- Overview
- Requirements
- Deployment templates
- Installation packages download links
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
Package |
Purpose |
uipathctl |
dumodernexperience.tar.gz |
UiPath.OrganizationMigrationApp |
hydrate-registry.sh |
as-fs.tar.gz |
rke2-killall.sh |
-O parameter.
as-installer.zip is an installation package that contains the main installation and supporting scripts. The package also contains the uipathctl tool.
uipathctl is only compatible with the x86 architecture.
You cannot run uipathctl on machines based on the ARM architecture,
such as Macs with Apple Silicon (M series) CPUs.
as-installer.zip. If you opt for the online installation profile, as-installer.zip is automatically downloaded by the interactive installation wizard.
as-installer.zip file is required during installation, upgrade, cluster restore in the event of disaster, and while adding new node to existing
cluster.
2024.10.7
https://download.uipath.com/automation-suite/2024.10.7/installer-2024.10.7.zip
Linux:
To downloadas-installer.zipon a Linux machine, run the following command from the terminal:wget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.7/installer-2024.10.7.zipwget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.7/installer-2024.10.7.zip -
Windows:
To downloadas-installer.zipon a Windows machine, access this link and rename the file toas-installer.zip.
2024.10.6
https://download.uipath.com/automation-suite/2024.10.6/installer-2024.10.6.zip
Linux:
To downloadas-installer.zipon a Linux machine, run the following command from the terminal:wget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.6/installer-2024.10.6.zipwget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.6/installer-2024.10.6.zip -
Windows:
2024.10.5
https://download.uipath.com/automation-suite/2024.10.5/installer-2024.10.5.zip
Linux:
To downloadas-installer.zipon a Linux machine, run the following command from the terminal:wget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.5/installer-2024.10.5.zipwget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.5/installer-2024.10.5.zip -
Windows:
2024.10.4
https://download.uipath.com/automation-suite/2024.10.4/installer-2024.10.4.zip
Linux:
To downloadas-installer.zipon a Linux machine, run the following command from the terminal:wget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.4/installer-2024.10.4.zipwget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.4/installer-2024.10.4.zip -
Windows:
2024.10.3
https://download.uipath.com/automation-suite/2024.10.3/installer-2024.10.3.zip
Linux:
To downloadas-installer.zipon a Linux machine, run the following command from the terminal:wget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.3/installer-2024.10.3.zipwget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.3/installer-2024.10.3.zip -
Windows:
2024.10.2
https://download.uipath.com/automation-suite/2024.10.2/installer-2024.10.2.zip
Linux:
To downloadas-installer.zipon a Linux machine, run the following command from the terminal:wget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.2/installer-2024.10.2.zipwget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.2/installer-2024.10.2.zip -
Windows:
2024.10.1
https://download.uipath.com/automation-suite/2024.10.1/installer-2024.10.1.zip
Linux:
To downloadas-installer.zipon a Linux machine, run the following command from the terminal:wget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.1/installer-2024.10.1.zipwget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.1/installer-2024.10.1.zip -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/installer-2024.10.0.zip
Linux:
To downloadas-installer.zipon a Linux machine, run the following command from the terminal:wget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.0/installer-2024.10.0.zipwget -O as-installer.zip https://download.uipath.com/automation-suite/2024.10.0/installer-2024.10.0.zip -
Windows:
uipathctl is a UiPath® command-line tool that allows you to run
commands against Automation Suite. You can use uipathctl to check
prerequisites in your environment, install Automation Suite, configure and manage it
from a single unified CLI.
