Different UiPath products work together to discover, investigate and build automation and communicate process improvements. UiPath Automation Hub is used to turn ideas for automation that are discovered from UiPath Process Mining into real automated implementations. If UiPath Process Mining is set up for integration with UiPath Automation Hub you can send ideas for process improvements that are subject for automation directly from the Process Graph to UiPath Automation Hub.
In UiPath Automation Hub the idea will be investigated and processed. Once the automation is built, the impact should become visible in UiPath Process Mining.
Soumettre des idées d'automatisation​
When you identify a bottleneck in your process while monitoring, for example when a manual activity takes a long time to be executed, you might want to send a request to automate the activity to UiPath Automation Hub. You can do this directly from the Process Graph.
Follow these steps to submit a request for automation and send it to UiPath Automation Hub.
ÉtapeAction
1Dans le graphique du processus, cliquez avec le bouton droit sur l'activité que vous identifiez comme candidate possible à l'automatisation.
2Sélectionnez Soumettre en tant qu'idée d'automatisation... dans le menu contextuel. La boîte de dialogue Soumettre en tant qu'idée d'automatisation s'affiche. Voir illustration ci-dessous.
3Entrez les détails requis pour la demande d'automatisation. Voir ci-dessous pour une description des champs.
4Click on SEND.
Remarque :
Be careful when completing the fields in the Submit As Automation Idea dialog since the values submitted may have an impact on the automation potential or determining the ease of automation.
You can also select an activity and click on the icon at the top of the Process Graph to open the Submit As Automation Idea dialog.
Remarque :
Si un filtre de graphique de processus est actif, par exemple Sélectionner les incidents qui passent par cette activité, l'activité est automatiquement sélectionnée comme activité pour l'idée d'automatisation lorsque vous cliquez sur l'icône Envoyer vers Automation Hub . Voir également Filtres de graphiques de processus.
Send to Automation Hub dialog​
The Send to Automation Hub dialog enables you to provide input for the Detailed Assessment of the automation idea to be sent to UiPath Automation Hub. Some of the fields already have a prefilled value, but you can change them according to your needs.
Les champs répertoriés ci-dessous se trouvent dans les questions d'évaluation par défaut de UiPath Automation Hub . Dans l'évaluation détaillée d'Automation Hub, les questions par défaut sont personnalisables ; si ces questions sont modifiées, les champs de boîte de dialogue Envoyer à Automation Hub seront eux aussi modifiés. Veuillez noter que dans ce cas l'idée d'automatisation peut ne pas être envoyée correctement et des messages d'erreur peuvent s'afficher. Reportez-vous à la documentation d'Automation Hub pour plus d'informations.
Below is a description of the fields of the Send to Automation Hub dialog.
Élément
Titre de l’idée d’automatisation
Saisissez un titre pour l'idée d'automatisation.
Vous pouvez, par exemple, utiliser le format Activity name - Process name .
Remarque : le titre doit être un titre unique dans l'instance UiPath Automation Hub .
Activité
L'activité qui est indiquée comme candidate à l'automatisation.
Remarque : si vous avez utilisé l'élément du menu contextuel Soumettre une automatisation à partir d'une activité spécifique ou créé l'idée à partir d'une activité sélectionnée, cette activité est sélectionnée par défaut.
Domaine d’activité
The name of a category that is predefined in UiPath Automation Hub as an area for automation to which the automation idea is mapped.
Pourcentage d’entrées de données numériques
Entrez un nombre qui indique le pourcentage d'entrée numérique.
Pourcentage d’entrées de données numériques structurées
Une liste déroulante contenant des options permettant de sélectionner la proportion de l'entrée numérique à structurer.
Nombre de manières de réaliser l’activité
Une liste déroulante contenant des options pour indiquer le nombre de façons de terminer l'activité qui est extraite des données.
Une brève description de l'idée d'automatisation où vous pouvez inclure les conditions préalables, les entrées ou les déclencheurs et les résultats.
Automatisation soumise​
Lorsque l'idée d'automatisation a été envoyée avec succès, une boîte de dialogue de confirmation s'affiche. Voir illustration ci-dessous.
When you click on the hyperlink in the confirmation dialog, you are redirected to the idea in UiPath Automation Hub where you are assigned as the submitter of the idea.
In Automation Hub the Process Mining Dashboard link is available to go back to the process graph from which the idea was submitted. See illustration below.
Remarque :
The Process Mining Dashboard link will also be available for other UiPath Automation Hub users that have the same permissions as the user who submitted the idea.
De plus, le graphique de processus à partir duquel l'idée a été soumise s'affiche dans la section Média , en bas de la page.👎
Remarque :
Les avantages par employé (devises/an) affichés dans le volet ICP d’évaluation dans Automation Hub sont calculés à partir de la somme des coûts annuels de l’événement. Il peut y avoir un léger écart entre le Nombre d'événements affichés dans Process Mining et les Volumes (par fréquence) dans Automation Hub. Elle s’étend toujours sur une année complète.
