- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Applying a patch
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining
- Task Mining troubleshooting
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated Jan 8, 2025
When trying to upgrade to a new Automation Suite version, you might see the following error message:
Ceph objectstore is not completely healthy at the moment. Inner exception - Timeout waiting for all PGs to become active+clean
To fix this upgrade issue, verify if the OSD pods are running and healthy by running the following command:
kubectl -n rook-ceph get pod -l app=rook-ceph-osd --no-headers | grep -P '([0-9])/\1' -v
If the command does not output any pods, verify if Ceph placement groups (PGs) are recovering or not by running the following command:
function is_ceph_pg_active_clean() { local return_code=1 if kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status --format json | jq '. as $root | ($root | .pgmap.num_pgs) as $total_pgs | try ( ($root | .pgmap.pgs_by_state[] | select(.state_name == "active+clean").count) // 0) as $active_pgs | if $total_pgs == $active_pgs then true else false end' | grep -q 'true';then return_code=0 fi [[ $return_code -eq 0 ]] && echo "All Ceph Placement groups(PG) are active+clean" if [[ $return_code -ne 0 ]]; then echo "All Ceph Placement groups(PG) are not active+clean. Please wait for PGs to become active+clean" kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph pg dump --format json | jq -r '.pg_map.pg_stats[] | select(.state!="active+clean") | [.pgid, .state] | @tsv' fi return "${return_code}" } # Execute the function multiple times to get updated ceph PG status is_ceph_pg_active_clean
function is_ceph_pg_active_clean() { local return_code=1 if kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status --format json | jq '. as $root | ($root | .pgmap.num_pgs) as $total_pgs | try ( ($root | .pgmap.pgs_by_state[] | select(.state_name == "active+clean").count) // 0) as $active_pgs | if $total_pgs == $active_pgs then true else false end' | grep -q 'true';then return_code=0 fi [[ $return_code -eq 0 ]] && echo "All Ceph Placement groups(PG) are active+clean" if [[ $return_code -ne 0 ]]; then echo "All Ceph Placement groups(PG) are not active+clean. Please wait for PGs to become active+clean" kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph pg dump --format json | jq -r '.pg_map.pg_stats[] | select(.state!="active+clean") | [.pgid, .state] | @tsv' fi return "${return_code}" } # Execute the function multiple times to get updated ceph PG status is_ceph_pg_active_cleanNote: If none of the affected Ceph PG recovers even after waiting for more than 30 minutes, raise a ticket with UiPath® Support. -
If the command outputs pod(s), you must first fix the issue affecting them:
- If a pod is stuck in
Init:0/4
, then it could be a PV provider (Longhorn) issue. To debut this issue, raise a ticket with UiPath® Support. -
If a pod is in
CrashLoopBackOff
, fix the issue by running the following command:function cleanup_crashing_osd() { local restart_operator="false" local min_required_healthy_osd=1 local in_osd local up_osd local healthy_osd_pod_count local crashed_osd_deploy local crashed_pvc_name if ! kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph osd pool ls detail | grep 'rook-ceph.rgw.buckets.data' | grep -q 'replicated'; then min_required_healthy_osd=2 fi in_osd=$(kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status -f json | jq -r '.osdmap.num_in_osds') up_osd=$(kubectl -n rook-ceph exec deploy/rook-ceph-tools -- ceph status -f json | jq -r '.osdmap.num_up_osds') healthy_osd_pod_count=$(kubectl -n rook-ceph get pod -l app=rook-ceph-osd | grep 'Running' | grep -c -P '([0-9])/\1') if ! [[ $in_osd -ge $min_required_healthy_osd && $up_osd -ge $min_required_healthy_osd && $healthy_osd_pod_count -ge $min_required_healthy_osd ]]; then return fi for crashed_osd_deploy in $(kubectl -n rook-ceph get pod -l app=rook-ceph-osd | grep 'CrashLoopBackOff' | cut -d'-' -f'1-4') ; do if kubectl -n rook-ceph logs "deployment/${crashed_osd_deploy}" | grep -q '/crash/'; then echo "Found crashing OSD deployment: '${crashed_osd_deploy}'" crashed_pvc_name=$(kubectl -n rook-ceph get deployment "${crashed_osd_deploy}" -o json | jq -r '.metadata.labels["ceph.rook.io/pvc"]') info "Removing crashing OSD deployment: '${crashed_osd_deploy}' and PVC: '${crashed_pvc_name}'" timeout 60 kubectl -n rook-ceph delete deployment "${crashed_osd_deploy}" || kubectl -n rook-ceph delete deployment "${crashed_osd_deploy}" --force --grace-period=0 timeout 100 kubectl -n rook-ceph delete pvc "${crashed_pvc_name}" || kubectl -n rook-ceph delete pvc "${crashed_pvc_name}" --force --grace-period=0 restart_operator="true" fi done if [[ $restart_operator == "true" ]]; then kubectl -n rook-ceph rollout restart deployment/rook-ceph-operator fi return 0 } # Execute the cleanup function cleanup_crashing_osd
After fixing the crashing OSD, verify if PGs are recovering or not by running the following command:
