Automation Suite on Linux Installation Guide
Last updated Jan 8, 2025
Step 3: Configuring High Availability Add-on
Automation Suite supports hosting High Availability Add-on either within the same cluster or externally. However, installing High Availability Add-on externally is mandatory for the Active-Active configuration of Automation Suite.
For details on how to configure High Availability Add-on on an external cluster, see Installing High Availability Add-on.