2024.10.7
uipathctl for Automation Suite 2024.10.7, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathctl-2024.10.7-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathctl-2024.10.7-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathctl-2024.10.7-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathctl-2024.10.7-windows-amd64.tar.gz - MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathctl-2024.10.7-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathctl-2024.10.7-darwin-amd64.tar.gz
2024.10.6
uipathctl for Automation Suite 2024.10.6, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathctl-2024.10.6-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathctl-2024.10.6-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathctl-2024.10.6-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathctl-2024.10.6-windows-amd64.tar.gz - MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathctl-2024.10.6-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathctl-2024.10.6-darwin-amd64.tar.gz
2024.10.5
uipathctl for Automation Suite 2024.10.5, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-windows-amd64.tar.gz - MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathctl-2024.10.5-darwin-amd64.tar.gz
2024.10.4
uipathctl for Automation Suite 2024.10.4, run one of the following commands, depending on your OS:
- Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-linux-amd64.tar.gz - Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-windows-amd64.tar.gz - MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathctl-2024.10.4-darwin-amd64.tar.gz
2024.10.3
uipathctl for Automation Suite 2024.10.3, run one of the
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathctl-2024.10.3-darwin-amd64.tar.gz
2024.10.2
uipathctl for Automation Suite 2024.10.2, run one of the following commands, depending on your OS:
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathctl-2024.10.2-darwin-amd64.tar.gz
2024.10.1
uipathctl for Automation Suite 2024.10.1, run one of the
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathctl-2024.10.1-darwin-amd64.tar.gz
2024.10.0
uipathctl for Automation Suite 2024.10.0, run one of the
Linux:
wget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-linux-amd64.tar.gzwget -O ~/uipathctl-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-linux-amd64.tar.gz -
Windows:
wget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-windows-amd64.tar.gzwget -O ~/uipathctl-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-windows-amd64.tar.gz -
MacOS:
wget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-darwin-amd64.tar.gzwget -O ~/uipathctl-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathctl-2024.10.0-darwin-amd64.tar.gz
as.tar.gz contains the container images and deployment manifests of UiPath® Shared Capabilities and UiPath® Product. The bundle is
approximately 30 GB in size.
as.tar.gz is ideal for users with strong network connections who wish to download the complete file in one go.
as.tar.gz. If you choose the online installation profile, Kubernetes will pull all the container images and deployment manifests directly
from the container registry hosted in UiPath® servers.
as.tar.gz is required during installation and upgrade only on server node when using internal Docker registry.
2024.10.7
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7.tar.gz
For the checksum file, access this link.
Linux:
To downloadas.tar.gzon a Linux machine, run the following command from the terminal:wget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7.tar.gzwget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7.tar.gz -
Windows:
2024.10.6
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6.tar.gz
Linux:
To downloadas.tar.gzon a Linux machine, run the following command from the terminal:wget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6.tar.gzwget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6.tar.gz -
Windows:
2024.10.5
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5.tar.gz
Linux:
To downloadas.tar.gzon a Linux machine, run the following command from the terminal:wget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5.tar.gzwget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5.tar.gz -
Windows:
2024.10.4
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4.tar.gz
Linux:
To downloadas.tar.gzon a Linux machine, run the following command from the terminal:wget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4.tar.gzwget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4.tar.gz -
Windows:
2024.10.3
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3.tar.gz
Linux:
To downloadas.tar.gzon a Linux machine, run the following command from the terminal:wget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3.tar.gzwget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3.tar.gz -
Windows:
2024.10.2
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2.tar.gz
Linux:
To downloadas.tar.gzon a Linux machine, run the following command from the terminal:wget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2.tar.gzwget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2.tar.gz -
Windows:
2024.10.1
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1.tar.gz
Linux:
To downloadas.tar.gzon a Linux machine, run the following command from the terminal:wget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1.tar.gzwget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1.tar.gz -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/as-2024.10.0.tar.gz
Linux:
To downloadas.tar.gzon a Linux machine, run the following command from the terminal:wget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.0/as-2024.10.0.tar.gzwget -O as.tar.gz https://download.uipath.com/automation-suite/2024.10.0/as-2024.10.0.tar.gz -
Windows:
as.tar.gz is designed for users with restricted networks, or those who may encounter challenges when downloading larger files.
