- Overview
- Requirements
- Deployment templates
- Q&A: Deployment templates
- Release notes
- GCP deployment architecture
- Step 1: Preparing the GCP deployment
- Step 2: Deploying Automation Suite to GCP
- Step 3: Post-deployment steps
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Once you prepare the GCP environment, you can directly deploy the infrastructure.
Take the following steps:
Deployment parameters
Name |
Description |
Parameter type |
Example |
Project in which the resources will be deployed. |
string |
Region where the resources will be deployed. |
string |
Default zone where zonal resources are deployed. The zone should belong to the region you chose. |
string |
Automation Suite installer version. |
string |
Automation Suite installer URL. It overwrites the
installer_version parameter and installs the version from the package.
string |
Automatically install Automation Suite on the provided infrastructure. |
bool |
Fully qualified domain name (FQDN) for Automation Suite. |
string |
Username used to log in VMs via SSH. |
string |
Path to the SSH public key used to access VMs. |
string |
Path to the SSH private key used to access VMs. |
string |
Instance type of server machines. |
string |
Instance type of agents machines. |
string |
(Optional) Parameter used only if the number of GPU agents is at least 1. Instance type of GPU agent machines. |
string |
(Optional) Parameter used only if the number of GPU agents is at least 1. GPU type for the GPU nodes. |
string |
Number of server VMs, must be odd |
number |
Number of agent VMs. |
number |
Number of GPU agent VMs |
number |
(Optional) Name of the custom image you want to use for the VM's. Leave empty to default to latest RHEL 8 GCP image. |
string |
Install Orchestrator. |
bool |
Install AI Center. |
bool |
Install Document Understanding. |
bool |
Install Insights. |
bool |
Install Data Service |
bool |
Install Test Manager. |
bool |
Install Automation Ops. |
bool |
Install Automation Hub. |
bool |
Install Apps. |
bool |
Install Action Center. |
bool |
Install Task Mining. |
bool |
Install Automation Suite Robots. |
bool |
Instance type of ASobots dedicated agents. |
number |
Number of dedicate ASRobots VMs. |
string |
Install Process Mining. |
bool |
By setting the parameter as true, you agree to the applicable license agreement. |
bool |
If you want to add any new configuration that is exposed via cluster_config.json, follow these steps:
