- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Last updated Nov 13, 2025
If you experience issues specific to Kubernetes running on the cluster, you can directly uninstall the rke2 cluster.
Depending on your installation profile, run one of the following commands:
1.1. In an online setup, run the following script with elevated privileges, i.e.sudo, on each node of the cluster. This will uninstall the nodes.function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null rm -rfv /etc/sysconfig/rke2-server > /dev/null rm -rfv /etc/sysconfig/rke2-agent > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete."function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null rm -rfv /etc/sysconfig/rke2-server > /dev/null rm -rfv /etc/sysconfig/rke2-agent > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete."1.2 In an offline setup, run the following script with elevated privileges, i.e.sudo, on each node of the cluster. This will uninstall the nodes.function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/local/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/local/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/local/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/local/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null rm -rfv /etc/sysconfig/rke2-server > /dev/null rm -rfv /etc/sysconfig/rke2-agent > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete."function remove_rke2_entry_from_exclude() { local current_exclude_list new_exclude_list YUM_CONF_FILE=$1 if [[ ! -s "${YUM_CONF_FILE}" ]]; then # File is empty return fi current_exclude_list=$(grep 'exclude=' "${YUM_CONF_FILE}" | tail -1) if echo "$current_exclude_list" | grep -q 'rke2-*'; then if [[ -w ${YUM_CONF_FILE} ]]; then new_exclude_list=$(printf '%s\n' "${current_exclude_list//rke2-* /}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-*,/}") new_exclude_list=$(printf '%s\n' "${new_exclude_list//rke2-\*/}") sed -i "/exclude=.*rke2-\*/d" "${YUM_CONF_FILE}" echo "${new_exclude_list}" >> "${YUM_CONF_FILE}" else error "${YUM_CONF_FILE} file is readonly and contains rke2-* under package exclusion. Please remove the entry for AS to work." fi fi } function enable_rke2_package_upgrade() { remove_rke2_entry_from_exclude /etc/dnf/dnf.conf remove_rke2_entry_from_exclude /etc/yum.conf } enable_rke2_package_upgrade service_exists() { local n=$1 if [[ $(systemctl list-units --all -t service --full --no-legend "$n.service" | cut -f1 -d' ') == $n.service ]]; then return 0 else return 1 fi } if service_exists rke2-server; then systemctl stop rke2-server systemctl disable rke2-server fi if service_exists rke2-agent; then systemctl stop rke2-agent systemctl disable rke2-agent fi if [ -e /usr/local/bin/rke2-killall.sh ] then echo "Running rke2-killall.sh" /usr/local/bin/rke2-killall.sh > /dev/null else echo "File not found: rke2-killall.sh" fi if [ -e /usr/local/bin/rke2-uninstall.sh ] then echo "Running rke2-uninstall.sh" /usr/local/bin/rke2-uninstall.sh > /dev/null else echo "File not found: rke2-uninstall.sh" fi crontab -l > backupcron sed -i '/backupjob/d' backupcron > /dev/null crontab backupcron > /dev/null rm -rf backupcron > /dev/null rm -rfv /usr/bin/backupjob > /dev/null rm -rfv /etc/rancher/ > /dev/null rm -rfv /var/lib/rook/ > /dev/null rm -rfv /var/lib/longhorn/ > /dev/null rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null umount -l -f /var/lib/rancher/rke2/server/db > /dev/null 2>&1 || true rm -rfv /var/lib/rancher/* > /dev/null umount -l -f /var/lib/rancher rm -rfv /var/lib/rancher/* > /dev/null while ! rm -rfv /var/lib/kubelet/* > /dev/null; do findmnt --list --submounts -n -o TARGET --target /var/lib/kubelet | grep '/var/lib/kubelet/plugins' | xargs -r umount -f -l sleep 5 done umount -l -f /var/lib/kubelet rm -rfv /var/lib/kubelet/* > /dev/null rm -rfv /datadisk/* > /dev/null umount -l -f /datadisk rm -rfv /datadisk/* > /dev/null rm -rfv ~/.uipath/* > /dev/null rm -rfv /etc/sysconfig/rke2-server > /dev/null rm -rfv /etc/sysconfig/rke2-agent > /dev/null mount /var/lib/rancher mkdir -p /var/lib/rancher/rke2/server/db/ && mount -a rm -rfv /var/lib/rancher/rke2/server/db/* > /dev/null echo "Uninstall RKE complete." - Clean up the OSD disk:
for osddisk in $(find /dev/uipath/ceph -maxdepth 1 -mindepth 1 -type l); do devName=$(basename "${osddisk}") devPath="/dev/${devName}" sgdisk --zap-all "${devPath}" dd if=/dev/zero of="${devPath}" bs=1M count=100 oflag=direct,dsync blkdiscard "${devPath}" done ls /dev/mapper/ceph-* | xargs -I% -- dmsetup remove % rm -rf /dev/ceph-* rm -rf /etc/udev/rules.d/99-ceph-raw-osd.rulesfor osddisk in $(find /dev/uipath/ceph -maxdepth 1 -mindepth 1 -type l); do devName=$(basename "${osddisk}") devPath="/dev/${devName}" sgdisk --zap-all "${devPath}" dd if=/dev/zero of="${devPath}" bs=1M count=100 oflag=direct,dsync blkdiscard "${devPath}" done ls /dev/mapper/ceph-* | xargs -I% -- dmsetup remove % rm -rf /dev/ceph-* rm -rf /etc/udev/rules.d/99-ceph-raw-osd.rulesImportant: For Rook-Ceph versions ≥ 1.16, the OSD cleanup procedure is changed. For details, refer to the Rook official documentation.3. Reboot the node after uninstall.Important: When uninstalling one of the nodes from the cluster, you must run the following command:kubectl delete node <node_name>. This removes the node from the cluster.
