Conformidad - Análisis de la causa raíz
Conformidad: panel de análisis de causa raíz en Process Mining independiente para identificar causas específicas detrás de las desviaciones del proceso y comportamientos de casos no deseados.
Introducción​
The Conformance – Root cause analysis dashboard supports you to determine the specific root causes of deviations from the desired process.
¿Qué es el análisis de la causa raíz?​
El análisis de la causa raíz se puede utilizar para analizar el comportamiento de los casos, en particular, el comportamiento no deseado.
In the Conformance – Root cause analysis dashboard you can compare the occurrence of cases with a certain behavior relatively to a reference set of cases. The set of Reference cases is defined based on the Case end and Case status filters. Within this set of cases, you can select the behavior that you want to analyze. For example, cases with a certain tag. This selection is called the Selected cases.
Conformidad: panel de análisis de causa raíz​
The Conformance - Root cause analysis dashboard enables you to compare a set of cases selected by using a specific filter setting with the reference set of cases that is defined by the Case end and Case status filters. For the attribute selected in the dashboard a comparison of the absolute and relative frequency of the attribute value within the selected cases and the reference cases is displayed.
Influencia​
The Influence is the deviation from the Reference %. The Reference % is calculated as the percentage of Selected cases in the Reference cases. A large deviation from the Reference % indicates a possible high influence on the selection.
Nota:
Es posible seleccionar varios atributos para el análisis de la causa raíz. Consulta también Trabajar con diagramas.
Realizar análisis de la causa raíz​
To perform a root cause analysis first define what you want to analyze. Then add user filters to define the Selected cases for the analysis. See animation below for an example root cause analysis based on tag Multiple finale checks done.
In the above example, 22% of the Reference cases have the Tag Multiple finale checks done. Cases that show a large deviation from the Reference % of 22% indicate a possible high influence. In the example, 46% of the cases with Case type Preferred supplier have the Tag Multiple finale checks done. This deviation of +24% indicates a possible influence and you may want to analyze these type of cases to prevent the occurrence of this tag in the future.
Display detail information​
Sigue este paso para mostrar información detallada sobre el análisis de la causa raíz.
PasoAcción
1Click on the Information icon in the upper-right corner of the Conformance - Root cause analysis dashboard.
A popup window is displayed containing detailed information on the data actually displayed in the Conformance - Root cause analysis dashboard. See illustration below.