2024.10.7
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-001
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-002
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-003
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-004
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-005
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-006
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-007
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-008
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-009
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-010
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-011
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-012
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-013
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-014
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-015
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-016
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-017
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-018
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-019
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-020
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-021
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-022
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-023
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-024
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-025
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-026
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-027
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-028
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-029
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-030
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-031
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-032
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-033
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-034
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-035
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-036
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-037
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-038
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-039
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-040
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-041
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-042
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-043
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-044
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-045
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-046
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-047
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-048
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-049
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-050
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-051
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-052
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-053
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-054
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-055
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-056
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-057
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-058
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-059
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-060
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-061
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-062
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-063
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-064
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-065
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-066
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-067
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-068
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-069
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-070
https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-071
Linux:
To download each split file on a Linux machine, you can use thewgetcommand. The command to download the first part is provided here:wget https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-001wget https://download.uipath.com/automation-suite/2024.10.7/as-2024.10.7-part-001Repeat this process for each subsequent part by incrementing the part number in the file name.
After downloading all parts, run the following command to concatenate the parts into a singleas.tar.gzfile:cat as-2024.10.7-part-* > as.tar.gzcat as-2024.10.7-part-* > as.tar.gz -
Windows:
Download each part of the split file individually, by selecting the corresponding download links previously provided. Each link represents a part of the fullas.tar.gzfile.After downloading all parts, run the following command via Command Prompt to concatenate the parts into a singleas.tar.gzfile:copy /b as-2024.10.7-part-* as.tar.gzcopy /b as-2024.10.7-part-* as.tar.gz
2024.10.6
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-001
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-002
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-003
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-004
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-005
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-006
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-007
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-008
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-009
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-010
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-011
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-012
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-013
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-014
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-015
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-016
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-017
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-018
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-019
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-020
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-021
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-022
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-023
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-024
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-025
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-026
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-027
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-028
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-029
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-030
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-031
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-032
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-033
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-034
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-035
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-036
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-037
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-038
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-039
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-040
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-041
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-042
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-043
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-044
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-045
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-046
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-047
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-048
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-049
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-050
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-051
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-052
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-053
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-054
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-055
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-056
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-057
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-058
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-059
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-060
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-061
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-062
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-063
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-064
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-065
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-066
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-067
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-068
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-069
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-070
https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-071
Linux:
To download each split file on a Linux machine, you can use thewgetcommand. The command to download the first part is provided here:wget https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-001wget https://download.uipath.com/automation-suite/2024.10.6/as-2024.10.6-part-001Repeat this process for each subsequent part by incrementing the part number in the file name.
After downloading all parts, run the following command to concatenate the parts into a singleas.tar.gzfile:cat as-2024.10.6-part-* > as.tar.gzcat as-2024.10.6-part-* > as.tar.gz -
Windows:
Download each part of the split file individually, by selecting the corresponding download links previously provided. Each link represents a part of the fullas.tar.gzfile.After downloading all parts, run the following command via Command Prompt to concatenate the parts into a singleas.tar.gzfile:copy /b as-2024.10.6-part-* as.tar.gzcopy /b as-2024.10.6-part-* as.tar.gz
2024.10.5
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-001
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-002
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-003
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-004
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-005
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-006
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-007
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-008
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-009
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-010
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-011
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-012
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-013
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-014
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-015
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-016
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-017
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-018
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-019
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-020
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-021
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-022
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-023
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-024
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-025
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-026
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-027
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-028
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-029
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-030
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-031
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-032
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-033
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-034
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-035
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-036
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-037
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-038
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-039
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-040
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-041
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-042
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-043
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-044
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-045
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-046
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-047
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-048
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-049
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-050
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-051
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-052
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-053
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-054
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-055
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-056
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-057
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-058
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-059
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-060
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-061
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-062
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-063
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-064
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-065
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-066
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-067
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-068
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-069
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-070
https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-071
Linux:
To download each split file on a Linux machine, you can use thewgetcommand. The command to download the first part is provided here:wget https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-001wget https://download.uipath.com/automation-suite/2024.10.5/as-2024.10.5-part-001Repeat this process for each subsequent part by incrementing the part number in the file name.
