Process Mining user guide
Last updated May 5, 2026
Connection string tables
Introduction
UiPath Process Mining uses connection strings to load data. Input tables are therefore also called Connection string tables. Connection string tables can be recognized by the Connection string icon.
Input tables can be connected to multiple types of data sources by using connection strings. Uploading a file automatically creates a connection string table.
Viewing the connection string
Follow these steps to view the connection string.
StepAction
1Go to the Data tab of your developer environment.
2Double-click on the table for which you want to view the connection string. The Edit Connection String Table dialog is opened showing the connection string. See the illustration below for an example.
docs image
This string denotes that a file is loaded, where it is located, and how this file is parsed. This string is automatically generated when using the Upload a file… option.
Below is a description of the parameters of the connection string.
Parameter
driver
Defines what type of data connection is created. In this case, `{mvfile
mv-enable
Enables you to disable a connection string. By default, this setting is set to True . A connection string can be disabled by settings mv-enable to False. If not set, it will default to True .
filename
Denotes the relative path to the location of the file. The root of this path is defined by the table scope of this table.
The type of file is taken from the extension of the file.
Note: instead of a relative path you can use a url, which enables you to load a file from a webserver via HTTPS. Since the `{mvfile
hasheader
If True , the values in the first line of the file will be used as the names of the attributes.
If False , all lines of the file will be parsed as values of the attributes, and the attributes will be automatically named (A1, A2, …).
delim
Contains the character that separates the fields in a line. For example tab, semicolon, comma, or space. This can either be the character itself, or the ASCII code of this character.
To avoid confusion with characters also used in a connection string itself, the ASCII code (for example, 59) is used.
quote
Contains the character that encloses fields within the file. Usually, this is not necessary, and none can be used.
Note: When fields can contain the delim character, all fields within this column should be quoted using a character that is not used in the data fields.
encoding
The encoding of the file defines how characters are parsed. Usually, this is UTF-8.
Creating a new table using a connection string
Follow these steps to create a new table using a connection string.
StepAction
1Right click in the Data tab and select New able - Connection string.... A connection string table New_table is created in the Data tab.
2Double-click on New_table to open the Edit Connection String Table dialog.
3Enter the connection string in the Connection String field.
4(Optionally) Enter a query the Query field.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
