Last updated May 15, 2026
Step 5: Configuring SQL databases
Databases
Important:
  • Only Microsoft ODBC Driver 17 is supported.
  • SQL Server 2016 and 2017 are not supported in Automation Suite versions from 2024.10.3 onward. SQL Server 2019 or later is supported starting with Automation Suite version 2024.10.3.
Unless otherwise specified in the dedicated requirements sections, these requirements are applicable to all Automation Suite products.
Each product in Automation Suite requires its own SQL database with corresponding specifications.
By default, the installer creates all the databases for you during the installation process. You must provide the necessary permissions for the installer to do so on your SQL server.
Alternatively, you can create your own databases. The following table lists the database names and their corresponding formats.
Product / serviceDefault database nameConnection string format
Shared Platform CapabilitiesAutomationSuite_PlatformADO.NET
OrchestratorAutomationSuite_OrchestratorADO.NET
Action CenterAutomationSuite_OrchestratorADO.NET
Automation Suite RobotsAutomationSuite_OrchestratorADO.NET
Automation HubAutomationSuite_Automation_HubADO.NET
Automation OpsAutomationSuite_PlatformADO.NET
Data ServiceAutomationSuite_DataServiceADO.NET
InsightsAutomationSuite_InsightsADO.NET
Test ManagerAutomationSuite_Test_ManagerADO.NET
Task MiningAutomationSuite_Task_MiningADO.NET
AI CenterAutomationSuite_AICenterJDBC
AppsAutomationSuite_Apps 1ODBC
Document UnderstandingAutomationSuite_DU_DatamanagerODBC PYODBC
Process Mining2AutomationSuite_ProcessMining_Metadata AutomationSuite_ProcessMining_Warehouse3 AutomationSuite_Airflow 45ADO.NET PYODBC PSYCOPG2
1 The password for the Apps database must not contain #{.
2 To minimize latency issues, it is strongly recommended to deploy the Process Mining databases in the same region as the compute resource (Kubernetes cluster).
3 AutomationSuite_ProcessMining_Warehouse uses both ADO.NET and PYODBC formats.
4 AutomationSuite_Airflow PostgreSQL database use SQLAlchemy connection string format. The connection to the AutomationSuite_Airflow database can not begin with a { character.
5 AutomationSuite_Airflow Microsoft SQL Server database uses SQLAlchemy connection string format. AutomationSuite_Airflow must have READ_COMMITTED_SNAPSHOT enabled when creating databases manually. The connection to the AutomationSuite_Airflow database can not begin with a { character.
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
Note:
For Process Mining on Automation Suite 2024.10.3 or higer versions, you are recommended to use PostgreSQL for AutomationSuite_Airflow .
Important:
If you manually set the connection strings in the configuration file, you can escape SQL, JDBC, or ODBC passwords as follows:
  • for SQL: add ' at the beginning and end of the password, and double any other '.
  • for JDBC/ODBC: add { at the beginning of the password and } at the end, and double any other }.
You can also use the databases in an elastic pool for better cost-effectiveness.
SQL collation
Automation Suite supports SQL collation set to SQL_Latin1_General_CP1_CI_AS at both the server and database level. We strongly recommend this particular setup for optimum performance and stability.
While you have the flexibility to use a collation of your choice, be aware that untested configurations can potentially lead to unexpected issues.
Important:
We do not recommend using Binary SQL or any collations that are case-sensitive, as they cause known issues while installing Automation Suite.
Permissions
If you want the installer to create a database on the provided SQL server, make sure to grant at least the dbcreator role to the SQL account used to connect to the database.
If you want to create your own databases for all the products, you must grant the SQL account the db_owner role for all Automation Suite databases.
If security restrictions do not allow the use of db_owner, then the SQL account should have the following roles and permissions on all databases (the only exception is Insights which still requires db_owner).
  • db_securityadmin
  • db_ddladmin
  • db_datawriter
  • db_datareader
  • EXECUTE permission on dbo, dt, authz, and msgbus schema
We only use the db_securityadmin and db_ddladmin roles during installation or if the databases are reprovisioned, so you may revoke these permission afterwards.
