- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
- Automation Suite on OpenShift release notes
Automation Suite release notes
2024.10.1
Release date: December 18, 2024
Support for new RHEL version
We have expanded our OS support to include RHEL 9.6. For details on the supported RHEL versions, see Compatibility Matrix.
Release date: September 24, 2025
Support for full migration
Full migration is now supported in Automation Suite 2024.10.1.
Compared to the full migration steps in Automation Suite 2023.10, in this version there is an additional migration step in which you can update the schema of the Insights and Orchestrator databases after previously restoring them.
Also, we implemented the following improvements in the UiPath.OrganizationMigrationApp tool:
- We provide an inner exception during a database connection test for enhanced error logging and debugging.
- We improved the merging process of single sign-on users (SSO) from multiple organizations to handle database conflicts more efficiently. The update also provides accurate migration success messages and prevents potential data duplication. This enhancement significantly benefits organizations utilizing the MSI to Automation Suite setup with a multi-tenant configuration and SSO.
For more details, refer to Performing a full migration.
New flags for enhanced Kerberos authentication
We have introduced new configuration flags to give you more control over the Kerberos authentication. You can now use the following flags to customize the Kerberos authentication settings:
kerberos_auth_config.enable_integrated_sql_auth: This flag allows you to decouple the Kerberos authentication from the SQL authentication login, and to enable or disable Kerberos authentication for SQL across all your products.<serviceGroupName>.kerberos_auth_config.enabled: This flag allows you to control the use of Kerberos authentication for SQL authentication at product level. You must replace<serviceGroupName>with the name of your product.
These new flags bring changes to the priority order for SQL Kerberos authentication, as follows:
- Kerberos authentication for SQL is enabled by default when Kerberos authentication is enabled.
- If you set
kerberos_auth_config.enable_integrated_sql_authtofalse, Kerberos authentication for SQL is disabled across all your products. - If you set
<serviceGroupName>.kerberos_auth_config.enabledtofalse, Kerberos SQL authentication is disabled for the specified product.
For more details on Kerberos authentication, see Setting up Kerberos authentication.
New prerequisite checks
We have introduced more prerequisite checks to optimize the overall experience of installing and configuring Automation Suite and to catch missing requirements earlier. Here are some highlights:
- A new validation check ensures that the
READ_COMMITTED_SNAPSHOToption is enabled in the SQL Server database. We have implemented this check validation for Orchestrator, Apps, and Process Mining. - We have introduced a prerequisite check in the
mirror-registry.shandhydrate-registry.shscripts to validate the OCI compliance of the external registry before uploading images.
Security enhancements
We continue to provide security updates and patches to address Common Vulnerabilities and Exposures (CVEs).
Support added for Document Understanding modern projects
Document Understanding modern projects are now supported in Automation Suite on Linux for offline deployments.
Bug fixes
- We have fixed an Automation Suite installation issue that occurred when using an SQL Server version prior to 2019.
- We have fixed an issue that caused Insights data loss when you reinstalled or upgraded Insights following an Automation Suite upgrade from version 2023.4 or older.
- We have fixed an issue causing the temporary registry installation to fail for RHEL 8.9. This issue occured due to the deprecated
systemd generatecommand in the upstream Podman and the absence ofsecontextin Podman-generatedsystemdfiles. - An issue was causing the Helm chart build to fail when the
enableSqlIntegratedAuthparameter was set totrueinvalues.yamlfor Kerberos SQL integration. This issue occured to due incorrect indentation of certain environment variables. We have fixed the issue. - We fixed an issue causing Automation Hub to become inaccessible after an upgrade to Automation Suite 2024.10.
- We fixed an Insights annotation issue that would block the Automation Suite installer.
- We fixed an issue causing a partial failure to restore a backup due to a Dapr sync issue.
