Automation Suite on Linux Installation Guide
Last updated Jan 22, 2025
Optional: Enabling resilience to zonal failures in a multi-node HA-ready production cluster
To enable resilience to zonal failures in a multi-node cluster, take the following steps:
  1. Make sure nodes are spread evenly across three availability zones. For a bare-metal server or VM provided by any vendor except for AWS, Azure, or GCP, zone metadata has to be provided via the configuration file at /etc/default/k8s-node-labels on every machine in following format.
    NODE_REGION_LABEL=<REGION_NAME>
    NODE_ZONE_LABEL=<ZONE_NAME>
    cat > /etc/default/k8s-node-labels <<EOF
    EXTRA_K8S_NODE_LABELS="topology.kubernetes.io/region=$NODE_REGION_LABEL,topology.kubernetes.io/zone=${NODE_ZONE_LABEL}"
    EOFNODE_REGION_LABEL=<REGION_NAME>
    EOF
  2. Update the cluster_config.json file during the advanced configuration step.
To update the cluster_config.json using the interactive installation wizard, exit at advanced configuration step and add the following to the configuration file using vim or your favorite editor:
"zone_resilience": true"zone_resilience": true
Mandatory parameters
zone_resilience
Use true or false to enable or disable resilience to zonal failure.
Important:
If you enable resilience to zonal failure, passing the --zone and --region arguments is:
  • recommended if you provision your machines on AWS, Azure, or GCP, and metadata services are enabled as the installer populates the zone and region details.
  • mandatory if you provision your machines on AWS, Azure, or GCP, and metadata services are disabled, or if you opt for a different cloud provider.
