test-manager
Step 2: Configuring Xray connection
Configure the Xray connection in Test Manager by entering your Jira server details and credentials to sync requirements and test cases.
An Xray connection links a Test Manager project to your Xray for Jira project.
Setting up an Xray connection​
The connection is created from Project Settings > Integration, and its API Key is then pasted into the UiPath Test Manager settings of your Jira project.
Context​
Xray Server uses a password, while Xray Cloud uses an API token and client credentials.
Prérequis​
  • A Test Manager administrator account.
  • For Xray Cloud, a Jira administrator account. You need it to create the API Key that contains the Client Id and Client Secret.
Étapes​
  1. Connectez-vous à Test Manager en tant qu'administrateur.
  2. Ouvrez votre projet.
  3. Navigate to Project Settings > Integration.
  4. Select New Connection and select XRay from the dropdown to create the connection.
  5. Configurez comme suit :
    • Name: Enter a name for your Xray connection.
    • Description (optional): Add a description.
    • Server URL: Add the Jira Server URL, including the port number. This is the URL of the server that exposes the Jira REST API. It is usually identical to the URL you navigate to when using Jira through your browser. For example: https://company-name.atlassian.net.
    • Web URL (optional): Add the web URL in case the server URL is not hosted under the same address as the web URL used to access Jira resources.
    • Username: The username you use to authenticate to the Jira API.
    • Password (Xray Server only): The password you use to authenticate to the Jira API.
    • Project Key: Enter the project key from Jira which refers to the project you want to integrate.
    • Jeton d'API (Xray Cloud uniquement) : générez un jeton d'API. Pour plus d’informations sur les jetons d’API Atlassian, consultez Gérer les jetons d’API pour votre compte Atlassian.
    • Client Id (Xray Cloud only): Create an API Key containing a Client Id and Client Secret. Enter the Client Id generated in Jira Software.
    • Client Secret (Xray Cloud only): Enter the Client Secret generated in Jira Software.
  6. Select Save to add the connection.
  7. Copy the API Key.
  8. Ouvrez Jira et accédez à Paramètres du projet > UiPath® Test Manager.
  9. Configure project settings and paste the API key in the API Key - XRay Integration field.
Résultat​
Le projet Xray pour Jira est connecté à Test Manager. Les exigences et les cas de test sont synchronisés de Xray vers Test Manager, et les résultats des tests et les défauts sont synchronisés de Test Manager vers Xray et Jira.
Editing an Xray connection​
Editing a connection changes the settings of an existing Xray connection, such as the server URL, credentials, or project key.
Prérequis​
  • An existing Xray connection.
Étapes​
  3. Sélectionnez le bouton Paramètres pour ouvrir les paramètres du projet.
  4. Dans la liste Intégration, sélectionnez une connexion Xray pour développer le panneau.
  5. Sélectionnez Modifier pour configurer la connexion.
  6. Cliquez sur Enregistrer pour confirmer.
Résultat​
The Xray connection is updated with the new configuration details.
Deleting an Xray connection​
Deleting a connection removes it together with its associated requirements and test cases.
Prérequis​
Étapes​
  5. Sélectionnez Supprimer pour supprimer la connexion.
  6. Sélectionnez OK pour confirmer.
Résultat​
The Xray connection and its associated requirements and test cases are removed.
