test-manager
Disabling governance at test case log level
Un-govern a test case log directly in Test Manager, independently of its parent test case's governance state.
You can disable governance on a test case log at any time, independently of the parent test case. Disabling governance on the parent test case does not do this for you. Once a log is governed, it is a disjoint entity from its parent, so the log's governance must be disabled directly if that is what you intend.
Prérequis​
To disable governance on a test case log, you must hold the Test Manager Administrator role, the Test Governance Administrator role, the Project Owner role, or be assigned the Test Process Governance permission.
Étapes​
  1. Go to the test set execution or test case log view containing the log you want to un-govern.
  2. Open the test case log.
  3. Toggle off the Governed option for the log.
Résultat​
Governance is disabled for the test case log. Its existing signatures and approvers are removed, and it is no longer subject to approval requirements. This has no effect on the parent test case's own governance state, or on the log's own future re-executions, which remain ungoverned unless governance is re-enabled on the log. The Governance section becomes disabled. You can re-enable governance on the log and resume the governance process at any time.
  • Prérequis​
  • Étapes​
  • Résultat​
