- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure on RHEL 8.x nodes
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
Replace self-signed certificates with CA-signed certificates after installation to maintain security in Automation Suite.
The installation process generates self-signed certificates on your behalf. These certificates are FIPS-compliant and will expire in 90 days. You must replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes. If you do not update the certificates, the installation will stop working in 90 days.
If you installed Automation Suite on a FIPS-enabled host and want to update the certificates, make sure they are FIPS-compliant.
The installation bundle provides a cluster management tool that enables you to update certificates post-installation. To access the tool, navigate to the location of the installer bundle:
cd /opt/UiPathAutomationSuite/
Generating a Certificate Signing Request (CSR) and a private key
To generate the CSR and the private key, run the following command:
# copy the machine openssl configuration locally
cp /etc/pki/tls/openssl.cnf ./openssl.tmp.cnf
# Replace the [AUTOMATION_SUITE_FQDN] value. For example, "automationsuite.corp.com"
AS_FQDN=[AUTOMATION_SUITE_FQDN]
cat >> ./openssl.tmp.cnf <<EOF
[SAN]
subjectAltName=DNS:$AS_FQDN,DNS:alm.$AS_FQDN,DNS:monitoring.$AS_FQDN,DNS:registry.$AS_FQDN,DNS:objectstore.$AS_FQDN,DNS:insights.$AS_FQDN,DNS:apps.$AS_FQDN
EOF
# create the certificate request
openssl req -new -sha256 -newkey rsa:2048 -nodes -keyout server.key -subj "/C=xx/ST=xx/O=xx/OU=xx/CN=$AS_FQDN" -reqexts SAN -config openssl.tmp.cnf -out ${AS_FQDN}.csr
[SAN]
EOF
Your IT team uses the obtained values to generate a signed certificate. The generated private key remains local.
Managing server certificates
To view more information about server certificates, run the following command:
./bin/uipathctl config tls-certificates --help
Output:
Manage tls certificates
Usage:
uipathctl config tls-certificates [flags]
uipathctl config tls-certificates [command]
Available Commands:
get Get the current tls certificates
update Update tls certificates
Flags:
-h, --help help for tls-certificates
Global Flags:
-q, --quiet disable progress indicators (emoji/formatted status messages)
Use "uipathctl config tls-certificates [command] --help" for more information about a command.
Usage:
Available Commands:
Flags:
Global Flags:
The following sections describe the operations you can perform using the uipathctl config tls-certificates command.
Updating the server certificate
Online installation: How to find the server certificate
Certificates are stored as a secret at the Istio level. You can find certificates under the istio-ingressgateway-certs name in the istio-system namespace.
See the certificate files in the following list:
- Server TLS certificate is stored as
tls.crt - Server TLS private key as
tls.key - CA bundle is stored as
ca.crt
You can verify the secrets using the following command:
kubectl -n istio-system get secrets istio-ingressgateway-certs -o yaml
Certificates are also stored in the UiPath namespace. This is applicable to every UiPath® product that needs certificate information to trust incoming calls. For details, refer to Understanding the container architecture related to certificates.
Offline installation: How to find the server certificate
In addition to the certificates required by online deployment, an offline deployment has two additional locations that use the same rootCA.crt and tls.crt: ArgoCD and Docker Registry. Certificates are then stored in both Docker and ArgoCD namespaces.
# For docker registry
kubectl -n docker-registry get secrets docker-registry-tls -o yaml
# For Argocd
argocd login alm.cluster_fqnd --username argocd_username --password argocd_password
argocd cert list --cert-type https
# For Argocd
How to update server certificates
You must decrypt the certificate key before updating the server certificate. Skipping the decryption step would result in an error.
