test-manager
Attribuer des cas de test à des ensembles de test
Assign test cases to a test set using static or dynamic assignment.
Après avoir créé un ensemble de test, vous devez lui attribuer des cas de test. Pour attribuer des cas de test à un ensemble de test, ouvrez l'ensemble de test souhaité, puis, dans le menu Tâches, sélectionnez Attribuer des cas de test.
Context​
You can assign test cases to a test set in two different ways:
  • Utiliser l'affectation statique : sélectionnez manuellement les cas de test que vous souhaitez lier.
  • Using Dynamic assignment - input the label of the test cases that you want to assign. Whenever an execution is started, all test cases which have at least one of the selected labels assigned are added to the execution.
The following sections describe each way.
Assigning test cases statically​
Static assignment links the test cases that you choose manually.
Étapes​
  1. Open the test set to which you want to assign test cases.
  2. Dans le menu Tâches , sélectionnez Attribuer des cas de test.
  3. Select Static Assignment and choose the test cases.
  4. Sélectionnez Affecter.
Résultat​
The test cases that you chose are assigned to the test set.
Assigning test cases dynamically​
Dynamic assignment adds, at each execution, all test cases that have at least one of the labels that you enter.
Étapes​
  3. Select Dynamic Assignment and enter the labels of the test cases.
Résultat​
The labels are saved on the test set, and each execution adds the test cases that carry at least one of them.
  • Context​
  • Assigning test cases statically​
  • Étapes​
  • Résultat​
  • Assigning test cases dynamically​
  • Étapes​
  • Résultat​
