- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
To effectively monitor the health of your Automation Suite services, you can use the health endpoints listed in this section. These endpoints allow you to quickly verify if a service is operating correctly.
Platform
https://<automation-suite-fqdn>/pap_/healthhttps://<automation-suite-fqdn>/pdp_/healthhttps://<automation-suite-fqdn>/identity_/.well-known/openid-configurationhttps://<automation-suite-fqdn>/identity_/web/https://<automation-suite-fqdn>/lease_/health/https://<automation-suite-fqdn>/license_/healthhttps://<automation-suite-fqdn>/organization_/healthhttps://<automation-suite-fqdn>/portal_/portal/shallow/healthStatushttps://<automation-suite-fqdn>/audit_/healthhttps://<automation-suite-fqdn>/resourcecatalog_/health
Action Center
https://<automation-suite-fqdn>/actions_/https://<automation-suite-fqdn>/bupproxyservice_/health/readyhttps://<automation-suite-fqdn>/processes_/
AI Center
https://<automation-suite-fqdn>/aifabric_/ai-apphttps://<automation-suite-fqdn>/aifabric_/ai-deployer/actuator/health/readyhttps://<automation-suite-fqdn>/aifabric_/ai-trainer/actuator/health/readyhttps://<automation-suite-fqdn>/aifabric_/ai-pkgmanager/actuator/health/readyhttps://<automation-suite-fqdn>/aifabric_/ai-helper/actuator/health/readyhttps://<automation-suite-fqdn>/aistorage_/health
Apps
https://<automation-suite-fqdn>/<org-name>/apps_/default/api/v1/default/system-health
Automation Hub
https://<automation-suite-fqdn>/automationhub_/fd-api/v1/pinghttps://<automation-suite-fqdn>/automationstore_/fd-api/v1/ping
Data Service
https://<automation-suite-fqdn>/dataservice_/api/HealthCheck/healthhttps://<automation-suite-fqdn>/dataservice_/assets
https://<automation-suite-fqdn>/du_/api/documentmanager/healthhttps://<automation-suite-fqdn>/du_/api/storage/healthhttps://<automation-suite-fqdn>/du_/api/eventservice/healthhttps://<automation-suite-fqdn>/du_/metering/alivehttps://<automation-suite-fqdn>/du_/ocr/info/readyhttps://<automation-suite-fqdn>/du_/extended-ocr/readyhttps://<automation-suite-fqdn>/du_/classify/MLclassification/info/readyhttps://<automation-suite-fqdn>/du_/svc/formextractor/infohttps://<automation-suite-fqdn>/du_/svc/intelligentkeywords/info
Insights
https://<automation-suite-fqdn>/insights_/health
Notification Service
https://<automation-suite-fqdn>/notificationservice_/notificationserviceapi/health/readinesshttps://<automation-suite-fqdn>/notificationservice_/usersubscriptionservice/health/readinesshttps://<automation-suite-fqdn>/notificationservice_/publishermetaservice/health/readiness
Orchestrator
https://<automation-suite-fqdn>/orchestrator_/api/health
Robotube
https://<automation-suite-fqdn>/robotube_/healthz
Task Mining
https://<automation-suite-fqdn>/taskmining_/console/api/healthhttps://<automation-suite-fqdn>/taskmining_/storage/api/health
Test Manager
https://<automation-suite-fqdn>/testmanager_/api/health/live
Checking service health
To check the health of a specific service, send a request to its corresponding endpoint, as shown in the following example.
curl -kiso /dev/null -w "%{http_code}" https://<automation-suite-fqdn>/orchestrator_/api/health
A successful response with an HTTP status code 200 indicates that the service is healthy.
