- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Applying a patch
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining
- Task Mining troubleshooting
- Exploring Logs
Automation Suite on Linux Installation Guide
Kubernetes resources alerts
The Kube State Metrics collector is not able to collect metrics from the cluster without errors. This means important alerts may not fire. Contact UiPath® Support.
See also: Kube state metrics at release.
This alert indicates that memory usage is very high on the Kubernetes node.
MemoryPressure
incident type occurs when a Kubernetes cluster node is running low on memory, which can be caused by a memory leak in an
application. This incident type requires immediate attention to prevent any downtime and ensure the proper functioning of
the Kubernetes cluster.
If this alert fires, try to identify the pod on the node that is consuming more memory, by taking these steps:
Retrieve the nodes CPU and memory stats:
kubectl top node
kubectl top node -
Retrieve the pods running on the node:
kubectl get pods --all-namespaces -o wide --field-selector spec.nodeName=${NODE_NAME}
kubectl get pods --all-namespaces -o wide --field-selector spec.nodeName=${NODE_NAME} -
Check the memory usage for pods in a namespace using:
kubectl top pod --namespace <namespace> kubectl logs -f <pod-name> -n <ns>
If you are able to identify any pod with high memory usage, check the logs of the pod and look for memory leak errors.
To address the issue, increase the memory spec for the nodes if possible.
If the issue persists, generate the support bundle and contact UiPath® Support.
kubectl describe
, and logs with kubectl logs
to see details on possible crashes. If the issue persists, contact UiPath® Support.
kubectl logs
to see if there is any indication of progress. If the issue persists, contact UiPath® Support.
There has been an attempted update to a deployment or statefulset, but it has failed, and a rollback has not yet occurred. Contact UiPath® Support.
In high availability clusters with multiple replicas, this alert fires when the number of replicas is not optimal. This may occur when there are not enough resources in the cluster to schedule. Check resource utilization, and add capacity as necessary. Otherwise contact UiPath® Support.
An update to a statefulset has failed. Contact UiPath® Support.
See also: StatefulSets.
Daemonset rollout has failed. Contact UiPath® Support.
See also: DaemonSet.
kubectl describe
of the pod for more information. The most common cause of waiting containers is a failure to pull the image. For air-gapped
clusters, this could mean that the local registry is not available. If the issue persists, contact UiPath® Support.
This may indicate an issue with one of the nodes Check the health of each node, and remediate any known issues. Otherwise contact UiPath® Support.
A job takes more than 12 hours to complete. This is not expected. Contact UiPath® Support.
A job has failed; however, most jobs are retried automatically. If the issue persists, contact UiPath® Support.
The autoscaler cannot scale the targeted resource as configured. If desired is higher than actual, then there may be a lack of resources. If desired is lower than actual, pods may be stuck while shutting down. If the issue persists, contact UiPath® Support.
See also: Horizontal Pod Autoscaling
The number of replicas for a given service has reached its maximum. This happens when the amount of requests being made to the cluster is very high. If high traffic is expected and temporary, you may silence this alert. However, this alert is a sign that the cluster is at capacity and cannot handle much more traffic. If more resource capacity is available on the cluster, you can increase the number of maximum replicas for the service by following these instructions:
# Find the horizontal autoscaler that controls the replicas of the desired resource
kubectl get hpa -A
# Increase the number of max replicas of the desired resource, replacing <namespace> <resource> and <maxReplicas>
kubectl -n <namespace> patch hpa <resource> --patch '{"spec":{"maxReplicas":<maxReplicas>}}'
kubectl get hpa -A
See also: Horizontal Pod Autoscaling.
These warnings indicate that the cluster cannot tolerate node failure. For single-node evaluation clusters, this is known, and these alerts may be silenced. For multi-node HA-ready production setups, these alerts fire when too many nodes become unhealthy to support high availability, and they indicate that the nodes should be brought back to health or replaced.
KubeCPUQuotaOvercommit, KubeMemoryQuotaOvercommit, KubeQuotaAlmostFull, KubeQuotaFullyUsed, KubeQuotaExceeded
These alerts pertain to namespace resource quotas that only exist in the cluster if added through customization. Namespace resource quotas are not added as part of Automation Suite installation.