- We have fixed an issue causing the prerequisite checks to identify hostnames with capital letters as invalid. This behavior no longer occurs. Hostnames are now validated correctly regardless of letter capitalization.
aicenter skill syncandaicenter skill statuscommands to fail during a side-by-side upgrade. This issue occurred due to a syntax error. - An issue was preventing
exclude=rke2-*from being automatically added to the/etc/yum.conffile on all nodes. This issue occurred particularly in online environments and caused an unintentional upgrade of the RKE2 service on nodes other than the first server. Previously, you had to manually add the exception to the/etc/yum.confon all nodes. We have fixed the issue. - An issue was causing the node removal operation to fail with an
error: no objects passed to scalemessage. This issue occurred due to a name mismatch during the scaling up of the Prometheus operator. We have fixed the issue. - You can now use custom directories for storing your pod logs. Previously, this function was unavailable due to the switch to
kube-logging. - We have fixed an issue that occurred in non-HA Redis scenarios, where the
redis-cluster-0pod could get stuck in a terminating state during node drain operations. This behavior no longer occurs. - When using style attributes in the HTML tags while customizing your Login page, they reflected accurately in the preview. However, upon saving the changes, the style attributes were deleted automatically. Now, all style attributes used within tags persist after saving your changes.
- We have fixed an issue causing the upgrade to fail due to the overriding of existing Insights PVC sizes.
- An issue was causing installation or upgrade failures when enabling Connaisseur during the configuration of an external OCI-compliant registry. This issue occurred when the
registries.trust.enabledparameter was set totruein thecluster_config.jsonfile. We have fixed the issue. - We fixed a bug that was breaking SAML2 when basic authentication was disabled, along with various other bugs.
- You can now forward logs to external tools, such as Splunk, using the OpenTelemetry Collector. Previously, this function was unavailable due to the switch to
kube-logging.
Known issues
FIPS 140-2 support limitations
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
Pre-upgrade command fails with proxy and external objectstore
Erratum - added December 19, 2025: An issue prevents the uipathctl cluster pre-upgrade command from completing successfully in environments configured with a proxy and external objectstore. The issue occurs due to an error during the Insights volume migration process.
We fixed the issue in Automation Suite 2024.10.7.
Upgrade failure during posthook import in chained upgrades
Erratum - added December 19, 2025: An issue causes the upgrade to fail during the execution of the uipathctl rke2 upgrade command in chained upgrade scenarios. This issue occurs due to the posthook secret and configmap import operation not being idempotent, which leads to conflicts with existing Kubernetes objects.
To address the issue, refer to the Troubleshooting section.
Backup operations fail with PartiallyFailed status
Erratum - added December 19, 2025: An issue causes backup operations to fail with a PartiallyFailed status when the objectstore is in-cluster (rook-ceph).
The backup logs show errors similar to following example:
ERROR: insights/app/workdir/2025-10-01-04/.config/chromium/Crash Reports/settings.dat: Failed to copy: failed to open source object: operation error S3: GetObject, https response error StatusCode: 404
You can view the backup logs by running the following command:
./bin/velero backup logs <backup name>
To address the issue you must contact UiPath Support.
We fixed the issue in Automation Suite 2024.10.4.
Registry certificates not fully updated in offline scenarios
Erratum - added September 24, 2025: An issue causes the uipathctl config tls-certificates command to update only the internal certificate, while missing the certificate required by Argo CD to trust the in-cluster registry in offline scenarios.
To address the issue, you must run the following command to explicitly update the ArgoCD registry certificate in internal–external registry scenarios:
./bin/uipathctl config argocd ca-certificates update --cacert [PATH]
We fixed the issue in Automation Suite 2024.10.5.
Kerberos keytab rotation does not trigger token regeneration
Erratum - added September 24, 2025: An issue causes Kerberos keytab rotation to not immediately regenerate authentication tokens, which may lead to temporary connectivity disruptions between services and the database.
To address the issue, you must manually trigger the Kerberos ticket renewal cronjob by running the following command:
kubectl delete job tgt-rotate-manual -n uipath --ignore-not-found ; kubectl create job tgt-rotate-manual --from=cronjob/kerberos-tgt-update -n uipath
GPU enablement fails with external registries containing project names
Erratum - added September 24, 2025: An issue prevents GPU enablement after adding a GPU node when using external registries with project names (such as Harbor). The required pods do not start and display an ImagePullBackoff error.
