Análisis: análisis de la causa raíz
Análisis: panel de análisis de causa raíz en TemplateOne para Process Mining independiente, utilizado para investigar el comportamiento no deseado de los casos e identificar oportunidades de mejora de la automatización.
¿Qué es el análisis de la causa raíz?​
El análisis de la causa raíz se puede utilizar para analizar el comportamiento de los casos, en particular el comportamiento no deseado, y cómo mejorarlo mediante la automatización.
In the Analysis – Root cause analysis dashboard you can compare the occurrence of cases with a certain behavior relatively to a reference set of cases. The set of Reference cases is defined based on the Case start filter. Within this set of cases, you can select the behavior that you want to analyze. For example, cases with a certain tag. This selection is called the Selected cases.
Análisis: panel Análisis de causa raíz​
The Analysis - Root cause analysis dashboard enables you to compare a set of cases selected by using a specific filter setting with the reference set of cases that is defined by the Case start filter. For the attribute selected in the dashboard a comparison of the absolute and relative frequency of the attribute value within the selected cases and the reference cases is displayed.
Influencia​
The Influence is the deviation from the Reference %. The Reference % is calculated as the percentage of Selected cases in the Reference cases. A large deviation from the Reference % indicates a possible high influence on the selection.
Nota:
Es posible seleccionar varios atributos para el análisis de la causa raíz. Consulta también Trabajar con diagramas.
Realizar análisis de la causa raíz​
To perform a root cause analysis first define what you want to analyze. Then add user filters to define the cases for the analysis.
Display detail information​
Click on the Information icon in the upper-right corner of the Analysis - Root cause analysis dashboard to display detail information on the root cause analysis.
A popup window is displayed containing detailed information on the data actually displayed in the Analysis - Root cause analysis dashboard. See the illustration below.
