Last updated Dec 15, 2025
Upgrade fails due to Velero migration issue
An issue related to Velero migration causes the in-place upgrade to Automation Suite 2024.10.1 and 2024.10.2 to fail when the backup is enabled.
Solution
To address the problem, take the following steps:
  1. If you have enabled backup in cluster, then disable the backup and uninstall Velero.
    1. To disable backup, refer to the Disabling the schedule snapshot backup section.
    2. To uninstall Velero, run the following command:
      kubectl delete ns velerokubectl delete ns velero
  2. After executing the first step, create a copy of your cluster_config.json and modify the original cluster_config.json to remove the snapshot field. Run the following command:
    cp cluster_config.json orig.cluster_config.json
    cat cluster_config.json | jq "del(.snapshot)" > cluster_config.jsoncp cluster_config.json orig.cluster_config.json
  3. Once you complete the upgrade, use original JSON file, orig.cluster_config.json, and reconfigure the backup as described in the Providing the backup store configuration section.
  • Description
  • Solution