After downloading all parts, run the following command to concatenate the parts into a singleas.tar.gzfile:cat as-2024.10.5-part-* > as.tar.gzcat as-2024.10.5-part-* > as.tar.gz -
Windows:
Download each part of the split file individually, by selecting the corresponding download links previously provided. Each link represents a part of the fullas.tar.gzfile.After downloading all parts, run the following command via Command Prompt to concatenate the parts into a singleas.tar.gzfile:copy /b as-2024.10.5-part-* as.tar.gzcopy /b as-2024.10.5-part-* as.tar.gz
2024.10.4
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-001
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-002
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-003
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-004
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-005
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-006
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-007
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-008
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-009
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-010
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-011
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-012
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-013
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-014
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-015
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-016
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-017
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-018
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-019
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-020
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-021
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-022
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-023
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-024
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-025
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-026
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-027
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-028
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-029
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-030
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-031
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-032
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-033
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-034
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-035
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-036
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-037
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-038
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-039
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-040
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-041
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-042
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-043
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-044
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-045
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-046
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-047
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-048
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-049
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-050
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-051
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-052
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-053
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-054
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-055
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-056
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-057
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-058
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-059
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-060
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-061
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-062
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-063
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-064
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-065
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-066
https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-067
Linux:
To download each split file on a Linux machine, you can use thewgetcommand. The command to download the first part is provided here:wget https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-001wget https://download.uipath.com/automation-suite/2024.10.4/as-2024.10.4-part-001Repeat this process for each subsequent part by incrementing the part number in the file name.
After downloading all parts, run the following command to concatenate the parts into a singleas.tar.gzfile:cat as-2024.10.4-part-* > as.tar.gzcat as-2024.10.4-part-* > as.tar.gz -
Windows:
Download each part of the split file individually, by selecting the corresponding download links previously provided. Each link represents a part of the fullas.tar.gzfile.After downloading all parts, run the following command via Command Prompt to concatenate the parts into a singleas.tar.gzfile:copy /b as-2024.10.4-part-* as.tar.gzcopy /b as-2024.10.4-part-* as.tar.gz
2024.10.3
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-001
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-002
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-003
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-004
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-005
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-006
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-007
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-008
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-009
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-010
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-011
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-012
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-013
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-014
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-015
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-016
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-017
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-018
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-019
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-020
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-021
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-022
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-023
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-024
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-025
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-026
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-027
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-028
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-029
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-030
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-031
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-032
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-033
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-034
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-035
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-036
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-037
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-038
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-039
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-040
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-041
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-042
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-043
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-044
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-045
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-046
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-047
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-048
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-049
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-050
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-051
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-052
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-053
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-054
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-055
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-056
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-057
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-058
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-059
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-060
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-061
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-062
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-063
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-064
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-065
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-066
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-067
https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-068
Linux:
To download each split file on a Linux machine, you can use thewgetcommand. The command to download the first part is provided here:wget https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-001wget https://download.uipath.com/automation-suite/2024.10.3/as-2024.10.3-part-001Repeat this process for each subsequent part by incrementing the part number in the file name.
After downloading all parts, run the following command to concatenate the parts into a singleas.tar.gzfile:cat as-2024.10.3-part-* > as.tar.gzcat as-2024.10.3-part-* > as.tar.gz -
Windows:
Download each part of the split file individually, by selecting the corresponding download links previously provided. Each link represents a part of the fullAfter downloading all parts, run the following command via Command Prompt to concatenate the parts into a singleas.tar.gzfile.as.tar.gzfile:copy /b as-2024.10.3-part-* as.tar.gzcopy /b as-2024.10.3-part-* as.tar.gz
2024.10.2
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-001
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-002
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-003
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-004
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-005
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-006
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-007
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-008
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-009
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-010
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-011
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-012
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-013
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-014
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-015
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-016
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-017
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-018
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-019
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-020
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-021
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-022
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-023
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-024
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-025
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-026
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-027
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-028
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-029
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-030
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-031
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-032
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-033
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-034
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-035
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-036
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-037
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-038
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-039
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-040
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-041
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-042
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-043
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-044
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-045
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-046
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-047
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-048
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-049
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-050
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-051
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-052
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-053
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-054
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-055
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-056
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-057
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-058
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-059
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-060
https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-061
Linux:
To download each split file on a Linux machine, you can use thewgetcommand. The command to download the first part is provided here:wget https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-001wget https://download.uipath.com/automation-suite/2024.10.2/as-2024.10.2-part-001Repeat this process for each subsequent part by incrementing the part number in the file name.
