Last updated Mar 9, 2026
How to clean up old logs stored in the sf-logs bucket
A bug might cause log accumulation in the sf-logs object store bucket. To clean up old logs in the sf-logs bucket, follow the instructions on running the dedicated script. Make sure to follow the steps relevant to your environment type.
To clean up old logs stored in the sf-logs bucket, take the following steps:
  1. Get the version of the sf-k8-utils-rhel image available in your environment:
    • in an offline environment, run the following command: podman search localhost:30071/uipath/sf-k8-utils-rhel --tls-verify=false --list-tags
    • in an online environment, run the following command: podman search registry.uipath.com/uipath/sf-k8-utils-rhel --list-tags
  2. Update the following yaml definition accordingly to include the proper image tag:
    apiVersion: v1
    kind: ConfigMap
    metadata:
      namespace: istio-system
    data:
      cleanup_old_logs.sh:  |
        #!/bin/bash
        function parse_args() {
          CUTOFFDAY=7
          SKIPDRYRUN=0
          while getopts 'c:sh' flag "$@"; do
            case "${flag}" in
            c)
              CUTOFFDAY=${OPTARG}
            s)
              SKIPDRYRUN=1
            h)
              display_usage
              exit 0
              echo "Unexpected option ${flag}"
              display_usage
              exit 1
            esac
          done
          shift $((OPTIND - 1))
        function display_usage() {
          echo "usage: $(basename "$0") -c <number> [-s]"
          echo "  -s                                                         skip dry run, Really deletes the log dirs"
          echo "  -c                                                         logs older than how many days to be deleted. Default is 7 days"
          echo "  -h                                                         help"
          echo "NOTE: Default is dry run, to really delete logs set -s"
        function setS3CMDContext() {
            OBJECT_GATEWAY_INTERNAL_HOST=$(kubectl -n rook-ceph get services/rook-ceph-rgw-rook-ceph -o jsonpath="{.spec.clusterIP}")
            OBJECT_GATEWAY_INTERNAL_PORT=$(kubectl -n rook-ceph get services/rook-ceph-rgw-rook-ceph -o jsonpath="{.spec.ports[0].port}")
            AWS_ACCESS_KEY=$1
            AWS_SECRET_KEY=$2
            # Reference https://rook.io/docs/rook/v1.5/ceph-object.html#consume-the-object-storage
            export AWS_HOST=$OBJECT_GATEWAY_INTERNAL_HOST
            export AWS_ENDPOINT=$OBJECT_GATEWAY_INTERNAL_HOST:$OBJECT_GATEWAY_INTERNAL_PORT
            export AWS_ACCESS_KEY_ID=$AWS_ACCESS_KEY
            export AWS_SECRET_ACCESS_KEY=$AWS_SECRET_KEY
        # Set s3cmd context by passing correct AccessKey and SecretKey
        function setS3CMDContextForLogs() {
            BUCKET_NAME='sf-logs'
            AWS_ACCESS_KEY=$(kubectl -n logging get secret s3-store-secret -o json | jq '.data.S3_ACCESSKEY' | sed -e 's/^"//' -e 's/"$//' | base64 -d)
            AWS_SECRET_KEY=$(kubectl -n logging get secret s3-store-secret -o json | jq '.data.S3_SECRETKEY' | sed -e 's/^"//' -e 's/"$//' | base64 -d)
            setS3CMDContext "$AWS_ACCESS_KEY" "$AWS_SECRET_KEY"
        function delete_old_logs() {
            local cutoffdate=$1
            days=$(s3cmd ls  s3://sf-logs/ --host="${AWS_HOST}" --host-bucket= s3://sf-logs --no-check-certificate --no-ssl)
            days=${days//DIR}
            if [[ $SKIPDRYRUN -eq 0 ]];
            then
                echo "DRY RUN. Following log dirs are selected for deletion"
            fi
            for day in $days
            do
                day=${day#*sf-logs/}
                day=${day::-1}
                if [[ ${day} < ${cutoffdate} ]];
                then
                    then
                        echo "s3://$BUCKET_NAME/$day"
                    else
                        echo "###############################################################"
                        echo "Deleting Logs for day: {$day}"
                        s3cmd del "s3://$BUCKET_NAME/$day/" --host="${AWS_HOST}" --host-bucket= --no-ssl --recursive || true
                    fi
                fi
            done
        function main() {
            # Set S3 context by setting correct env variables
            echo "Bucket name is $BUCKET_NAME"
            CUTOFFDATE=$(date --date="${CUTOFFDAY} day ago" +%Y_%m_%d)
            echo "logs older than ${CUTOFFDATE} will be deleted"
            delete_old_logs "${CUTOFFDATE}"
            then
                echo "NOTE: For really deleting the old log directories run with -s option"
            fi
        parse_args "$@"
        main
        exit 0
    apiVersion: v1
    kind: Pod
    metadata:
    spec:
       serviceAccountName: fluentd-logs-cleanup-sa
       containers:
       - name: cleanup
         image: registry.uipath.com/uipath/sf-k8-utils-rhel:24.10.2
         command: ["/bin/bash"]
         args: ["/scripts-dir/cleanup_old_logs.sh", "-s"]
         volumeMounts:
         - name: scripts-vol
           mountPath: /scripts-dir
         securityContext:
           privileged: false
           allowPrivilegeEscalation: false
           readOnlyRootFilesystem: true
           runAsUser: 9999
           runAsGroup: 9999
           runAsNonRoot: true
           capabilities:
             drop: ["NET_RAW"]
       volumes:
       - name: scripts-vol
         configMap:
    apiVersion: v1
    kind: ConfigMap
    metadata:
    data:
        #!/bin/bash
          CUTOFFDAY=7
          SKIPDRYRUN=0
            case "${flag}" in
            c)
              CUTOFFDAY=${OPTARG}
            s)
              SKIPDRYRUN=1
            h)
              display_usage
              exit 0
              display_usage
              exit 1
            esac
          done
          echo "  -h                                                         help"
            AWS_ACCESS_KEY=$1
            AWS_SECRET_KEY=$2
            local cutoffdate=$1
            days=${days//DIR}
            then
            fi
            for day in $days
            do
                day=${day::-1}
                then
                    then
                    else
                    fi
                fi
            done
        function main() {
            then
            fi
        parse_args "$@"
        main
        exit 0
    apiVersion: v1
    kind: Pod
    metadata:
    spec:
       containers:
       - name: cleanup
         volumeMounts:
         - name: scripts-vol
         securityContext:
           privileged: false
           runAsUser: 9999
           runAsGroup: 9999
           runAsNonRoot: true
           capabilities:
             drop: ["NET_RAW"]
       volumes:
       - name: scripts-vol
         configMap:
  3. Copy the content of the aforementioned yaml definition to a file called cleanup.yaml. Trigger a pod to clean up the old logs:
    kubectl apply -f cleanup.yaml
  4. Get details on the progress:
    kubectl -n istio-system logs cleanup-old-logs -f
  5. Delete the job:
    kubectl delete -f cleanup.yaml
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
