- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
Known issue where Automation Hub is inaccessible after upgrading to Automation Suite 2024.10.0 due to database schema discrepancies, with an SQL script workaround.
After upgrading to Automation Suite 2024.10.0, you can no longer access Automation Hub due to database schema discrepancies. We fixed the issue in Automation Suite 2024.10.1.
Solution
To address the problem, you must run the following SQL script on the AutomationSuite_Automation_Hub database:
-- IMPORTANT:
-- This script should be executed in the AutomationSuite_Automation_Hub database.
-- Purpose:
-- This script resolves potential issues encountered during the upgrade to version 2024.10.0 of Automation Hub.
-- Please replace placeholders with actual data before running the script.
-- Assumptions:
-- The customer has an existing Automation Hub instance running a version prior to 2024.10.0.
-- Variables:
-- @AccountName: Logical name of the Automation Suite organization. Replace '<USER_INPUT>' with the actual name.
-- @TenantName: Logical name of the Automation Suite tenant. Replace '<USER_INPUT>' with the actual name.
-- Note:
-- The script will terminate if any errors occur and will provide error details for debugging.
SET XACT_ABORT ON;
-- Replace placeholders with actual values
DECLARE @AccountName NVARCHAR(255) = '<USER_INPUT>';
DECLARE @TenantName NVARCHAR(255) = '<USER_INPUT>';
-- DO NOT EDIT ANYTHING AFTER THIS POINT --
BEGIN TRY
BEGIN TRANSACTION;
-- Validate placeholders
IF @AccountName = '<USER_INPUT>' OR
@TenantName = '<USER_INPUT>'
BEGIN
RAISERROR('Placeholders were not replaced with actual values. Please update the script and retry.', 16, 1);
RETURN;
END;
-- Declare variables for tenant information
DECLARE @TenantUUID NVARCHAR(255);
DECLARE @TsTablePrefix NVARCHAR(255);
-- Retrieve tenant_uuid from the cloud_tenants table based on TenantName and AccountName
DECLARE @sql NVARCHAR(MAX);
DECLARE @params NVARCHAR(MAX);
SET @sql = N'SELECT @TenantUUID = tenant_uuid
FROM ah.cloud_tenants
WHERE cloud_TenantName = @TenantName
AND cloud_AccountName = @AccountName;';
SET @params = N'@TenantName NVARCHAR(255), @AccountName NVARCHAR(255), @TenantUUID NVARCHAR(255) OUTPUT';
EXEC sp_executesql @sql,
@params,
@TenantName = @TenantName,
@AccountName = @AccountName,
@TenantUUID = @TenantUUID OUTPUT;
-- Abort if tenant_uuid is not found
IF @TenantUUID IS NULL
BEGIN
RAISERROR('No tenant found for the provided TenantName and AccountName. Script execution aborted.', 16, 1);
RETURN;
END;
-- Retrieve tenant_db_table_prefix from tenants table using tenant_uuid
SET @sql = N'SELECT @TsTablePrefix = tenant_db_table_prefix
FROM ah.tenants
WHERE tenant_uuid = @TenantUUID;';
SET @params = N'@TenantUUID NVARCHAR(255), @TsTablePrefix NVARCHAR(255) OUTPUT';
@params,
@TenantUUID = @TenantUUID,
@TsTablePrefix = @TsTablePrefix OUTPUT;
-- Abort if tenant_db_table_prefix is not found
IF @TsTablePrefix IS NULL
BEGIN
RAISERROR('No tenant found in the tenants table for the provided tenant_uuid. Script execution aborted.', 16, 1);
RETURN;
END;
-- Drop the default constraint for assignment_days column
DECLARE @ConstraintName NVARCHAR(200);
SELECT @ConstraintName = dc.name
FROM sys.default_constraints dc
INNER JOIN sys.columns c
ON dc.parent_object_id = c.object_id
AND dc.parent_column_id = c.column_id
WHERE c.object_id = OBJECT_ID(@TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates')
AND c.name = 'assignment_days';
IF @ConstraintName IS NOT NULL
BEGIN
EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates DROP CONSTRAINT [' + @ConstraintName + ']');
END;
-- Recreate the default constraint for assignment_days
DECLARE @UniqueConstraintName NVARCHAR(255) = '[' + @TsTablePrefix + 'DF_assignment_days]';
BEGIN
EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates ADD CONSTRAINT ' + @UniqueConstraintName + ' DEFAULT 0.00 FOR assignment_days');
END
-- Drop the index on the assignment_days column
IF EXISTS (SELECT 1
FROM sys.indexes
WHERE name = 'assignment_days'
AND object_id = OBJECT_ID(@TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates')
BEGIN
EXEC('DROP INDEX assignment_days ON ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates');
END;
-- Alter the assignment_days column
EXEC('ALTER TABLE ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates ALTER COLUMN assignment_days NUMERIC(15, 2) NOT NULL');
-- Recreate the index on assignment_days
EXEC('CREATE NONCLUSTERED INDEX assignment_days ON ' + @TsTablePrefix + 'process_cost_benefit_one_time_costs_estimates (assignment_days ASC)');
-- Insert a record into the migrations table
EXEC('INSERT INTO ' + @TsTablePrefix + 'migrations (name, run_on) VALUES (''tenants/20230925145641-edit-cba-one-time-costs-estimates-table-column'', CURRENT_TIMESTAMP)');
-- Commit the transaction
COMMIT TRANSACTION;
PRINT 'Script executed successfully.';
END TRY
BEGIN CATCH
IF @@TRANCOUNT > 0
ROLLBACK TRANSACTION;
-- Output error details
PRINT 'Error occurred during script execution:';
PRINT 'Error Number: ' + CAST(ERROR_NUMBER() AS VARCHAR(10));
PRINT 'Error Severity: ' + CAST(ERROR_SEVERITY() AS VARCHAR(10));
PRINT 'Error State: ' + CAST(ERROR_STATE() AS VARCHAR(10));
PRINT 'Error Procedure: ' + ISNULL(ERROR_PROCEDURE(), '');
PRINT 'Error Line: ' + CAST(ERROR_LINE() AS VARCHAR(10));
PRINT 'Error Message: ' + ERROR_MESSAGE();
END CATCH;
-- IMPORTANT:
-- Purpose:
-- Assumptions:
-- Variables:
-- Note:
SET XACT_ABORT ON;
BEGIN TRY
BEGIN TRANSACTION;
BEGIN
RETURN;
END;
@params,
BEGIN
RETURN;
END;
FROM ah.tenants
@params,
BEGIN
RETURN;
END;
BEGIN
END;
BEGIN
END
IF EXISTS (SELECT 1
FROM sys.indexes
BEGIN
END;
COMMIT TRANSACTION;
END TRY
BEGIN CATCH
IF @@TRANCOUNT > 0
END CATCH;
