Last updated Nov 13, 2025
Release Notes
May 22, 2025
Upcoming removal
This deployment template is currently deprecated and is planned for removal in October 2025. As an alternative, consider using Automation Suite on EKS/AKS or reach out to support.
February 20, 2025
AWS template version
2024.10.1
Automation Suite version
2024.10.1
What's new
If you installed Automation Suite 2023.10.6 using the AWS deployment template, you can now upgrade to Automation Suite 2024.10.1. For details, see Completing an upgrade.
December 19, 2024
2024.10.1
2024.10.1
What's new
  • We updated RHEL to version 9.4.
  • We updated the CPU and memory requirements for UiPath® products.
  • We removed the ArgoCDUserPassword post-deployment output.
  • The ArgoCD admin password secret now stores the ArgoCD password generated automatically during installation. We recommend that you change the password when you first log in to ArgoCD.
  • We added the CORS configuration for storage buckets.
  • May 22, 2025
  • Upcoming removal
  • February 20, 2025
  • What's new
  • December 19, 2024
  • What's new
