Automation Suite on Linux Installation Guide
Last updated Jan 8, 2025
Migrating in-cluster objectstore to external objectstore
To migrate from in-cluster objectstore to external objectstore, take the following steps:
  1. Update the external objectstore parameters in the cluster_config.json file. For instructions, see External Objectstore configuration.
  2. Rerun the uipathctl installer:
    ./bin/uipathctl manifest apply cluster_config.json --versions versions/helm-charts.json./bin/uipathctl manifest apply cluster_config.json --versions versions/helm-charts.json
  3. Ensure that the files have been copied accurately, then create a backup of the Ceph data on an alternative storage solution, such as NFS. This step is crucial in preventing possible data loss.
  4. Once all products are configured to connect with the external objectstore, you can uninstall Ceph by running the following command:
    uipathctl rke2 objectstore uninstalluipathctl rke2 objectstore uninstall
