Monitoring configuration
Reference for monitoring stack configuration options and resource provisioning parameters in Automation Suite.
Important:
The monitoring configuration parameters on this page do not take effect in Automation Suite versions 2024.10.0 through 2024.10.8. This issue is resolved in Automation Suite 2024.10.9.
To provision enough resources for monitoring (refer to Using the monitoring stack), you should consider the number of vCPUs in the cluster and the amount of desired metric retention. Details on how to set the following monitoring resource configurations are provided next.
The following table describes the monitoring field details:
ParameterDescription
prometheus_retentionIn days.
This is the amount of days that metrics will be retained for the purpose of visualization in Grafana and manual querying via the Prometheus console.
Default value is 7.
prometheus_storage_sizeIn GB.
Amount of storage space to reserve per Prometheus replica.
A good rule of thumb is to set this value to:
0.65 * vCPU cores * (prometheus_retention / 7)
Example: If you set prometheus_retention to 14 days, and your cluster has 80 cores spread across 5 machines, this becomes:
0.65 * 80 * (14 / 7)
52 * (2)
104
Default value is 45 and should not be set lower.
If Prometheus starts to run out of storage space, an alert will be triggered with specific remediation instructions. Refer to the Alert runbooks section.
prometheus_memory_limitIn MB.
Amount of memory to limit each Prometheus replica to.
100 * vCPU cores * (prometheus_retention / 7)
Example: If you've set prometheus_retention to 14 days, and your cluster has 80 cores spread across 5 machines, this becomes:
100 * 80 * (14 / 7)
8000 * (2)
16000
Default value is 3200 for the single-node evaluation mode, and 6000 for the multi-node HA-ready production mode, and should not be set lower.
If Prometheus starts to run out of memory, an alert will be triggered with specific remediation instructions. Refer to the Alert runbooks section.
Example
"monitoring": {
  "prometheus_retention": 14,
  "prometheus_memory_limit": 16000,
  "prometheus_storage_size": 104
"monitoring": {
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
