- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Antivirus causes installation and operation issues
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- After Disaster Recovery Dapr is not working properly for Task Mining
- Task Mining initialization issue in Kerberos
- Exploring Logs
Resolve Dapr certificate issues affecting Task Mining after disaster recovery in Automation Suite.
After a Disaster Recovery, Dapr is not restored properly, and the certificates needed by dapr to provide services for Process Mining and Task Mining are incorrect. The dapr, processmining, and taskmining applications appear to be healthy first, but will then go back to progressing state and the environment becomes unstable. When logging in to Process Mining or Task Mining, the application may not load, or return unexpected errors.
This page describes the steps you should take to resolve the issue.
Overview of the steps
- Delete all dapr secrets and the mutatingwebhookconfiguration.
- Resync all dapr secrets and the mutatingwebhookconfiguration.
- Restart dapr-sentry deployment and wait to the deployment is finished.
- Restart dapr-operator deployment and wait to the deployment is finished.
- Restart dapr-sidecar-injector deployment and wait to the deployment is finished.
A detailed description of the steps is provided next.
Deleting dapr secrets and the mutatingwebhookconfiguration
Go to Applications in ArgoCD.
Select the dapr application card to open the dapr app details tree.
Locate the dapr secrets.
The secrets must be recreated. You can do this by deleting each secret.
Open the context menu of the secret and select Delete.
In the Delete resource confirmation dialog enter the name of the secret and select OK to confirm.
Repeat steps 4 and 5 for the remaining secrets.
In the dapr app details tree, locate the mutatingwebhookconfiguration.
Note:You can recognize the mutatingwebhookconfiguration from the label MWC.
Open the context menu of the secret and select Delete. In the Delete resource confirmation dialog enter the name of the mutatingwebhookconfiguration and select OK to confirm.
Syncing the dapr secrects and the mutatingwebhookconfiguration
Some of the secrets are immediately recreated. This is indicated by a green check mark on the secret card.
If a secret is not recreated, you need to sync to recreate the secret.
Locate the secret you want to recreate and select Sync from the context menu.
In the pop-up panel, select SYNCHRONIZE.
Repeat steps 2 and 3 for all the secrets that you want to recreate.
Open the context menu for the mutatingwebhookconfiguration and select Sync.
Restarting the deployment
After you deleted and synchronized the secrets and the mutatingwebhookconfiguration, you need to restart the deployment.
In the dapr app details tree, locate the dapr-sentry deploy card.
Open the context menu and select Restart.
A confirmation dialog is displayed.
Select OK to confirm the restart. The dapr-sentry deployment starts. When the deployment is finished, a green heart appears. Wait for the deployment to be finished.
In the dapr app details tree, locate the dapr-operator deploy card.
In the confirmation dialog, select OK to confirm the restart. Wait for the deployment to be finished.
In the dapr app details tree, locate the dapr- sidecar-injector deploy card.
Restart the deployments in the described order and make sure a deployment is ready before starting the next deployment.
- dapr-sentry
- dapr-operator
- dapr-sidecar-injector
You can now check that dapr is working correctly by looking at processmining, as previously described. Now there should be 3 containers in the pod and the daprd container should be present in the LOGS.
The following image shows the processmining pod with 3 containers including the daprd sidecar, confirming that dapr is working correctly.
Task Mining should work properly now.