SQL server ciphers
Only the listed SQL ciphers are supported in Automation Suite:
  • TLS_AES_256_GCM_SHA384
  • TLS_CHACHA20_POLY1305_SHA256
  • TLS_AES_128_GCM_SHA256
  • TLS_AES_128_CCM_SHA256
  • ECDHE-ECDSA-AES256-GCM-SHA384
  • ECDHE-RSA-AES256-GCM-SHA384
  • ECDHE-ECDSA-CHACHA20-POLY1305
  • ECDHE-RSA-CHACHA20-POLY1305
  • ECDHE-ECDSA-AES256-CCM
  • ECDHE-ECDSA-AES128-GCM-SHA256
  • ECDHE-RSA-AES128-GCM-SHA256
  • ECDHE-ECDSA-AES128-CCM
  • ECDHE-ECDSA-AES128-SHA256
  • ECDHE-RSA-AES128-SHA256
  • ECDHE-ECDSA-AES256-SHA
  • ECDHE-RSA-AES256-SHA
  • AES256-GCM-SHA384
  • AES256-CCM
  • AES128-GCM-SHA256
  • AES128-CCM
  • AES256-SHA256
  • AES128-SHA256
  • AES256-SHA
  • AES128-SHA
  • DHE-RSA-AES256-GCM-SHA384
  • DHE-RSA-CHACHA20-POLY1305
  • DHE-RSA-AES256-CCM
  • DHE-RSA-AES128-GCM-SHA256
  • DHE-RSA-AES128-CCM
  • DHE-RSA-AES256-SHA256
  • DHE-RSA-AES128-SHA256
  • PSK-AES256-GCM-SHA384
  • PSK-CHACHA20-POLY1305
  • PSK-AES256-CCM
  • PSK-AES128-GCM-SHA256
  • PSK-AES128-CCM
  • PSK-AES256-CBC-SHA
  • PSK-AES128-CBC-SHA256
  • DHE-PSK-AES256-GCM-SHA384
  • DHE-PSK-CHACHA20-POLY1305
  • DHE-PSK-AES256-CCM
  • DHE-PSK-AES128-GCM-SHA256
  • DHE-PSK-AES128-CCM
  • DHE-PSK-AES256-CBC-SHA
  • DHE-PSK-AES128-CBC-SHA256
  • ECDHE-PSK-CHACHA20-POLY1305
  • ECDHE-PSK-AES256-CBC-SHA
  • ECDHE-PSK-AES128-CBC-SHA256
  • RSA-PSK-AES256-GCM-SHA384
  • RSA-PSK-CHACHA20-POLY1305
  • RSA-PSK-AES128-GCM-SHA256
  • RSA-PSK-AES256-CBC-SHA
  • RSA-PSK-AES128-CBC-SHA256
Document Understanding requires the SQL Server to have the Full-Text Search component of the SQL Server Database Engine, which is not always installed by default.
If you did not select Full-Text Search when you installed SQL Server, run SQL Server Setup again to add it before configuring Document Understanding.
For more info, check this guide on how to add/install features on SQL server. You can also find a full list of SQL Server components, which includes Full-Text Search.
SQL requirements for Insights
Note:
Insights does not support Azure AD authentication. If you authenticate using Azure AD, dashboards cannot be loaded and data cannot be fetched from the Microsoft SQL database.
Insights requires SQL Server 2019 or 2022, including support for columnstore index and .json functions. SQL Server Enterprise is recommended due to more efficient threading and scalability.
For Azure SQL, ensure the database is S3 service objective or higher.
Make sure the compatibility level for Insights database is set to 130 or higher. In most cases, the default settings meet this requirement. For more info, refer to View or Change the Compatibility level of a Database - SQL Server.
The installation validates both conditions and alerts you if minimum requirements are not met.
SQL requirements for Data Service
Data Service requires SQL Server version 2016 or higher.
If you create your own database using SQL Server version 2019 or higher, make sure to grant the following Data Service permissions to your users:
GRANT ALTER ANY SENSITIVITY CLASSIFICATION TO {userName};
GRANT VIEW ANY SENSITIVITY CLASSIFICATION TO {userName};
SQL requirements for Process Mining
Important:
Due to a known issue, you cannot use a custom database name for the Platform database if Process Mining is enabled. If you specify a custom name, the OMS backfill job fails.
To avoid this, use AutomationSuite_Platform as the Platform database name when installing Process Mining.
When you enable Process Mining for installation on Automation Suite 2024.10.3 or higher you can choose to bring either a PostgreSQL database or a Microsoft SQL Server database for AutomationSuite_Airflow.
Important:
For Process Mining on Automation Suite 2024.10.3 or higher versions, you are recommended to move to PostgreSQL for the AutomationSuite_Airflow database, as PostgreSQL runs with the latest versions of Apache Airflow. Running the latest version of Airflow ensures you make use of new functionality, performance, and security fixes.
