Automation Suite on Linux Installation Guide
Last updated Jan 8, 2025
Step 7: Configuring the disks
Before performing an Automation Suite installation, you must partition and configure the disk using LVM, so that you can alter its size easily and without any data migration or data loss.
Partitioning the disks
The default partitioning structure on RHEL machines is not suitable for installing Kubernetes. This is because the Kubernetes infrastructure is usually installed under the /var partition, which is allocated only 8 GiB of space by default.
Note:
  • The supported format for the disks is ext4 or xfs.
  • You must create all partitions using LVM to ensure that the cluster data can reside on a different disk but still be viewed coherently. This also helps extend the partition size in the future without the risk of data migration or loss.
  • All the pods and application logs are stored under the /var/log/pods directory. Make sure that the capacity of this directory is at least 8 GiB. We also recommend configuring logrotate to rotate the logs at an interval ranging from daily to weekly.
  • If you use a single-node RKE2 setup with in-cluster storage, it is mandatory to provide at least an additional 512GB of disk space for the storage of Ceph data backups. For details, see How to schedule Ceph backup and restore data.
The disk requirements for online and offline installations are the same, except for the extra space needed to unpack the offline UiPath® bundle.
For the RHEL OS, make sure you have the following minimum mount point sizes on the machine.
Disk label
Server
Agent
Partition
Size
Purpose
Cluster disk
available
available
/var/lib/rancher
190 GiB
Note:
If you enable Document Understanding modern projects, the minimum size is 400 GiB.
Stores the container images and layers.
/var/lib/kubelet
56 GiB
Stores runtime Kubernetes configurations such as secrets, configmaps, and emptyDir.
/opt/UiPathAutomationSuite
10 GiB
Stores the installer binary.
etcd disk
available
not available
/var/lib/rancher/rke2/server/db
16 GiB
Stores the distributed database for Kubernetes
Data disk
available
not available
/datadisk/insights
15 GiB
Required for Insights.
/datadisk/monitoring
50 GiB
Required for the monitoring tools.
/datadisk/registry1
200 GiB
Required for the Docker registry.
/datadisk/objectstore2
10 Gib
Required for ceph-mon.
Objectstore2
available
not available
N/A
512 GiB
Required for in-cluster objectstore.
AI Center3
available
available
N/A
51 GiB minimum and 105 GiB recommended for 1 training pipeline.
Required only if you install AI Center.
UiPath® bundle disk
available
not available
/uipath512 GiB
Required only for offline installations to store the offline bundle
Ceph backup
available
not available
/backup512 GiBRequired only for single-node RKE2 setup with in-cluster storage, to store Ceph data backups.
1 This refers to the in-cluster Docker registry and is not applicable if you use an external registry.
2 This refers to the in-cluster objectstore and is not applicable if you use an external objectstore.
3 This refers to the storage required by the AI Center training pipeline. The disk is required only on the machines on which you plan to run the AI Center training pipeline and on the dedicated Task Mining node. We recommend attaching this disk on the agent machines.
Note:
We recommend that you do not use OS disk for any of the above purposes, to ensure processes get their fair share of resources.
Using uipathctl to configure the disks
To configure and partition the disks, you must use uipathctl .
Downloading uipathctl
uipathctl is a part of the as-installer.zip installation package. To use uipathctl, take the following steps:
  1. Download as-installer.zip and save it to a temporary location. For the download instructions, see as-installer.zip.
  2. Extract the contents by running the following command:
    unzip as-installer.zip -d installerunzip as-installer.zip -d installer
For details on how to use uipathctl to configure the disks, run the following command:
./bin/uipathctl rke2 disk --help./bin/uipathctl rke2 disk --help
Configuring the cluster disk on all the machines
To configure the cluster disk, run the following command on all the machines:
./bin/uipathctl rke2 disk --cluster-disk-name name_of_cluster_disk./bin/uipathctl rke2 disk --cluster-disk-name name_of_cluster_disk
Configuring the etcd disk on all the server machines
To configure the etcd disk, run the following command on all the server machines:
./bin/uipathctl rke2 disk --etcd-disk-name name_of_etcd_disk./bin/uipathctl rke2 disk --etcd-disk-name name_of_etcd_disk
Configuring the data disk on all the server machines
To configure the data disk, run the following command on all the server machines and provide the necessary flags based on your requirements:
./bin/uipathctl rke2 disk --volume name_of_data_disk./bin/uipathctl rke2 disk --volume name_of_data_disk
Flag
Value
-v|--volume
Disk name example: /dev/sde
You need the disk name when partitioning the disks that host the various mounts for monitoring, Insights, objectstore, and registry.
Providing the disk name is mandatory in the first-time configuration of the disk. If it is not provided during the subsequent run, then any existing disk associated with uipathdatavg is used to create the partition for the selected component.
