Last updated Apr 15, 2026
Migration compatibility matrix
When migrating from a standalone product to Automation Suite, you must make sure the versions of the standalone product, UiPath.OrganizationMigrationApp, Automation Suite, and the Identity and Orchestrator migrators are compatible.
The following table describes the version compatibility required to perform a migration to Automation Suite:
Source standalone product version
Test Manager migration script version UiPath.OrganizationMigrationApp
version
Target Automation Suite version
Identity migrator Orchestrator migrator
Orchestrator Insights Test Manager
2024.10.6
2024.10.5
2024.10.6 2024.10.6 2024.10.1 2024.10.5 identity-service-datamigrator:25.10.17-release-k8.21 orchestrator:24.10.9
2024.10.6
2024.10.5
2024.10.6 2024.10.5 2024.10.1 2024.10.5 identity-service-datamigrator:25.8.6-release-k8.15 orchestrator:24.10.8
2024.10.3
2024.10.4
2024.10.5 2024.10.4 2024.10.1 2024.10.4 identity-service-datamigrator:25.5.19-release-k8.2 orchestrator:24.10.7
2024.10.2 2024.10.4 2024.10.3 2024.10.1 2024.10.3 identity-service-datamigrator:25.3.19-release-k8.27 orchestrator:24.10.5
2024.10.1 2024.10.2
2024.10.3
2024.10.2 2024.10.1 2024.10.2 identity-service-datamigrator:25.1.22-alpha-k8.19 orchestrator:24.10.3
2024.10.1 2024.10.1 2024.10.1 2024.10.1 2024.10.1 identity-service-datamigrator:24.11.25-alpha-k8.10 orchestrator:24.10.2
2024.10.0 2024.10.0 2024.10.0 2024.10.1 2024.10.0 identity-service-datamigrator:24.10.9-release-k8.31 orchestrator:24.10.0
Note:
How to read the table
  • As an example, to migrate standalone Orchestrator 2024.10.0, you must use UiPath.OrganizationMigrationApp 2024.10.0 and make sure that you installed Automation Suite 2024.10.0.
  • For information on updates to the UiPath.OrganizationMigrationApp and the migration workflows, see the release notes for your targeted Automation Suite version. The links to the release notes are available in the Automation Suite version column.
    If there is no entry dedicated to the UiPath.OrganizationMigrationApp in the release notes, this means that we made only minor improvements to the tool.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