After downloading all parts, run the following command to concatenate the parts into a singleas.tar.gzfile:cat as-2024.10.2-part-* > as.tar.gzcat as-2024.10.2-part-* > as.tar.gz -
Windows:
Download each part of the split file individually, by selecting the corresponding download links previously provided. Each link represents a part of the fullAfter downloading all parts, run the following command via Command Prompt to concatenate the parts into a singleas.tar.gzfile.as.tar.gzfile:copy /b as-2024.10.2-part-* as.tar.gzcopy /b as-2024.10.2-part-* as.tar.gz
2024.10.1
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-001
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-002
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-003
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-004
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-005
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-006
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-007
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-008
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-009
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-010
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-011
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-012
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-013
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-014
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-015
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-016
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-017
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-018
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-019
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-020
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-021
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-022
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-023
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-024
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-025
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-026
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-027
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-028
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-029
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-030
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-031
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-032
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-033
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-034
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-035
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-036
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-037
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-038
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-039
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-040
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-041
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-042
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-043
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-044
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-045
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-046
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-047
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-048
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-049
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-050
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-051
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-052
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-053
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-054
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-055
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-056
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-057
https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-058
Linux:
To download each split file on a Linux machine, you can use thewgetcommand. The command to download the first part is provided here:wget https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-001wget https://download.uipath.com/automation-suite/2024.10.1/as-2024.10.1-part-001Repeat this process for each subsequent part by incrementing the part number in the file name.
After downloading all parts, run the following command to concatenate the parts into a singleas.tar.gzfile:cat as-2024.10.1-part-* > as.tar.gzcat as-2024.10.1-part-* > as.tar.gz -
Windows:
Download each part of the split file individually, by selecting the corresponding download links previously provided. Each link represents a part of the fullAfter downloading all parts, run the following command via Command Prompt to concatenate the parts into a singleas.tar.gzfile.as.tar.gzfile:copy /b as-2024.10.1-part-* as.tar.gzcopy /b as-2024.10.1-part-* as.tar.gz
du-ondemand.tar.gz contains base images to install Document Understanding packages.
du-ondemand.tar.gz. If you choose the online installation profile, Automation Suite pulls all the Document Understanding base images directly
du-ondemand.tar.gz is required only when Document Understanding is installed.
For download instructions, see ML Packages Offline Installation.
du-ondemand.tar.gz.
dumodernexperience.tar.gz contains the Document Understanding modern projects bundle.
dumodernexperience.tar.gz. If you choose the online installation profile, Automation Suite pulls all the Document Understanding base images directly
dumodernexperience.tar.gz is required only when Document Understanding modern projects is installed.
cv-ondemand.tar.gz contains Computer Vision models and packages.
cv-ondemand.tar.gz. If you choose the online installation profile, Automation Suite will pull all the Computer Vision models directly from the
cv-ondemand.tar.gz is required only when you want to use Computer Vision models.
2024.10.7
https://download.uipath.com/automation-suite/2024.10.7/cv2410-2024.10.7.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.7/cv2410-2024.10.7.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.7/cv2410-2024.10.7.tar.gz -
Windows:
To downloadcv-ondemand.tar.gzon a Windows machine, access this link and rename the file tocv-ondemand.tar.gz.
2024.10.6
https://download.uipath.com/automation-suite/2024.10.6/cv2410-2024.10.6.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.6/cv2410-2024.10.6.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.6/cv2410-2024.10.6.tar.gz -
Windows:
2024.10.5
https://download.uipath.com/automation-suite/2024.10.5/cv2410-2024.10.5.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.5/cv2410-2024.10.5.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.5/cv2410-2024.10.5.tar.gz -
Windows:
2024.10.4
https://download.uipath.com/automation-suite/2024.10.4/cv2410-2024.10.4.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.4/cv2410-2024.10.4.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.4/cv2410-2024.10.4.tar.gz -
Windows:
2024.10.3
https://download.uipath.com/automation-suite/2024.10.3/cv2410-2024.10.3.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.3/cv2410-2024.10.3.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.3/cv2410-2024.10.3.tar.gz -
Windows:
2024.10.2
https://download.uipath.com/automation-suite/2024.10.2/cv2410-2024.10.2.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.2/cv2410-2024.10.2.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.2/cv2410-2024.10.2.tar.gz -
Windows:
2024.10.1
https://download.uipath.com/automation-suite/2024.10.1/cv2410-2024.10.1.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.1/cv2410-2024.10.1.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2024.10.1/cv2410-2024.10.1.tar.gz -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/cv2410-2024.10.0.tar.gz
Linux:
To downloadcv-ondemand.tar.gzon a Linux machine, run the following command from the terminal:wget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.0/cv2510-2.2510.0.tar.gzwget -O cv-ondemand.tar.gz https://download.uipath.com/automation-suite/2.2510.0/cv2510-2.2510.0.tar.gz -
Windows:
The UiPath.OrganizationMigrationApp tool helps you perform operations such as move the Identity data of all tenants from standalone to Automation Suite and merge organizations.
To check which UiPath.OrganizationMigrationApp version is compatible with your environment, see Compatibility matrix.
2024.10.5
Linux
To download UiPath.OrganizationMigrationApp on a Linux machine, run the following command on the terminal:
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.5-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.5-linux.zip -
Windows
To download UiPath.OrganizationMigrationApp on a Windows machine, access this link.
2024.10.4
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.4-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.4-linux.zip -
Windows
2024.10.3
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.3-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.3-linux.zip -
Windows
2024.10.2
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.2-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.2-linux.zip -
Windows
2024.10.1
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.1-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.1-linux.zip -
Windows
2024.10.0
Linux
wget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.0-linux.zipwget https://download.uipath.com/MSIToAutomationSuiteTenantMigrator-2024.10.0-linux.zip -
Windows
uipathtools is a CLI tool that contains a subset of uipathctl
capabilities specific to health commands. The tool is backward compatible and works with
any supported Automation Suite version. We recommend using uipathtools
as the first step if you face any issue.
2024.10.7
uipathtools, run one of the following commands, depending on your OS:
- Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathtools-2024.10.7-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathtools-2024.10.7-linux-amd64.tar.gz - Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathtools-2024.10.7-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathtools-2024.10.7-windows-amd64.tar.gz - MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathtools-2024.10.7-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.7/uipathtools-2024.10.7-darwin-amd64.tar.gz
2024.10.6
- Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathtools-2024.10.6-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathtools-2024.10.6-linux-amd64.tar.gz - Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathtools-2024.10.6-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathtools-2024.10.6-windows-amd64.tar.gz - MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathtools-2024.10.6-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.6/uipathtools-2024.10.6-darwin-amd64.tar.gz
2024.10.5
- Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-linux-amd64.tar.gz - Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-windows-amd64.tar.gz - MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.5/uipathtools-2024.10.5-darwin-amd64.tar.gz
2024.10.4
- Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-linux-amd64.tar.gz - Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-windows-amd64.tar.gz - MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.4/uipathtools-2024.10.4-darwin-amd64.tar.gz
2024.10.3
your OS:
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.3/uipathtools-2024.10.3-darwin-amd64.tar.gz
2024.10.2
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.2/uipathtools-2024.10.2-darwin-amd64.tar.gz
2024.10.1
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.1/uipathtools-2024.10.1-darwin-amd64.tar.gz
2024.10.0
Linux
wget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-linux-amd64.tar.gzwget -O uipathtools-linux-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-linux-amd64.tar.gz -
Windows
wget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-windows-amd64.tar.gzwget -O uipathtools-windows-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-windows-amd64.tar.gz -
MacOS
wget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-darwin-amd64.tar.gzwget -O uipathtools-darwin-amd64.tar.gz https://download.uipath.com/uipathctl/2024.10.0/uipathtools-2024.10.0-darwin-amd64.tar.gz
objectstore-migration.sh helps you migrate Objectstore data in online and offline installations.
