Guidelines on backing up and restoring an Active/Passive or Active/Active deployment
Back up and restore an active-passive or active-active Automation Suite deployment following the cluster backup and restore process.
Note:
For detailed instructions on how to back up and restore Automation Suite, refer to Backing up and restoring the cluster.
Backing up the cluster​
  • You must back up only the primary cluster and external storage (SQL and Objectstore).
  • Backing up the secondary cluster is optional. If you do not back it up, you can use the primary cluster to set up the secondary cluster.
Restoring the primary cluster​
  • If the primary cluster goes down, you must use the backup to restore it.
  • If configuration changes were made on the secondary cluster while the primary cluster was down, follow these steps to ensure the restored primary reflects the latest configuration:
    • Merge configurations from the primary and secondary clusters to create an updated cluster_config.json that includes all changes made on the secondary after the primary went down.
    • Apply any required updates to parameters that are specific to the primary cluster.
    • Restore the primary cluster using the merged cluster_config.json file.
Restoring the secondary cluster​
  • If the secondary cluster's backup is unavailable, you can restore it from the primary cluster by taking the following steps:
    1. Generate the cluster_config.json from the primary cluster.
    2. Update the cluster_config.json with the specific values of the secondary cluster, including turning off the products that are not supported on the secondary cluster. For details, refer to Updating the configuration file.
    3. Install the secondary cluster.
  • If the backup for the secondary cluster is available, you can restore the secondary cluster from the backup.
Connect
Stay updated
