test-manager
Exigences de contrôle qualité
Autopilot suggestions for evaluating requirement clarity, completeness, and consistency, with options to implement, regenerate, or export them.
Autopilot vous aide à évaluer les exigences relatives aux aspects qualitatifs tels que la clarté, l’intégralité et la cohérence dans Test Manager.
Context​
Selecting Evaluate Requirement for an existing requirement evaluates it using Autopilot, generating a list of suggestions that you can directly implement.
Étapes​
  1. For an existing requirement, select Evaluate Requirement.
  2. (Optional) Provide supporting documents to Autopilot and additional guidance through a prompt that you choose from your library or that you enter yourself.
  3. Expand each suggestion to update its status based on your implementation progress:
    • To add the suggestion to your requirements, mark its status as In Work or Done.
    • To remove the suggestion, use the remove option.
  4. (Optional) To generate more suggestions or regenerate them with different supporting documents or additional guidance, select Suggest More or Regenerate.
  5. (Optional) To keep suggestions for future reference, export them to Word.
Résultat​
Autopilot evaluates the requirement and lists suggestions that you can implement, track by status, and export.
  • Context​
  • Étapes​
  • Résultat​
  • Articles associés​
