- Overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Applying a patch
- Installation best practices
- Encrypting the SQL Server
- Performing database maintenance
- Performing yearly certificate maintenance
- Setting up directory roles and permissions
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining
- Task Mining troubleshooting
- Exploring Logs
Automation Suite on Linux Installation Guide
We recommend rotating certificates before their expiration date. Make sure to schedule a downtime period to address potential issues. To be informed in a timely manner of the certificate expiration dates, configure alerts for your cluster. Doing so prevents service disruptions. For more details, see Alert runbooks.
We highly recommend performing the following yearly maintenance tasks:
Renew the SSL certificate. For details, see Managing server certificates.
Renew the identity certificate. For details, see Managing identity token-signing certificates .
Renew the internal Kubernetes certificate. For details, see Managing RKE2 certificates.
Clean up logs manually. For details, see How to clean up logs.
