- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Antivirus causes installation and operation issues
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Pods stuck in Init state due to XFS volume mount failure
- Cluster data appears lost after a reboot due to incorrect Rancher and etcd disk mount order
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
Backing up and restoring the cluster
Backup and restore functionality in Automation Suite, including NFS server requirements and supported scenarios for data protection.
Automation Suite supports the backup and restore functionality to prevent data loss in various scenarios. You can configure a backup any time post-installation.
To use the backup and restore functionality, you must enable an NFS server, backup cluster, and restore cluster. These concepts are defined in the following section.
Backup and restore via virtual machines snapshots is not supported.
For Automation Suite versions 2024.10.0 to 2024.10.3, when the objectstore is configured in-cluster (rook-ceph), the backup operations can fail with a PartiallyFailed status. For details, refer to theTroubleshooting section.
Terminology
NFS Server - The server that stores the backup data and facilitates the restoration. You can set up the NFS server on any machine or a PaaS service offered by cloud providers. Note that we do not support Windows-based NFS and Azure blob-based NFS.
Backup Cluster - The cluster you set up to install Automation Suite. This is the cluster where you will enable the backup.
Restore Cluster - The cluster where you restore all the data from the backup cluster. This becomes the new cluster where you run Automation Suite once the restore process is complete.
Prerequisites
- This setup will only enable a backup of the cluster, including cluster configuration and data stored as part of the in-cluster
block storage in
/datadiskand objectstore data disks attached to server machines. However, this will not enable the backup of any external data sources, such as the SQL database and external objectstore. You must enable the external data source backup separately. - If you want to add new server nodes after enabling the backup, make sure you configure the NFS server to allow access to the new node.
To set up the backup and restore functionality, you must meet the following requirements:
You must use NFSv3 or NFSv4 on Linux.
You must set up the NFS server on a separate machine hosted outside of the backup and restore cluster.
There must not be more than 10-millisecond Round Trip Time (RTT) latency between the NFS server and the backup and restore cluster.
The cluster you want to back up and the NFS server must be in the same region.
The NFS server must meet the following hardware requirements:
CPU RAM Disk 4(v-) CPU 8 GB 1 TB SSD (1100 IOPS) -
The NFS server must be reachable from all the cluster nodes.
You must enable the following ports on the NFS server and all the nodes in the backup cluster. When restoring the cluster, the same ports must be open on all the nodes in the restore cluster.
Port Protocol Purpose 2049TCP Bidirectional communication between the NFS server and the backup and restore cluster. This is the port on which the NFS server will run. 111TCP Bidirectional communication between the NFS server and the backup and restore cluster. This port is used for rpcbind between the NFS server and the backup and restore cluster.