If you are using an external registry with a project name, update the NVIDIA device plugin daemonset with the following command:
# Replace REGISTRY_WITH_PROJECT_NAME with the correct value (Eg. my.registry.io:443/myproject)
# Replcae TAG with the correct value. You can get this from the <installer_directory>/versions/docker-images.json file (Eg. v0.17.1)
kubectl set image daemonset/nvidia-device-plugin-daemonset \
-n kube-system \
nvidia-device-plugin-ctr=<REGISTRY_WITH_PROJECT_NAME>/k8s-device-plugin:<TAG>
-n kube-system \
Temporary registry installation timeout
Erratum - added September 24, 2025: An issue causes the temporary registry installation to fail with a timeout error when connecting to registry-1.docker.io. To address the issue, refer to the Troubleshooting section.
Thanos compactor stops on corrupted blocks
Erratum - added September 24, 2025: An issue causes the Thanos compactor to stop compacting metrics when it encounters corrupted blocks in the object store. This prevents compaction and leads to increased storage usage.
Uploading large Document Understanding bundles causes node instability
Erratum - added July 17, 2025: An issue causes nodes to become unresponsive when uploading large Document Understanding offline bundles. The issue occurred due to image layers being loaded into memory in parallel, leading to high memory consumption and out-of-memory (OOM) errors.
Task Mining Kerberos initialization failure
Erratum - added June 26, 2025: An issue causes the Task Mining service to fail to initialize in Kerberos environments. This issue occurs when the kerberos-discoverygroup-user-keytab secret is missing or when the discoverygroup app is not included in the enabledApps parameter of the IntegratedAuth app.
Agent node addition failure in offline environments
Erratum - added June 26, 2025: An issue causes the addition process of agent nodes in offline environments to fail. Agent node additions require the temporary registry to be running. To address the issue, you must re-enable the temporary registry to successfully join the agent node.
Frequent restarts in uipath namespace due to secret mismatch
Erratum - added June 26, 2025: An issue causes frequent restarts of deployments in the uipath namespace due to inconsistent istio-ingressgateway-certs secrets between the istio-system and docker-registry namespaces.
Log streaming does not work in proxy setups
Erratum - added June 26, 2025: Log forwarding does not work in proxy setups because the proxy environment variables were not set in the logging pods. To address the issue, refer to the Troubleshooting section.
Installation fails due to CA certificates with large policy OIDs
Erratum - added June 26, 2025: An issue causes the Automation Suite installation to fail when using Certificate Authority (CA) certificates that include a CertificatePolicies section with policy OID values exceeding 4 bytes. This issue prevents Automation Suite from recognizing these CA certificates, interrupting the installation process.
To address the issue, you must either ensure that the policy OID values within the CertificatePolicies section do not exceed 4 bytes, or avoid using CA generators that add the CertificatePolicies section to the certificates.
Licensing SQL connection error
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Service disruptions due to automatic secret rotation
Erratum - added May 14, 2025: An issue causes service disruptions due to the automatic secret rotation, making services temporarily inaccessible.
To address this issue, take the following steps:
- Restart the affected service to restore its normal functionality.
- Navigate to the ArgoCD UI and from the platform applicatio, select Details > Parameters. Edit the values to add
"secretRotation: enabled: false"underidentity-service. You must take this step after each Automation Suite upgrade or reinstallation.
For AI Center, all skills must be stopped and started from AI Center UI.
Studio Web not accessible when using a proxy
Erratum - added April 28, 2025: If you are using a proxy environment and Studio Web is enabled, Studio Web is not accessible and throws a 404 error. As a workaround, you must add studioweb-backend,studioweb-frontend,studioweb-typecache to the no_proxy entry in the input.json file and rerun the installer.
This is fixed in Automation Suite 2024.10.3.
Blocked upgrade on backup-restored cluster
Erratum - added April 28, 2025: An issue blocks the Automation Suite upgrade on a backup-restored cluster. For a successful upgrade, remove all labels from the service apps.
We fixed the issue in Automation Suite 2024.10.3.
Incomplete Docker registry cleanup process
Erratum - added April 28, 2025: An issue prevents the registry cleanup command from effectively clearing the unused Docker images from all registry pods. To address the issue, refer to the Troubleshooting section.