To decrypt the certificate key, run the following command:
# replace /path/to/encrypted/cert/key to absolute file path of key
# replace /path/to/decrypt/cert/key to store decrypt key
# Once prompted, please entry the passphrase or password to decrypt the key
openssl rsa -in /path/to/encrypted/cert/key -out /path/to/decrypt/cert/key
How the certificate chain is assembled
When you run the uipathctl config tls-certificates update command, uipathctl assembles the full certificate chain from two separate input files:
server.crt- the complete public server certificate chain in PEM format: the leaf server certificate, followed by the intermediate CA certificate(s), and the root CA that form the signing path for that leaf certificate. Include only certificates that are part of the leaf certificate's actual signing chain — do not include sibling, unrelated, duplicate, or alternate CA certificates.ca.crt- the complete CA chain, including all intermediate certificates and the root CA. The file must contain only the certificates used to sign the TLS server certificate. Including anything else will lead to failure.
uipathctl merges these files at runtime.
To update the certificate, provide the path to each of the three certificate files. All certificate files must be in pem format.
- Certificate Authority Bundle - The complete CA chain used to sign the TLS server certificate. Include all intermediate certificates and the root CA. Do not include the leaf certificate or any other certificates not used to sign the TLS server certificate, as including anything else will lead to failure. The chain limit is up to nine certificates.
- Server Certificate - The complete public server certificate chain in PEM format, starting with the leaf server certificate, followed by the intermediate CA certificate(s), and root CA. Include only the certificates that form the leaf certificate's actual signing chain.
- Private key - Private key for the server certificate.
./bin/uipathctl config tls-certificates update --cert server.crt --cacert ca.crt --key server.key
For troubleshooting TLS certificate validation errors, refer to TLS certificate validation errors.
The following files are stored in the /directory/path/to/store/certificate location.
Accessing the TLS certificate
To print out the certificate files, run the following command, specifying the directory where certificates are stored.
./bin/uipathctl config tls-certificates get --show-details
Adding the CA certificate to the host trust store
You are responsible for making sure the generated certificates are trusted.
This step is required when your environment uses a private CA or self-signed certificate that is not globally trusted. If the private CA is not already present in the Linux host trust store, calls originating from the host nodes fail with SSL errors. If your CA is already trusted by the host, you can skip this step.
To add the certificate to the host VM trust store, run the following commands on all the nodes in the cluster:
# 1. Copy the certificate file to the /usr/share/pki/ca-trust-source/anchors/ or the /etc/pki/ca-trust/source/anchors/ directory
cp /path/to/the/ca-cert /usr/share/pki/ca-trust-source/anchors/
# 2. Update the trust store configuration
update-ca-trust
update-ca-trust
Managing additional CA certificates
To view more information about additional CA certificates, run the following command:
./bin/uipathctl config additional-ca-certificates --help
Output:
Manage additional ca certificates
Usage:
uipathctl config additional-ca-certificates [flags]
uipathctl config additional-ca-certificates [command]
Available Commands:
get Get the current additional ca certificates
update Update additional ca certificates
Flags:
-h, --help help for additional-ca-certificates
Global Flags:
Use "uipathctl config additional-ca-certificates [command] --help" for more information about a command.
Usage:
Available Commands:
Flags:
Global Flags:
The following sections describe the operations you can perform using the uipathctl config additional-ca-certificates command.
Updating the CA certificates
Use this command when your environment relies on a private CA or self-signed certificate. Adding the CA certificate lets Automation Suite services communicate securely with external components that use certificates signed by that CA, such as SQL Server, objectstore, or SMTP servers.
To update the CA certificates, take the following steps:
Update the
cluster_config.jsonfile to point to the file withadditional_ca_certs. For more details about this parameter, refer to Certificate configuration. -
Apply the manifest:
./bin/uipathctl manifest apply cluster_config.json --versions versions.json./bin/uipathctl manifest apply cluster_config.json --versions versions.jsonThis command may fail with errors such as:
Error: [failed to wait for application argocd/<app-name1>: timed out waiting for the condition, failed to wait for application argocd/<app-name2>: timed out waiting for the condition]]Error: [failed to wait for application argocd/<app-name1>: timed out waiting for the condition, failed to wait for application argocd/<app-name2>: timed out waiting for the condition]]Irrespective of the failure, proceed to step 3 to restart deployments and stabilize the environment.
