Process Mining user guide
- Release notes
- Getting started
- Configuration
- Integrations
- Authentication
- Working with Apps and Discovery Accelerators
- AppOne menus and dashboards
- AppOne setup
- TemplateOne 1.0.0 menus and dashboards
- TemplateOne 1.0.0 setup
- TemplateOne menus and dashboards
- TemplateOne 2021.4.0 setup
- Getting started with TemplateOne
- Steps to roll-out TemplateOne
- Directly loading data in TemplateOne
- How to use AppOne connectors with TemplateOne
- Adding Tags, Due dates, or Automation estimates to TemplateOne
- Purchase to Pay Discovery Accelerator menus and dashboards
- Purchase to Pay Discovery Accelerator Setup
- Order to Cash Discovery Accelerator menus and dashboards
- Order to Cash Discovery Accelerator Setup
- Basic Connector for AppOne
- SAP Connectors
- Introduction to SAP Connector
- SAP input
- Checking the data in the SAP Connector
- Adding process specific tags to the SAP Connector for AppOne
- Adding process specific Due dates to the SAP Connector for AppOne
- Adding automation estimates to the SAP Connector for AppOne
- Adding attributes to the SAP Connector for AppOne
- Adding activities to the SAP Connector for AppOne
- Adding entities to the SAP Connector for AppOne
- SAP Order to Cash Connector for AppOne
- SAP Purchase to Pay Connector for AppOne
- SAP Connector for Purchase to Pay Discovery Accelerator
- SAP Connector for Order-to-Cash Discovery Accelerator
- Superadmin
- Dashboards and charts
- Tables and table items
- Application integrity
- How to ....
- Working with SQL connectors
- Introduction to SQL connectors
- Setting up a SQL connector
- CData Sync extractions
- Running a SQL connector
- Editing transformations
- Releasing a SQL Connector
- Scheduling data extraction
- Using SQL connectors for released apps
- Generating a cache with scripts
- Separate development and production environments
- Useful resources
Business data enrichment for TemplateOne in Process Mining standalone, covering how to add tags, due dates, and automation estimates using a connector-built dataset.
Introduction
If you want to add business data to TemplateOne, for example, tags, due dates, or automation estimates, you must use a connector to create a proper dataset for use with TemplateOne. You can add tags, due dates, or automation estimates in a similar way as for AppOne, for example, using the Basic Connector.
Note:
Reference models are not supported for TemplateOne.
Important:
Always make sure that your input data is formatted according to the TemplateOne data model. See Input tables of TemplateOne.