Upgrade fails due to MongoDB to SQL Server migration
Erratum - added April 28, 2025: We have identified an issue impacting the side-by-side and the in-place upgrade of Automation Suite 2022.10 or earlier to Automation Suite 2024.10.0 or later. Due to a faulty migration from MongoDB to SQL Server, the upgrade operation fails if you have Apps enabled and use Kerberos authentication for the SQL Server database.
The recommended solution is to upgrade to Automation Suite 2024.10.3.
Kube-proxy health check not working
Erratum - added April 28, 2025: The node-monitor component, which monitors the node for issues such as checking kube-proxy health or if ip_forward is enabled, and cordons the node if issues arise, is not working for specific nodes such as GPU, task-mining, or as-robot. We have fixed this issue in Automation Suite 2024.10.3.
Proxy and Kerberos pipelines not functioning correctly
Erratum - added April 28, 2025: Proxy and Kerberos pipelines are not functioning correctly, leading to authentication and support issues.
Same requirement for enabling user and SQL authentication
Erratum - added March 24, 2025: The configuration of user authentication and SQL authentication for the Automation Suite cluster is interconnected. To use either of them, currently you must set both kerberos_auth_config.enabled and kerberos_auth_config.enable_integrated_sql_auth parameters to true.
Upgrade fails due to Velero migration issue
Erratum - added March 3, 2025: An issue related to Velero migration causes the Automation Suite in-place upgrade to fail when the backup is enabled. The address the issue, see the Troubleshooting section.
Orchestrator and AI Center require SQL Sever version 2019 and higher
Erratum - added February 27, 2025: For this version of Automation Suite, you need to use SQL Server version 2019 or higher for proper operation of Orchestrator and AI Center.
Upgrade failure due to upgrade-journal configmap
Erratum - added February 17, 2025: An issue affecting the upgrade-journal configmap causes the upgrade from Automation Suite 2024.10.0 to Automation Suite 2024.10.1 to fail. The address the issue, see the Troubleshooting section.
Infrastructure upgrade failure due to missing server resource type
Erratum - added February 17, 2025: An issue causes the infrastucture upgrade process to fail with an infra upgrade to 1.31.4 failed cannot upgrade embedded infra 1.31.4 Running prerequisite checks on all nodes...\nerror: the server doesn't have a resource type \"plan\ error message. This issue occures due to a missing server resource type.
To fix this issue, you must restart the system-upgrade-controller deployment in the system-upgrade namespace using the following command:
kubectl rollout restart deployment system-upgrade-controller -n system-upgrade
Once the restart has been successfully completed, you can re-trigger the infrastructure upgrade process.
This issue is fixed in Automation Suite 2024.10.2.
Error message while uninstalling rook-ceph post migrating to a S3 object-store
Erratum - added February 17, 2025: When uninstalling rook-ceph, an error message related to missing external object storage configuration is displayed. This issue occurs even though the migration is succesful. This behavior is fixed in Automation Suite 2024.10.2.
AI Center storage migration failure
Erratum - added February 17, 2025: An issue prevents uipathctl from correctly setting executeMigration to true during the migration process from Ceph in-cluster storage to external object storage in AI Center.
To fix this issue, you must manually set executeMigration to true in ArgoCD for AI Center and then proceed with a resync, ensuring to prune. This issue is fixed in Automation Suite 2024.10.2.
FQDN update failure due to security configuration
Erratum - added February 17, 2025: An issue causes the FQDN update flow to fail due to a security configuration.
To address this issue, you must use the uipathctl version included in Automation Suite 2024.10.2 when you update the FQDN at the infrastructure level. To download uipathctl, see Installation packages download links.
RKE2 certificate rotation command issue on agent nodes
Erratum - added February 17, 2025: An issue causes the RKE2 certificate rotation command to run on the agent nodes even though it is not supported. This issue occurs during the Automation Suite upgrade process.
To address this issue, you must manually edit infra-installer.sh and replace the rke2 certificate rotate command with [[ ${NODE_ROLE} != "agent" ]] && rke2 certificate rotate to exclude the agent nodes.