Manually restart all deployments and stateful sets in the
uipathnamespace:kubectl rollout restart deployment -n <uipath> kubectl rollout restart sts -n <uipath>kubectl rollout restart deployment -n <uipath> kubectl rollout restart sts -n <uipath>
To append the old certificates, you must use the get command from the Accessing the CA certificates section and append them in the CA certificate .pem file that you must provide in the additional_ca_certs field.
The CA Certificate bundle file should be a valid .pem format and can have more than one certificate present in it.
To download the already configured CA certificates, run the following command:
./bin/uipathctl config additional-ca-certificates get
update-ca-trust
update-ca-trust
For Windows environments, refer to this guide to install trusted root certificates.
Managing identity token-signing certificates
Automation Suite offers two methods to manage the rotation of identity token-signing certificates: automatic and manual.
To view more information about identity token-signing certificates, run the following command:
./bin/uipathctl config token-signing-certificates --help
Output:
Manage token signing certificates
Usage:
uipathctl config token-signing-certificates [flags]
uipathctl config token-signing-certificates [command]
Available Commands:
automatic-key-management Manage key management
get Get the current token signing certificate
rotate Rotate token signing certificates
update Update future token signing certificate
Flags:
-h, --help help for token-signing-certificates
Global Flags:
Use "uipathctl config token-signing-certificates [command] --help" for more information about a command.
Usage:
Available Commands:
Flags:
Global Flags:
You can use a maximum key length of 4096 bits for signing certificates. We highly recommend you to use a key length of at least 512 bits (64 bytes) as a best practice.
The following section provide details on the operations you can perform using the uipathctl config token-signing-certificates command.
Automatic certificate rotation
Automatic certificate rotation means Automation Suite manages the lifecycle of signing keys. This includes rotating keys every 90 days, announcing new keys 14 days prior to rotation, retaining old keys for 14 days post-rotation, and then deleting them when the 14-day period ends.
If you're upgrading from an older version to 2024.10, automatic certificate rotation is disabled by default. To enable automatic key management, run the following command:
uipathctl config token-signing-certificates automatic-key-management enable
Enabling automatic certificate rotation may result in a downtime of up to one hour.
Automatic certificate rotation is enabled by default for clean Automation Suite installations. To disable automatic key management, run the following command:
uipathctl config token-signing-certificates automatic-key-management disable
If the automatic management feature is disabled, signing certificates need to be updated and rotated manually. For details on manual key management, see the documentation on manually updating and rotating the certificate.
Manually updating the certificate
The following command does not replace the existing token signing certificate.
Make sure the certificate you provide is in .pem format. The server.crt file must contain the entire chain, as shown in the following example:
-----server cert-----
-----root ca chain-----
To upload the new certificate to sign the token, run the following command:
./bin/uipathctl config token-signing-certificates update --cert server.crt --key server.key
Manually rotating the certificate
To rotate or replace the old certificate with the new one, run the following command:
./bin/uipathctl config token-signing-certificates rotate
There should be the lead time of about 24 - 48 hours between certificate update and rotate.
We need this lead time to keep supporting the authentication for cached token signed by old certificate.
If you rotate the certificate too soon before the expiry of cache token can result in downtime. And you may have to restart all your robots.