If you choose not to use a PostgreSQL database and keep using a Microsoft SQLServer database, Process Mining on Automation Suite will run with legacy Airflow. Legacy versions of Apache Airflow may lack functionality, performance, and security fixes.
Starting with Process Mining on Automation Suite 2025.10 only PostgreSQL database is supported for the AutomationSuite_Airflow database.
For Process Mining on Automation Suite 2024.10.3 or higher versions, you can choose to use a PostgreSQL database for the AutomationSuite_Airflow database.
Note:
Before installing or upgrading to Automation Suite 2024.10.3 or higher, you need to manually create the PostgreSQL database for AutomationSuite_Airflow. The PostgreSQL database for Airflow will not be created automatically by the installer.
When migrating from Microsoft SQL Server to PostgreSQL database, data migration is not required. With a correct configuration setup, the database is rebuilt when running Sync Airflow.
Supported PostgreSQL versions
PostgreSQL versions 12.x to 16.x are supported. It is recommended to use the most recent version of PostgreSQL within this range for optimal compatibility and performance.
Hardware requirements
The machine on which the PostgreSQL database for Airflow is installed must meet the following harware requirements.
  • Cores: 4
  • Memory: 16 GiB
  • Storage: 64 GiB
  • IOPS: >=500 IOPS
Required permissions
The PostgreSQL Airflow user (or any dedicated database user) must have
  • "All Privileges" permissions for the designated Airflow database.
  • "all grants" on the server's public schema.
  • "search_path" set to "public".
Note:
You may need to update PostgreSQL Host-Based Authentication file pg_hba.conf to add the Airflow user to the database access control list and reload the database configuration to apply the changes.
The following code shows an example for setting up a PostgreSQL database.
CREATE DATABASE airflow_db
  WITH ENCODING 'UTF8'
  LC_COLLATE='en_US.UTF-8'
  LC_CTYPE='en_US.UTF-8'
  TEMPLATE template0;
CREATE USER airflow_user WITH PASSWORD 'airflow_pass';
GRANT ALL PRIVILEGES ON DATABASE airflow_db TO airflow_user;
-- PostgreSQL 15 requires additional privileges:
GRANT ALL ON SCHEMA public TO airflow_user;
  TEMPLATE template0;
The following code shows a database encoding validation example.
SELECT pg_encoding_to_char(encoding) AS encoding
FROM pg_database
WHERE datname = 'airflow_db';
FROM pg_database
Refer to the official Airflow documentation for more information on how to set up a PostgreSQL database for Airflow.
Default server port
The default server port for Airflow database connections with PostgreSQL is 5432. If you are using the PgBouncer connection pooler, it is common to use port 6432.
The following code blocks show some example connection strings for PostgreSQL using port 5432.
Sample connection string:
postgresql+psycopg2://testadmin:<password>@test-cu231009v3-postgresql.postgres.database.azure.com:5432/automationsuite_airflow
Sample connection string for using Kerberos:
postgresql+psycopg2://kerberos_user:@kerberospostgres.AUTOSUITEAD.LOCAL:5432/automationsuite_airflow
Sample connection string for using Managed Identitiy:
postgresql+psycopg2://testmanagedidentity:@test-postgresql-1.postgres.database.azure.com/airflow-ci-sfasaksqacu8524745
The default server port can be configured to use any available port as per your system requirements.
PgBouncer
Since Airflow uses short-lived connections, it is highly recommended to set up PgBouncer. PgBouncer is a lightweight connection pooler for PostgreSQL.
Refer to the official PgBouncer documentation for more information on how to set up PgBouncer.
Note:
For the AutomationSuite_Airflow database, Microsoft SQL Server is the only option available for Process Mining on Automation Suite versions 2024.10.2 and earlier. For Process Mining on Automation Suite 2024.10.3 or higher versions, you are recommended to move to PostgreSQL.
If you use Microsoft SQL Server for AutomationSuite_Airflow database, make sure you meet the following requirements.
Important:
You must use the default server port 1433 for Airflow database connections.
Non-standard SQL Server ports are not supported.
Note:
When setting up Microsoft SQL Server make sure that the timezone of the SQL Server machine where the Airflow database is installed, is set to UTC.
AutomationSuite_ProcessMining_Warehouse database
Process Mining on Automation Suite requires a separate Microsoft SQL Server for the AutomationSuite_ProcessMining_Warehouse for data storage for Process Mining process apps.