https://download.uipath.com/automation-suite/objectstore-migration.sh
Linux:
To downloadobjectstore-migration.shon a Linux machine, run the following command from the terminal:wget -O objectstore-migration.sh https://download.uipath.com/automation-suite/objectstore-migration.shwget -O objectstore-migration.sh https://download.uipath.com/automation-suite/objectstore-migration.sh -
Windows:
To downloadobjectstore-migration.shon a Windows machine, access this link.
automation-suite-util.tar.gz helps you migrate Objectstore data in offline installations.
https://download.uipath.com/automation-suite/automation-suite-util.tar.gz
Linux:
To downloadautomation-suite-util.tar.gzon a Linux machine, run the following command from the terminal:wget -O automation-suite-util.tar.gz https://download.uipath.com/automation-suite/automation-suite-util.tar.gzwget -O automation-suite-util.tar.gz https://download.uipath.com/automation-suite/automation-suite-util.tar.gz -
Windows:
To downloadautomation-suite-util.tar.gzon a Windows machine, access this link.
mirror-registry.sh is required to configure an external Docker registry.
2024.10.7
https://download.uipath.com/automation-suite/2024.10.7/mirror-registry.sh
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command from the terminal:wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.7/mirror-registry.shwget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.7/mirror-registry.sh -
Windows:
To downloadmirror-registry.shon a Windows machine, access this link.
2024.10.6
https://download.uipath.com/automation-suite/2024.10.6/mirror-registry.sh
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command from the terminal:wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.6/mirror-registry.shwget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.6/mirror-registry.sh -
Windows:
2024.10.5
https://download.uipath.com/automation-suite/2024.10.5/mirror-registry.sh
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command from the terminal:wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.5/mirror-registry.shwget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.5/mirror-registry.sh -
Windows:
2024.10.4
https://download.uipath.com/automation-suite/2024.10.4/mirror-registry.sh
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command from the terminal:wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.4/mirror-registry.shwget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.4/mirror-registry.sh -
Windows:
2024.10.3
https://download.uipath.com/automation-suite/2024.10.3/mirror-registry.sh
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command from the terminal:wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3/mirror-registry.shwget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.3/mirror-registry.sh -
Windows:
2024.10.2
https://download.uipath.com/automation-suite/2024.10.2/mirror-registry.sh
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command from the terminal:wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2/mirror-registry.shwget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.2/mirror-registry.sh -
Windows:
2024.10.1
https://download.uipath.com/automation-suite/2024.10.1/mirror-registry.sh
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command from the terminal:wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.1/mirror-registry.shwget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.1/mirror-registry.sh -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.sh
Linux:
To downloadmirror-registry.shon a Linux machine, run the following command from the terminal:wget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.shwget -O mirror-registry.sh https://download.uipath.com/automation-suite/2024.10.0/mirror-registry.sh -
Windows:
hydrate-registry.sh is required for configuring your external OCI-compliant registry for offline installations in the Automation Suite.
2024.10.7
https://download.uipath.com/automation-suite/2024.10.7/hydrate-registry.sh
Linux:
To downloadon a Linux machine, run the following command from the terminal:hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.7/hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.7/hydrate-registry.sh -
Windows:
To downloadhydrate-registry.shon a Windows machine, access this link.
