Node removal failure due to incorrect scaling operation naming
Prometheus operator scale-up failure after node removal in Automation Suite due to a misnaming error, and how to recover manually.
After a node removal, an attempt is made to scale up the Prometheus operator. However, due to a misnaming error, the scale-up command fails with an error: no objects passed to scale message.
Solution
To address the issue, you must manually scale up the operator using the following command:
kubectl -n monitoring scale --replicas=1 deploy/monitoring-kube-prometheus-operator
For future node removals, make sure to use the correct Prometheus operator name. You must edit the node removal script by running the following command from the installer directory:
sed -i 's/rancher-monitoring-operator/monitoring-kube-prometheus-operator/g' Modules/graceful-node-removal.sh
  • Description
  • Solution
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
