Automation Suite on Linux Installation Guide
Last updated Jan 22, 2025
Sample Azure infrastructure setup
The following table lists the steps you need to take to configure the infrastructure in Azure for both single-node evaluation and multi-node HA-ready production profiles.
Step
Instructions
Single-node evaluation profile
Multi-node HA-ready production profile
Required during installation
Step 1: Configure a VM node
<details>:
Basics; Configure Disks; Networking
Configure the DNS of the VM; Partitioning the disk; Additional networking configuration for multi-node
Configure one node
Configure a minimum of 3 nodes.
  • Follow additional instructions specific to multi-node.
  • Username and password used when creating the VM.
  • FQDN of the first VM.
  • For the single-node evaluation profile, provide this FQDN as the Cluster FQDN.
N/A
Required
  • FQDN of the load balancer.
  • For multi-node, provide this FQDN as the Cluster FQDN.
Required
Required
  • SQL Server FQDN and SQL Server credentials.
You must create an Azure storage account if you opt for external objectstore.
For production deployments:
For test or evaluation deployments:
Required
Required
Step 6: Install Automation Suite
At this point, configuration is complete, and you can install Automation Suite. For details, refer to Manual: Performing the installation.