--docker-registry
Optional. Only required if the external registry is not available.
--monitoring
Optional flag. The monitoring partition (Prometheus storage) is mandatory, so it is automatically created even if the flag is not specifically passed during the first run execution. However, the flag is required in the subsequent run, during the resize of the monitoring partition along with the --size flag.
--objectstore
Optional flag. Only required if the external objectstore is not available. When used, it also creates the datadisk partition required for ceph-mon. For details, see Partitioning the disks.
--insights
Optional flag. The Insights partition is automatically created even if the flag is not specifically passed during the first run execution. Insights storage configuration is required at infrastructure installation to allow you to enable Insights post-installation.
However, the flag is required in the subsequent run, during the resize of the Insights partition along with the --size flag.
--size <int>
Optional. If the integer value is provided, the selected component is resized, provided that enough space is available. Otherwise, the entire disk is consumed to expand the selected partition. It is mandatory to indicate precisely one partition that must be resized.
Note:
The --size option is not required during the disk configuration. It can be used after the configuration to extend the disk size.
--robot-package-cache
Path to the location on the Automation Suite Robots node to download the package for caching. This must be performed only on the Automation Suite Robots node.
You can also use the command to resize the selected partition with the help of the --size flag, as shown in the following example:
./bin/uipathctl rke2 disk --docker-registry --size 300./bin/uipathctl rke2 disk --docker-registry --size 300
Configuring the objectstore disk on all the server machines
This step is only required if the external objectstore is not available.
You can add or expand your storage size for the in-cluster objectstore by running the following script on all server nodes:
./bin/uipathctl rke2 disk --ceph-raw-disk-name name_ceph_raw_disk./bin/uipathctl rke2 disk --ceph-raw-disk-name name_ceph_raw_disk
Note:
  • An Azure known issue incorrectly marks the Azure disk as non-SSD. If Azure is your cloud provider, and you want to configure the Objectstore disk, follow the instructions in Troubleshooting.
  • Vertical scaling of the existing disks is not supported. To increase the size of your in-cluster storage post-installation, add new raw disks.
Configuring the AI Center disk on selected machines
To configure the AI Center disk, run the following command on the machines where you plan to execute the training pipelines:
./bin/uipathctl rke2 disk --aicenter-disk-name name_of_aicenter_disk_to_partition./bin/uipathctl rke2 disk --aicenter-disk-name name_of_aicenter_disk_to_partition
To extend the storage for AI Center:
  • If you want to add a new AI Center disk, run the following command on the machine where you plan to add the disk:
    ./bin/uipathctl rke2 disk --aicenter-storage-extend name_of_new_aicenter_disk_to_attach./bin/uipathctl rke2 disk --aicenter-storage-extend name_of_new_aicenter_disk_to_attach
  • If you have expanded the existing AI Center disk, run the following command on the machine where the underlying AI Center disk is expanded:
    ./bin/uipathctl rke2 disk --aicenter-storage-extend./bin/uipathctl rke2 disk --aicenter-storage-extend
Configuring the hosting disk for the Automation Suite Robot package cache
This step is required for single-node setups without a dedicated Automation Suite Robot agent.
To host the Automation Suite Robot package cache on the server node, you need to create a disk of at least 10 GB:
./bin/uipathctl rke2 disk --volume name_of_data_disk --robot-package-cache./bin/uipathctl rke2 disk --volume name_of_data_disk --robot-package-cache
Note: It is recommended that the disk is backed up by LVM.
Configuring the bundle disk on the first server node for the in-cluster registry
This step is required in the following scenarios:
  • When performing an offline (air-gapped) installation;
  • When an external registry is not available.
To configure the bundle disk, run the following command only on the first server node:
./bin/uipathctl rke2 disk --bundle-disk-name name_of_bundle_disk./bin/uipathctl rke2 disk --bundle-disk-name name_of_bundle_disk
Validating disk mounts
Note:
Make sure to add all mount points to the fstab file and to include the nofail option in those fstab entries so that it does not affect the VM boot in case of failure.
To validate that /etc/fstab is correctly configured and can handle a reboot of the system, take the following steps, run the following command:
mount -afvmount -afv
You should get the following output:
/var/lib/rancher                  : already mounted
/var/lib/kubelet                  : already mounted
/opt/UiPathAutomationSuite        : already mounted
/datadisk/monitoring              : already mounted
/datadisk/insights                : already mounted
/var/lib/rancher/rke2/server/db   : already mounted
# Additional mount point is require if customer is installing offline with internal registry
/datadisk/registry                : already mounted
# Additional mount point is require if customer is using in-cluster objectstore
/datadisk/objectstore             : already mounted/var/lib/rancher                  : already mounted
