Plazo - Fechas límite
Panel de tiempo: fechas límite en Process Mining independiente, utilizado para analizar los casos que cumplen o no los plazos y los costes asociados para los hitos del proceso predefinidos.
Introducción​
The Timing – Due dates dashboard displays information regarding cases meeting or not meeting deadlines and the related costs. Due dates can be predefined to set a significant stage or activity deadline in processes. The Timing – Due dates dashboard can be used to analyze various aspects of due dates in the processes. Using this dashboard, predefined due dates in the process can be examined, such as a payment deadline or an SLA that needs to be met on time.
Nota:
The Timing - Due dates dashboard will only be visible if the dataset contains due dates.
On time​
A due date can be subdivided in various groups or Time bins of lateness. Using the Timing - Due dates dashboard, it is visible how many due dates fall in which category. If a process has multiple due dates related to it, they can all be added to the analysis, but the dashboard will show only one of the due dates at a time. See illustration below.
Costes y días de retraso​
Due dates can have amounts associated with them, for example, a discount for timely payment or a fine for late delivery. These amounts can be analyzed using the Timing - Due dates dashboard as well. See illustration below.
Leyenda de fechas límite​
Una leyenda en el panel de filtros explica el significado de los colores en el análisis.
Consulta la siguiente ilustración.
Imagen de documentos
Historial​
Por tipo de caso se muestra el historial de pagos a tiempo y atrasados de las facturas y los costes involucrados.
  • Introducción​
  • On time​
  • Costes y días de retraso​
  • Leyenda de fechas límite​
  • Historial​