In-cluster registry node addition failure in offline environment
Erratum - added February 17, 2025: An issue prevents the addition of a server node in offline environments with an in-cluster registry.
FQDN update failure
Erratum - added February 17, 2025: An issue causes the FQDN update to fail due to the update_fqdn parameter to not being properly set in the service-cluster-configurations secret.
To address this issue, you must manually remove the update_fqdn and update_fqdn_state parameters and update the service-cluster-configurations secret using the following command:
kubectl patch secret service-cluster-configurations -n uipath-infra --type=json -p='[
{"op": "remove", "path": "/data/UPDATE_FQDN"},
{"op": "remove", "path": "/data/UPDATE_FQDN_STATE"}
Full migration from standalone products to Automation Suite not supported
You cannot currently perform a full migration from standalone products version 2024.10 to Automation Suite 2024.10 using the UiPath.OrganizationMigrationApp tool. We are actively working on introducing support for this scenario.
In the meantime, you can perform a single-tenant migration. For details on this migration option, refer to Single tenant migration.
Migration from Automation Suite on Linux to Automation Suite on OpenShift not supported
You cannot currently perform a migration from Automation Suite on Linux to Automation Suite on OpenShift. We are actively working on introducing support for this scenario.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
Internal third-party component versions
This Automation Suite release bundles the following internal components:
| Component | Version |
| RKE2 | 1.30.5+rke2r1 |
| ArgoCD | 2.12.6 |
| gatekeeper | 3.17.1 |
| rook | 1.14.6 |
| ceph | 17.2.6 |
| prometheus-pushgateway | 1.10.0 |
| cert-manager | 1.16.1 |
| kube-logging/logging-operator | 4.9.1 |
| config-reloader | v0.0.5 |
| reloader | 1.0.95 |
| velero | 1.14.1 |
| Prometheus | 2.55.1 |
| Grafana | 11.3.0 |
| velero | 1.14.1 |
| redis-operator | 7.4.6-2 |
| redis-cluster | 7.4.6-102 |
| oauth2-proxy | 7.7.1 |
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
- Support for new RHEL version
- Support for full migration
- New flags for enhanced Kerberos authentication
- New prerequisite checks
- Security enhancements
- Support added for Document Understanding modern projects
- Bug fixes
- Known issues
- FIPS 140-2 support limitations
- Pre-upgrade command fails with proxy and external objectstore
- Upgrade failure during posthook import in chained upgrades
- Backup operations fail with PartiallyFailed status
- Registry certificates not fully updated in offline scenarios
- Kerberos keytab rotation does not trigger token regeneration
- GPU enablement fails with external registries containing project names
- Temporary registry installation timeout
- Thanos compactor stops on corrupted blocks
- Uploading large Document Understanding bundles causes node instability
- Task Mining Kerberos initialization failure
- Agent node addition failure in offline environments
- Frequent restarts in uipath namespace due to secret mismatch
- Log streaming does not work in proxy setups
- Installation fails due to CA certificates with large policy OIDs
- Licensing SQL connection error
- Service disruptions due to automatic secret rotation
- Studio Web not accessible when using a proxy
- Blocked upgrade on backup-restored cluster
- Incomplete Docker registry cleanup process
- Upgrade fails due to MongoDB to SQL Server migration
- Kube-proxy health check not working
- Proxy and Kerberos pipelines not functioning correctly
- Same requirement for enabling user and SQL authentication
- Upgrade fails due to Velero migration issue
- Orchestrator and AI Center require SQL Sever version 2019 and higher
- Upgrade failure due to upgrade-journal configmap
- Infrastructure upgrade failure due to missing server resource type
- Error message while uninstalling rook-ceph post migrating to a S3 object-store
- AI Center storage migration failure
- FQDN update failure due to security configuration
- RKE2 certificate rotation command issue on agent nodes
- In-cluster registry node addition failure in offline environment
- Full migration from standalone products to Automation Suite not supported
- Migration from Automation Suite on Linux to Automation Suite on OpenShift not supported
- Deprecation timeline
- Bundling details
- Product versions
- Internal third-party component versions
- Migration tool version