See also: Resource Quotas.
Indicates problems with the Kubernetes control plane. Check the health of master nodes, resolve any outstanding issues, and contact UiPath® Support if the issues persist.
See also:
KubeNodeNotReady, KubeNodeUnreachable, KubeNodeReadinessFlapping, KubeletPlegDurationHigh, KubeletPodStartUpLatencyHigh, KubeletDown
These alerts indicate a problem with a node. In multi-node HA-ready production clusters, pods would likely be rescheduled onto other nodes. If the issue persists, you should remove and drain the node to maintain the health of the cluster. In clusters without extra capacity, another node should be joined to the cluster first.
If the issues persist, contact UiPath® Support.
There are too many pods running on the specified node.
Join another node to the cluster.
There are different semantic versions of Kubernetes components running. This can happen as a result of an unsuccessful Kubernetes upgrade.
This alert indicates that the etcd cluster has an insufficient number of members. Note that the cluster must have an odd number of members. The severity of this alert is critical.
Make sure that there is an odd number of server nodes in the cluster, and all of them are up and healthy.
This alert shows that the etcd cluster has no leader. The severity of this alert is critical.
This alert indicates that the etcd leader changes more than twice in 10 minutes. This is a warning.
This alert indicates that a certain percentage of GRPC request failures was detected in etcd.
This alert indicates that etcd GRPC requests are slow. This is a warning.
If this alert persists, contact UiPath® support.
This alert indicates that a certain percentage of HTTP failures was detected in etcd.
This alert indicates that etcd member communication is slowing down. This is a warning.
This alert indicates that the etcd server received more than 5 failed proposals in the last hour. This is a warning.
This alert indicates that etcd WAL fsync duration is increasing. This is a warning.
This alert indicates that the Kubernetes API server is experiencing a high error rate. This issue could lead to other failures, so it is recommended that you investigate the problem proactively.
api-server
pod to find out the root cause of the issue using the kubectl logs <pod-name> -n kube-system
command.
- k8s.rules, kube-apiserver-availability.rules, kube-apiserver-slos
- KubeAPIErrorBudgetBurn
- kube-state-metrics
- KubeStateMetricsListErrors, KubeStateMetricsWatchErrors
- KubernetesMemoryPressure
- kubernetes-apps
- KubePodCrashLooping
- KubePodNotReady
- KubeDeploymentGenerationMismatch, KubeStatefulSetGenerationMismatch
- KubeDeploymentReplicasMismatch, KubeStatefulSetReplicasMismatch
- KubeStatefulSetUpdateNotRolledOut
- KubeDaemonSetRolloutStuck
- KubeContainerWaiting
- KubeDaemonSetNotScheduled, KubeDaemonSetMisScheduled
- KubeJobCompletion
- KubeJobFailed
- KubeHpaReplicasMismatch
- KubeHpaMaxedOut
- kubernetes-resources
- KubeCPUOvercommit, KubeMemoryOvercommit
- KubeCPUQuotaOvercommit, KubeMemoryQuotaOvercommit, KubeQuotaAlmostFull, KubeQuotaFullyUsed, KubeQuotaExceeded
- AggregatedAPIErrors, AggregatedAPIDown, KubeAPIDown, KubeAPITerminatedRequests
- kubernetes-system-kubelet
- KubeNodeNotReady, KubeNodeUnreachable, KubeNodeReadinessFlapping, KubeletPlegDurationHigh, KubeletPodStartUpLatencyHigh, KubeletDown
- KubeletTooManyPods
- kubernetes-system
- KubeVersionMismatch
- KubeClientErrors
- etdc Alerts
- EtcdInsufficientMembers
- EtcdNoLeader
- EtcdHighNumberOfLeaderChanges
- EtcdHighNumberOfFailedGrpcRequests
- EtcdGrpcRequestsSlow
- EtcdHighNumberOfFailedHttpRequests
- EtcdHttpRequestsSlow
- EtcdMemberCommunicationSlow
- EtcdHighNumberOfFailedProposals
- EtcdHighFsyncDurations
- EtcdHighCommitDurations
- kube-api
- KubernetesApiServerErrors
