Automation Suite on Linux Installation Guide
Last updated Jan 22, 2025
Migrating standalone products to Automation Suite
To migrate your standalone Orchestrator data to Automation Suite, you can use the UiPath Automation Cloud™ Migration Tool. The tool helps you run a single tenant migration process and copy strictly the entities present in your standalone Orchestrator. The tool retrieves these entities from standalone Orchestrator over API and then writes them in Automation Suite over API.
The tool can migrate to either Automation Cloud or Automation Suite, but this guide describes the process of migrating to Automation Suite. For instructions on migrating to Automation Cloud, see the Automation Cloud documentation instead.
You can only use the Automation Cloud Migration Tool if:
  • your standalone Orchestrator version is 2019.10.x, 2020.10.x, 2021.4.x,, 2021.10.x, or later.
  • your Automation Suite version is 2021.10.x or later.
Note:
You cannot currently perform a full migration from standalone products version 2024.10 to Automation Suite 2024.10 using the UiPath.OrganizationMigrationApp tool. We are actively working on introducing support for this scenario.
