Last updated Dec 23, 2025
Configuring Orchestrator parameters
Manifest configuration
Follow these steps to edit the Orchestrator manifest configuration:
  1. Edit the cluster_config.json file
  2. Add or edit the desired settings in the orchestrator section.
    For details on the Ochestrator-specific configuration, see Orchestrator configuration.
  3. Run this command:
    ./bin/uipathctl manifest apply cluster_config.json --versions versions/helm-chart.json --kubeconfig kubeconfig.yaml --only orchestrator./bin/uipathctl manifest apply cluster_config.json --versions versions/helm-chart.json --kubeconfig kubeconfig.yaml --only orchestrator
Custom Orchestrator configuration
You can use this command to edit the Orchestrator custom configuration for both appSettings and NLog:
./bin/uipathctl config orchestrator./bin/uipathctl config orchestrator
Custom Orchestrator scenarios
You can modify various Orchestrator parameters using uipathctl. This enables the following configuration scenarios:
  • Manifest configuration
  • Custom Orchestrator configuration
  • Custom Orchestrator scenarios
