Automation Suite on Linux Installation Guide
Last updated Jan 22, 2025
Evaluating your storage needs
Note: The information on this page only applies if you use in-cluster storage. If you use an Azure storage account, AWS S3, or other S3 compatible storage, you do not need this.
An Automation Suite cluster uses the objectstore disks attached to its server nodes as storage resources available to all the products enabled on your cluster. Each product uses these resources differently.
To understand your storage needs and plan for them accordingly, refer to the following terminology and guidelines.
Terminology
  • Server node disk size – The size of all individual disks attached to each server node.
    • Disks on each server may have different sizes as long as the sum of all the disk sizes is identical on all servers.
  • Total cluster disk size – Server node disk size multiplied by the number of server nodes.
  • Application available storage – The amount of storage available for applications to consume.
    • Application available storage is lower than the total storage attached. This is to ensure we have a higher resiliency to fault tolerance and high availability.
The following table describes the multi-node HA-ready hardware requirements for the Complete product selection in the context of the previously introduced terms.
Number of server nodes
3
512 GiB
1.5 TiB
512 GiB
Estimating the storage used by your applications
As you enable and use products on the cluster, they consume some storage from the application available storage. Products usually have a small enablement footprint as well as some usage-dependent footprint that varies depending on the use case, scale of use, and project. The storage consumption is evenly distributed across all the storage resources (data disks), and you can monitor the levels of storage utilization using the Automation Suite monitoring stack.
How to monitor available storage
You will receive an alert with a warning when the storage consumption exceeds 75%. You will receive another critical alert when the storage consumption exceeds 85%; in this case, the storage will be read-only.
How to increase storage capacity
If your evaluated needs do not meet the recommended hardware requirements, you can add more storage capacity using either one or both of the following methods:
  1. You have to add a new disk on all the server nodes of same size.
  2. To configure the disk, see our docs.
How to calculate your usage needs
You can estimate your storage consumption using the product-specific metric in the following tables. These tables describe how much content you can place on your cluster out of the box. For reference, they include the storage footprint of a typical usage scenario of each product.
Product
Storage-driving metric
Storage per metric
Typical use case
Shared suite capabilities
  • Application logs
N/A
Typically, 7 days of application logs is around 25 GiB.
Orchestrator
  • Size of the automation packages for deployed automations
  • Size of the storage buckets of deployed automation
  • MiB per package
  • MiB per bucket
Typically, a package is 5 MiB, and buckets, if any, are less than 1 MiB. A mature enterprise has 5 GiB of packages and 6 GiB of buckets deployed.
Action Center
  • Number of documents stored by customer in document tasks
  • Number of tasks created
  • GiB per document in document tasks
  • Number of tasks
Typically, a document takes 0.15 MiB, and the forms to fill take an additional 0.15 KiB. In a mature enterprise this can roll up to 4 GiB in total.
Test Manager
  • Number of attachments and screenshots stored by users
  • Mb of attachments and screenshots
Typically, all files and attachments add up to approximately 5 GiB.
Insights
  • Enablement footprint and the number of dashboards published
  • GiB per dashboard
2 GiB are required for enablement, with the storage footprint growing with the number. A well-established enterprise-scale deployment requires another few GiB for all the dashboards.
Automation Hub
N/A
N/A
2 GiB fixed footprint
Automation Ops
N/A
N/A
No storage footprint
Apps
  • Number of apps deployed and enablement footprint
  • Number of apps, size of apps, size of database supporting apps
Typically, the database takes approximately 5 GiB, and a typical complex app consumes approximately 15 MiB.
AI Center
  • Number of uploaded ML packages
  • Number of datasets for analysis
  • Number of published pipelines
  • GiB per package
  • GiB per dataset
  • Number of pipelines
A typical and established installation will consume 8 GiB for 5 packages and an additional 1GiB for the datasets.
A pipeline may consume an additional 50 GiB, but only when actively running.
Document Understanding
  • Size of ML model
  • Size of OCR model
  • Number of stored documents
  • GiB per ML model
  • GiB per OCR model
In a mature deployment, 12GiB will go to ML model, 17GiB to the OCR, and 50GiB to all documents stored.
Task Mining
  • Hours of user activity analyzed to suggest automation patterns
  • GiB per hour
Typically, about 200GiB of activity log data should be analyzed to suggest meaningful automations. Highly repetitive tasks however, may require much less data.
Process Mining
  • the number of events in millions
  • the case and event fields
  • the number of events in millions x the number of case and event fields x 0.02 GiB
Minimal footprint only used by users uploading data via the Process Mining portal. Approximately 10 GiB of storage should be enough in the beginning.
