- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
RKE2CertificateExpiry7Days
This alert indicates that the server TLS certificate expires in the following 7 days.
To fix this issue, update the TLS certificate. For instructions, see Managing the certificates.
RKE2CertificateExpiry90Days
This alert has different severity levels and messages based on the number of remaining days:
Warning Severity alert
Message: RKE2 certificates are going to expire in 89 days! To renew, restart RKE.
Message: RKE2 certificates are going to expire in 29 days! To renew, restart RKE.
Critical Severity alert
Message: RKE2 certificates are going to expire in 7 days! To renew, restart RKE.
RKE2CACertificateExpiry60Days
Message: RKE2 CA certificates are going to expire in 59 days!
RKE2CACertificateExpiry30Days
Message: RKE2 CA certificates are going to expire in 29 days!
RKE2CACertificateExpiry15Days
This alert indicates that the server TLS certificate expires in the following 15 days.
To fix this issue, update the TLS certificate. For instructions, see Managing server certificates.
IdentityKerberosTgtUpdateFailed
This job updates the latest Kerberos ticket to all the UiPath® services. Failures in this job would cause SQL server authentication to fail.
To fix this issue, check the logs:
kubectl -n uipath logs job/kerberos-tgt-updatekubectl -n uipath logs job/kerberos-tgt-updateIf the issue persists, please contact UiPath® Support.
IdentityCertificateExpiry30Days
This alert indicates that the Identity token signing certificate will expire in the following 30 days.
To fix this issue, update the Identity token signing certificate. For instructions, see Managing server certificates.
IdentityCertificateExpiry7Days
This alert indicates that the Identity token signing certificate will expire in the following 7 days.
UiPathAvailabilityHighTrafficBackend, UiPathAvailabilityMediumTrafficUserFacing, UiPathAvailabilityMediumTrafficBackend, UiPathAvailabilityLowTrafficUserFacing, UiPathAvailabilityLowTrafficBackend
The number of http 500 responses from UiPath® services exceeds a given threshold.
Traffic level |
Number of requests in 20 minutes |
Error threshold (for http 500s) |
High |
>100,000 |
0.1% |
Medium |
Between 10,000 and 100,000 |
1% |
Low |
< 10,000 |
5% |
Errors in user-facing services would likely result in degraded functionality that is directly observable in the Automation Suite UI, while errors in backend services would have less obvious consequences.
The alert indicates which service is experiencing a high error rate. To understand what cascading issues there may be from other services that the reporting service depends on, you can use the Istio Workload dashboard, which shows errors between services.
Please double check any recently reconfigured Automation Suite products. Detailed logs are also available with the kubectl logs command. If the error persists, please contact UiPath® Support.
SecretCertificateExpiry30Days
This alert indicates that the server TLS certificate will expire in the following 30 days.
To fix this issue, update the server TLS certificate. For instructions, see Managing server certificates.
SecretCertificateExpiry7Days
This alert indicates that the server TLS certificate will expire in the following 7 days.
UiPathRequestRouting
Errors in the request routing layer would result in degraded functionality that is directly observable in the Automation Suite UI. The requests will not be routed to backend services.
istio-ingressgateway pods in istio-system namespace. Retrieve the pod name by running the following commands:
kubectl get pods -n istio-system
kubectl logs <istio-ingressgateway-pod-name> -n istio-systemkubectl get pods -n istio-system
kubectl logs <istio-ingressgateway-pod-name> -n istio-systemInternodeCommunicationBroken
The node has become unresponsive due to some issue causing broken communication between nodes in the cluster.
To fix this problem, take the following steps:
Make sure that you implemented the settings mentioned in Step 8: Configuring kernel and OS level settings.
If applicable, make sure you implemeneted the changes mentioned in
If the previous steps did not solve the issue, reach out to UiPath® Support with the generated support bundle.
- kubernetes-system-apiserver
- RKE2CertificateExpiry7Days
- RKE2CertificateExpiry90Days
- RKE2CACertificateExpiry60Days
- RKE2CACertificateExpiry30Days
- RKE2CACertificateExpiry15Days
- uipath.cronjob.alerts.rules
- IdentityKerberosTgtUpdateFailed
- IdentityCertificateExpiry30Days
- IdentityCertificateExpiry7Days
- UiPathAvailabilityHighTrafficBackend, UiPathAvailabilityMediumTrafficUserFacing, UiPathAvailabilityMediumTrafficBackend, UiPathAvailabilityLowTrafficUserFacing, UiPathAvailabilityLowTrafficBackend
- certs
- SecretCertificateExpiry30Days
- SecretCertificateExpiry7Days
- uipath.requestrouting.alerts
- UiPathRequestRouting
- InternodeCommunicationBroken