Emergency certificate rotation
The following procedure is for emergencies only. You should rotate certificates ahead of their expiration dates
To perform an emergency certificate update, take the following steps:
Obtain a new certificate or create a self-signed one and copy it to the cluster server node used to execute the next rotation steps. To create a new self-signed certificate, run the following command:
openssl req -x509 -sha256 -nodes -days 365 -newkey rsa:2048 -keyout identityserver.key -out identityserver.crt openssl pkcs12 -export -out identityserver.pfx -inkey identityserver.key -in identityserver.crtopenssl req -x509 -sha256 -nodes -days 365 -newkey rsa:2048 -keyout identityserver.key -out identityserver.crt openssl pkcs12 -export -out identityserver.pfx -inkey identityserver.key -in identityserver.crt -
If
IdentityServer1.pfxis expired, rotate and update the certificate. For instructions, refer to Rotating the certificate. -
If
IdentityServer2.pfxis expired, update the certificate. -
If both certificates are expired, update, rotate and update again.
Restart all deployments. For instructions, refer to Troubleshooting.
Clear all browser caches. If you run in Incognito or Private mode, you can skip this step.
For Firefox, press CTRL+SHIFT+DEL, select Cache, and select OK.
For Chrome, press CTRL+SHIFT+DEL, select Cached images and files, and select Clear data.
Accessing the certificate
Run the following command to download the current token signing certificate:
./bin/uipathctl config token-signing-certificates get --show-details
Managing RKE2 certificates
By default, RKE2 certificates expire in 12 months. In the 90 days prior to their expiration date, certificates are rotated when you restart RKE2.
For more details, refer to RKE2 - Advanced Options - Certificate rotation.
Checking the RKE2 certificate expiration date
To check the expiration date of the RKE2 certificate, run the following command on any of the nodes:
if [[ -d "/var/lib/rancher/rke2/server/tls" ]]; then
dir="/var/lib/rancher/rke2/server/tls"
elif [[ -d "/var/lib/rancher/rke2/agent/tls" ]]; then
dir="/var/lib/rancher/rke2/agent/tls"
else
dir="/var/lib/rancher/rke2/agent/"
fi
# Loop through each .crt file in the directory
for file in "$dir"/*.crt; do
# Extract the expiry date from the certificate
expiry=$(openssl x509 -enddate -noout -in "$file" | cut -d= -f 2-)
# Get the file name without the path
filename=$(basename "$file")
# Print the filename and expiry date in a pretty format
printf "%-30s %s\n" "$filename:" "$expiry"
done
else
fi
done
The output you get should be similar to the one shown in the following image:
Rotating the RKE2 certificate
By default, RKE2 certificates expire in 12 months. In the 90 days prior to their expiration date, certificates are rotated when you restart RKE2. However, if the validity of the certificates exceeds the 90-day period, you must manually rotate the certificates by following the steps mentioned in RKE2 - Advanced Options - Certificate rotation.
If you want to customize the expiration period of RKE2 certificates to meet particular requirements, you can do so before restarting the RKE2 services for both server and agent nodes.
To rotate the RKE2 certificates, you must first execute a series of action on the server nodes, then proceed with some steps on the agent nodes.
Take the following steps on the server nodes:
Stop the RKE2 server:
systemctl stop rke2-server.servicesystemctl stop rke2-server.service -
Clear any remaining RKE2 processes:
rke2-killall.shrke2-killall.sh -
Delete the
dynamic-cert.jsonfile located at/var/lib/rancher/rke2/server/tls/. -
To customize the expiration period of the RKE2 certificates, use the following command. Be aware that this example sets the validity period to 1000 days, but you can change this value based on your requirements.
SERVICE_NAME="rke2-server.service" conf_file_path="/etc/systemd/system/${SERVICE_NAME}.d/cert.conf" mkdir -p /etc/systemd/system/"${SERVICE_NAME}".d/ cat > "$conf_file_path" <<EOF [Service] Environment="CATTLE_NEW_SIGNED_CERT_EXPIRATION_DAYS=1000" EOF systemctl daemon-reloadSERVICE_NAME="rke2-server.service" conf_file_path="/etc/systemd/system/${SERVICE_NAME}.d/cert.conf" mkdir -p /etc/systemd/system/"${SERVICE_NAME}".d/ cat > "$conf_file_path" <<EOF [Service] Environment="CATTLE_NEW_SIGNED_CERT_EXPIRATION_DAYS=1000" EOF systemctl daemon-reload -
Restart the RKE2 server:
systemctl start rke2-server.servicesystemctl start rke2-server.serviceNote:If the cluster has more than one server node, steps 1-4 might not wholly execute as etcd may be unable to complete the leader election. Should this happen, repeat steps from 1-4 on other server nodes.
