- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Out-of-sync Task Mining
- Cleaning up the Task Mining database
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Antivirus causes installation and operation issues
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
Maintenance tasks and schema details for the Task Mining database in Automation Suite, including data storage and cleanup procedures.
This page describes the necessary maintenance tasks for the Task Mining databases.
The default Task Mining database, named [AutomationSuite_Task_Mining], uses a single schema [tddiscovery] for data storage. Primarily, Task Mining stores data in the object store, reducing the need of frequent database maintenance. If required, you can use the Remove_Active_History.sql database maintenance script to periodically clean up the following database table:
[AutomationSuite_Task_Mining].[tddiscovery].[ActivityHistory]Important:Ensure to back up the Task Mining database
[AutomationSuite_Task_Mining]before executing any scripts.
Prerequisites
The following prerequisites are assumed:
- You have access to the
[AutomationSuite_Task_Mining]database with the required permissions.
Remove_Active_History.sql script
CREATE PROCEDURE [tddiscovery].[Delete_TaskMining_ActivityHistory]
@CutoffTimeStamp datetime2,
@BatchSize INT = 10000
AS
BEGIN
DECLARE @total_deleted_items BIGINT = 0;
SET NOCOUNT ON;
-- delete ActivityHistoryItems
DECLARE @Deleted_Rows_ActivityHistoryItems INT = @BatchSize;
WHILE(@Deleted_Rows_ActivityHistoryItems = @BatchSize)
BEGIN
DELETE TOP(@BatchSize) FROM [tddiscovery].[ActivityHistory] WHERE At <= @CutoffTimeStamp;
SET @Deleted_Rows_ActivityHistoryItems = @@ROWCOUNT;
SET @total_deleted_items = @Deleted_Rows_ActivityHistoryItems + @total_deleted_items;
END;
PRINT('The script executed successfully!');
PRINT('Total deleted rows from [tddiscovery].[ActivityHistory]: ' + CONVERT(NVARCHAR, @total_deleted_items));
END;
GO
AS
BEGIN
SET NOCOUNT ON;
BEGIN
END;
END;
GO
Steps
Run the
Remove_Active_History.sqldatabase maintenance script to create theDelete_TaskMining_ActivityHistoryStored Procedure.Note:Always use the most recent version of the Stored Procedure.
It is strongly recommended to archive previously executed SQL Stored Procedures by renaming the Stored Procedures. This provides an opportunity to detect and address any potential issues or anomalies within that particular version of the SQL Stored Procedure. The following code provides an example on how to rename a SQL Stored Procedure for archiving purposes.
EXEC sp_rename '[tddiscovery].[Delete_TaskMining_ActivityHistory]', '[Delete_TaskMining_ActivityHistory_2024-10-10_001]';EXEC sp_rename '[tddiscovery].[Delete_TaskMining_ActivityHistory]', '[Delete_TaskMining_ActivityHistory_2024-10-10_001]'; -
Execute the
Delete_TaskMining_ActivityHistoryStored Procedure. This deletes all data related to Activity History for a cut-off timestamp from the[AutomationSuite_Task_Mining].[tddiscovery].[ActivityHistory]table.
SQL Stored Procedure: Delete active history
Before executing the PROCEDURE [tddiscovery].[Delete_TaskMining_ActivityHistory] script, ensure that Task Mining usage is suspended.
Although there is no restriction on deleting data using a SQL Stored Procedure, it would be a good practice to retain the activity history in the system for a minimum period, for example, 30 days, to preserve recent activity records. This also provides an opportunity to detect and address any potential issues or anomalies within the SQL Stored Procedure before it is permanently deleted.
The following table describes the parameters for the Delete_TaskMining_ActivityHistory SQL Stored Procedure.
| Parameter | Description | Mandatory Y/N |
@CutoffTimeStamp | Delete all data before a specified timestamp (e.g., 2021-01-01 01:00:05 ).
Do not provide a timestamp that leads to an empty table. | Y |
@BatchSize INT = 10000 | The number of rows to be deleted at a time. This enables you to delete the data batch by batch. | N |
The following code provides an example of how to run the Stored Procedure.
DECLARE @ProcessTime datetime2;
SET @ProcessTime = '2024-07-11 13:44:42.7856026';
EXEC [tddiscovery].[Delete_TaskMining_ActivityHistory] @CutoffTimeStamp = @ProcessTime;
For more information, see the official Microsoft documentation on Stored procedures.