Important:
To ensure proper functioning of Process Mining, it is recommended to use Microsoft SQL Server 2022.
This is an overview of hardware requirements and recommendations for setting up a Microsoft SQL Server database machine for AutomationSuite_ProcessMining_Warehouse.
To calculate the hardware requirements, you need to have an indication of:
  • the number of (million) events in your process.
  • the number of case and event fields in your output data. In a development environment, for performance reasons, it is recommended to work on a small development dataset with a limited number of records.
You can use the UiPath Automation Suite Install Sizing Calculator to determine the hardware requirements for setting up a dedicated Microsoft SQL Server machine for Process Mining. When you add Process Mining to the Product section, the minimum requirements for 1 Dedicated SQL Server are displayed.
Refer to Hardware requirements for more informations.
The SQL user used in the connection strings must have the db_securityadmin database-level role both during and post-installation to enable per app security on the Process Mining data warehouse SQL Server. For details, refer to the official Microsoft documentation on Database-level roles and Configuring process app security.
Note:
It is recommended to enable case sensitivity in table and column names using the following command:
ALTER DATABASE AutomationSuite_ProcessMining_Warehouse COLLATE SQL_Latin1_General_CP1_CS_AS
This prevents errors when loading data caused by columns with similar names, such as ID and id. It also ensures that textual values differing only in capitalization are treated as distinct. For example:
  • 'activity 1' == 'activity 1'
  • 'Activity 1' != 'activity 1'
This prevents duplication issues in SQL transformations.
SQL requirements for AI Center
Requirements for AI Center connected to an external Orchestrator
If you install an AI Center that connects to an external Orchestrator, you must ensure you create a new database named AutomationSuite_Platform for AI Events and AI Storage services.
Important:
Currently, AI Center requires SQL Server version 2019 and higher to function optimally.
Requirements for AI Center installed on a FIPS 140-2-enabled machine
To install AI Center on a FIPS 140-2-enabled machine, take the following steps:
  1. Before starting the Automation Suite installation, take the following steps:
    1. Enable FIPS 140-2 on the machine on which you plan to install Microsoft Server by following the Microsoft instructions.
    2. Install Microsoft SQL Server on the FIPS 140-2-enabled machine.
    3. Get the Microsoft SQL Server certificate by running the following command from the SQL Server or any server that can connect to the SQL server with the configured SQL host name:
      nmap -sV -p <port> -vv --script ssl-cert domain
  2. During the Automation Suite installation, take the following steps:
    1. Append the following values to the AI Center sql_connection_string_template_jdbc connection string in the cluster_config.json file: encrypt=true;trustServerCertificate=false;fips=true;.
      Example:
      jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;fips=true;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
      For details on database configuration, refer to Advanced installation experience and Updating the SQL database.
    2. Add the exported cert from step 1.c. to the trust store of the host machine. For details refer to Updating the CA Certificates.
SQL requirements for HA
For a high-availability configuration of your SQL Server, select an Always On availability group. For more info, refer to Overview of Always On availability groups.
SQL requirements for Orchestrator
Important:
To increase performance, avoid deadlocks, and prevent dirty reads in SQL, make sure that the READ_COMMITTED_SNAPSHOT option is set to ON.
To process the same queue with multiple robots, and snapshot isolation is turned on, make sure that the ALLOW_SNAPSHOT_ISOLATION option is set to ON.
Use this query to check if READ_COMMITTED_SNAPSHOT and ALLOW_SNAPSHOT_ISOLATION are enabled or disabled:
SELECT is_read_committed_snapshot_on, snapshot_isolation_state FROM sys.databases
   WHERE name like 'PLACEHOLDER'
Make sure to replace PLACEHOLDER with your Orchestrator database name.
If the settings are enabled, the returned value will be 1.
If the settings are disabled, the returned value will be 0. Use this query to enable it:
# To enable READ_COMMITTED_SNAPSHOT
ALTER DATABASE <PLACEHOLDER>
SET READ_COMMITTED_SNAPSHOT ON
# To enable ALLOW_SNAPSHOT_ISOLATION
SET ALLOW_SNAPSHOT_ISOLATION ON
Make sure to replace <PLACEHOLDER> with your Orchestrator database name.
If you use different databases for Test Automation and/or Update Server, READ_COMMITTED_SNAPSHOT and ALLOW_SNAPSHOT_ISOLATION must be enabled on those as well.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