Delete the
rke2-servingsecret from thekube-systemnamespace:kubectl delete secret -n kube-system rke2-servingkubectl delete secret -n kube-system rke2-servingNote:In a multi-node deployment, you may not be able to run the
kubectlcommands until you have completed the first four operations on the necessary number of server nodes. This is to fulfill the etcd quorum requirement. You can remove therke2-servingsecret immediately after the RKE2 server starts up.
Once etcd attains quorum, the RKE2 server can start the rest of the control plane pods. You should then see the successful execution of the kubectl get nodes command. When your server nodes are ready, you can proceed to the agent nodes to regenerate the certificates.
Take the following steps on the agent nodes:
systemctl stop rke2-agent.servicesystemctl stop rke2-agent.service -
SERVICE_NAME="rke2-agent.service" conf_file_path="/etc/systemd/system/${SERVICE_NAME}.d/cert.conf" mkdir -p /etc/systemd/system/"${SERVICE_NAME}".d/ cat > "$conf_file_path" <<EOF [Service] Environment="CATTLE_NEW_SIGNED_CERT_EXPIRATION_DAYS=1000" EOF systemctl daemon-reloadSERVICE_NAME="rke2-agent.service" conf_file_path="/etc/systemd/system/${SERVICE_NAME}.d/cert.conf" mkdir -p /etc/systemd/system/"${SERVICE_NAME}".d/ cat > "$conf_file_path" <<EOF [Service] Environment="CATTLE_NEW_SIGNED_CERT_EXPIRATION_DAYS=1000" EOF systemctl daemon-reload -
systemctl start rke2-agent.servicesystemctl start rke2-agent.service
Managing the external OCI-compliant registry certificate
To update the certificate for the external OCI-compliant registry post-installation, take the following steps:
Update the
registry_ca_certflag in thecluster_config.jsonfile. For details, refer to External OCI-compliant registry configuration. -
Update the root CA used by the external OCI-compliant registry by running the following command on all the nodes:
./bin/uipathctl rke2 generate-registries cluster_config.json --current-config-path /etc/rancher/rke2/registries.yaml > /etc/rancher/rke2/registries.yaml.tmp mv -f /etc/rancher/rke2/registries.yaml.tmp /etc/rancher/rke2/registries.yaml systemctl restart rke2-server || systemctl restart rke2-agent./bin/uipathctl rke2 generate-registries cluster_config.json --current-config-path /etc/rancher/rke2/registries.yaml > /etc/rancher/rke2/registries.yaml.tmp mv -f /etc/rancher/rke2/registries.yaml.tmp /etc/rancher/rke2/registries.yaml systemctl restart rke2-server || systemctl restart rke2-agent -
Update the ArgoCD trusted CA certificate for the external OCI-compliant registry:
./bin/uipathctl config argocd ca-certificates update --cacert [PATH]./bin/uipathctl config argocd ca-certificates update --cacert [PATH]
- Generating a Certificate Signing Request (CSR) and a private key
- Managing server certificates
- Updating the server certificate
- How to update server certificates
- How the certificate chain is assembled
- Accessing the TLS certificate
- Adding the CA certificate to the host trust store
- Managing additional CA certificates
- Updating the CA certificates
- Accessing the CA certificates
- Managing identity token-signing certificates
- Automatic certificate rotation
- Manually updating the certificate
- Manually rotating the certificate
- Emergency certificate rotation
- Accessing the certificate
- Managing RKE2 certificates
- Checking the RKE2 certificate expiration date
- Rotating the RKE2 certificate
- Managing the external OCI-compliant registry certificate
