- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Applying a patch
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining
- Task Mining troubleshooting
- Exploring Logs
Automation Suite on Linux Installation Guide
Automation Suite allows you to bring your own external storage provider. You can choose from the following storage providers:
- Azure
- AWS
- S3-compatible
You can configure the external object storage in one of the following ways:
- during installation;
- post-installation, using the
file.cluster_config.json
- For Automation Suite to function properly when using pre-signed URLs, you must make sure that your external objectstore is accessible from the Automation Suite cluster, browsers, and all your machines, including workstations and robot machines.
The Server Side Encryption with Key Management Service (SSE-KMS) can only be enabled on the Automation Suite buckets deployed in any region created after January 30, 2014.
SSE-KMS functionality requires pure SignV4 APIs. Regions created before January 30, 2014 do not use pure SignV4 APIs due to backward compatibility with SignV2. Therefore, SSE-KMS is only functional in regions that use SignV4 for communication. To find out when the various regions were provisioned, refer to the AWS documentation.
cluster_config.json
parameters you can use to configure each provider of external object storage:
Parameter |
Azure |
AWS |
S3-compatible |
Description |
Specify whether you would like to bring your own object store. Possible values:
true and false .
Specify whether you would like to provision the bucket. Possible values:
true and false .
Specify the storage provider you would like to configure. The value is case-sensitive. Possible values:
azure and s3 .
Note: Many S3 objectstores require the CORS set to all the traffic from the Automation Suite cluster. You must configure the CORS
policy at the objectstore level to allow the FQDN of the cluster.
Specify the FQDN of the S3 server. Required in the case of AWS instance and non-instance profile. |
Specify the S3 port. Required in the case of AWS instance and non-instance profile. |
Specify the AWS region where buckets are hosted. Required in the case of AWS instance and non-instance profile. |
Specify the access key for the S3 account. Only required in the case of the AWS non-instance profile. |
Specify the secret key for the S3 account. Only required in the case of the AWS non-instance profile. |
Specify whether you want to use an instance profile. An AWS Identity and Access Management (IAM) instance profile grants secure access to AWS resources for applications or services running on Amazon Elastic Compute Cloud (EC2) instances. If you opt for AWS S3, an instance profile allows an EC2 instance to interact with S3 buckets without the need for explicit AWS credentials (such as access keys) to be stored on the instance. |
Use managed identity with your Azure storage account. Possible values:
true and false .
external_object_storage.bucket_name_prefix 1 |
Indicate the prefix for the bucket names. Optional in the case of the AWS non-instance profile. |
external_object_storage.bucket_name_suffix 2 |
Indicate the suffix for the bucket names. Optional in the case of the AWS non-instance profile. |
Specify the Azure account key. Only required when using non-managed identity. |
Specify the Azure account name. |
Specify the Azure FQDN suffix. Optional parameter. |
Specify your Azure client ID. Only required when using managed identity. |
1 If you plan on disabling pre-signed URL access, note that this configuration is not supported by Task Mining and the following activities that upload or retrieve data from the objectstore:
bucket_name_prefix
and bucket_name_suffix
. In addition to that, the suffix and prefix must have a combined length of no more than 25 characters, and you must not end
the prefix or start the suffix with a hyphen (-
) as we already add the character for you automatically.
You can use the parameters described in the General configuration section to update the general Automation Suite configuration. This means that all installed products would share the same configuration. If you want to configure one or more products differently, you can override the general configuration. You just need to specify the product(s) you want to set up external object storage for differently, and use the same parameters to define your configuration. Note that all the other installed products would continue to inherit the general configuration.
The following example shows how you can override the general configuration for Orchestrator:
"external_object_storage": {
"enabled": false, // <true/false>
"create_bucket": true, // <true/false>
"storage_type": "s3", // <s3,azure,aws>
"fqdn": "", // <needed in the case of aws instance and non-instance profile>
"port": 443, // <needed in the case of aws instance and non-instance profile>
"region": "",
"access_key": "", // <needed in the case of aws non instance profile>
"secret_key": "", // <needed in the case of aws non instance profile>
"use_managed_identity": false, // <true/false>
"bucket_name_prefix": "",
"bucket_name_suffix": "",
"account_key": "", // <needed only when using non managed identity>
"account_name": "",
"azure_fqdn_suffix": "core.windows.net",
"client_id": "" // <optional field in case of managed identity>
"orchestrator": {
"storage_type": "s3", // <s3,azure>
"region": "",
"access_key": "", // <needed in case of aws non instance profile>
"secret_key": "", // <needed in case of aws non instance profile>
"account_name": "",
"region": "",
"account_name": "",
"orchestrator": {
"region": "",
"account_name": "",
To rotate the blob storage credentials for Process Mining in Automation Suite the stored secrets must be updated with the new credentials. See Rotating blob storage credentials.
create_bucket
parameter is set to false
, you must ensure the bucket_name
value you use for Insights is the same as the one for Platform. If create_bucket
is set to true
, no action is required from your side.
"insights": {
"enabled": true,
"bucket_name": "<same_as_platform_bucket_name"
"insights": {
"enabled": true,
