- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure on RHEL 8.x nodes
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
Post-migration steps
Complete post-migration tasks such as removing old Identity cache keys and updating AD integration in Automation Suite.
After completing the migration, take the following steps:
- Remove the old Identity cache keys. Details...
- Update the AD integration and authentication settings. Details...
- Clear Redis data. Details...
- Validate the Insights migration. Details...
- Validate the Test Manager migration. Details...
Step 5: Validating the Test Manager migration
To ensure a successful synchronization between Test Manager and ALM systems, follow these steps to reconfigure the Test Manager in Automation Suite:
- Reconfigure the Automation Suite Test Manager URL in your ALM systems to reflect the correct location of the Test Manager.
- Confirm that you can access Test Manager using the updated Automation Suite URL.
- Ensure all projects and their underlying resources, including test cases, requirements, and related data, are fully restored and accessible.
- Confirm that all attachments are correctly located in the external storage and can be downloaded without issues.
- Reconfigure robots to point to the correct Orchestrator URL to ensure they function properly.
- Update the Test Manager URL in Studio with the updated Test Manager in Automation Suite URL.
Troubleshooting
- If migration fails due to another operation that is already in progress, this occurs when ArgoCD is actively processing another job or deployment for Test Manager, preventing the migration script from executing. To solve this, follow these steps:
- Open the Arco CD UI and check the status of running processes related to Test Manager.
- Wait until all processes are completed, and confirm that all pods are in a healthy state.
- Re-run the the Test Manager migration script.
- If the script fails to execute due to a bad interpreter, follow these steps:
- Open a terminal in the directory where the Test Manager migration script is located.
- Run the following command:
dos2unix testmanager_migrator.shdos2unix testmanager_migrator.sh