2024.10.6
https://download.uipath.com/automation-suite/2024.10.6/hydrate-registry.sh
Linux:
To downloadon a Linux machine, run the following command from the terminal:hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.6/hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.6/hydrate-registry.sh -
Windows:
2024.10.5
https://download.uipath.com/automation-suite/2024.10.5/hydrate-registry.sh
Linux:
To downloadon a Linux machine, run the following command from the terminal:hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.5/hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.5/hydrate-registry.sh -
Windows:
2024.10.4
https://download.uipath.com/automation-suite/2024.10.4/hydrate-registry.sh
Linux:
To downloadon a Linux machine, run the following command from the terminal:hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.4/hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.4/hydrate-registry.sh -
Windows:
2024.10.3
https://download.uipath.com/automation-suite/2024.10.3/hydrate-registry.sh
Linux:
To downloadon a Linux machine, run the following command from the terminal:hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3/hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.3/hydrate-registry.sh -
Windows:
2024.10.2
https://download.uipath.com/automation-suite/2024.10.2/hydrate-registry.sh
Linux:
To downloadon a Linux machine, run the following command from the terminal:hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2/hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.2/hydrate-registry.sh -
Windows:
2024.10.1
https://download.uipath.com/automation-suite/2024.10.1/hydrate-registry.sh
Linux:
To downloadon a Linux machine, run the following command from the terminal:hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.1/hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.1/hydrate-registry.sh -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/hydrate-registry.sh
Linux:
To downloadon a Linux machine, run the following command from the terminal:hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.0/hydrate-registry.shwget -O hydrate-registry.sh https://download.uipath.com/automation-suite/2024.10.0/hydrate-registry.sh -
Windows:
as-images.txt contains the name and version of the container images that must be
pulled and uploaded into the external Docker registry.
2024.10.7
https://download.uipath.com/automation-suite/2024.10.7/embedded-images.txt
Linux:
To downloadembedded-images.txton a Linux machine, run the following command from the terminal:wget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.7/embedded-images.txtwget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.7/embedded-images.txt -
Windows:
To downloadembedded-images.txton a Windows machine, access this link and rename the file toas-images.txt.
2024.10.6
https://download.uipath.com/automation-suite/2024.10.6/embedded-images.txt
Linux:
To downloadembedded-images.txton a Linux machine, run the following command from the terminal:wget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.6/embedded-images.txtwget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.6/embedded-images.txt -
Windows:
2024.10.5
https://download.uipath.com/automation-suite/2024.10.5/embedded-images.txt
Linux:
To downloadembedded-images.txton a Linux machine, run the following command from the terminal:wget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.5/embedded-images.txtwget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.5/embedded-images.txt -
Windows:
2024.10.4
https://download.uipath.com/automation-suite/2024.10.4/embedded-images.txt
Linux:
To downloadembedded-images.txton a Linux machine, run the following command from the terminal:wget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.4/embedded-images.txtwget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.4/embedded-images.txt -
Windows:
2024.10.3
https://download.uipath.com/automation-suite/2024.10.3/embedded-images.txt
To download
Linux:
embedded-images.txton a Linux machine, run the following command from the terminal:wget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.3/embedded-images.txtwget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.3/embedded-images.txt -
To download
Windows:
2024.10.2
https://download.uipath.com/automation-suite/2024.10.2/embedded-images.txt
To download
Linux:
embedded-images.txton a Linux machine, run the following command from the terminal:wget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.2/embedded-images.txtwget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.2/embedded-images.txt -
To download
Windows:
2024.10.1
https://download.uipath.com/automation-suite/2024.10.1/embedded-images.txt
To download
Linux:
embedded-images.txton a Linux machine, run the following command from the terminal:wget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.1/embedded-images.txtwget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.1/embedded-images.txt -
To download
Windows:
embedded-images.txton a Windows machine, access this linkand rename the file toas-images.txt.
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/embedded-images.txt
To download
Linux:
embedded-images.txton a Linux machine, run the following command from the terminal:wget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.0/embedded-images.txtwget -O as-images.txt https://download.uipath.com/automation-suite/2024.10.0/embedded-images.txt -
To download
Windows:
as-helm-charts.txt contain the details for the UiPath® application helm chart
that must be pulled and uploaded to an external Docker registry hosted on your
environment.
2024.10.7
https://download.uipath.com/automation-suite/2024.10.7/embedded-helm-charts.txt
Linux:
To downloadembedded-helm-charts.txton a Linux machine, run the following command from the terminal:wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.7/embedded-helm-charts.txtwget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.7/embedded-helm-charts.txt -
Windows:
To downloadembedded-helm-charts.txton a Windows machine, access this link and rename the file toas-helm-charts.txt.
2024.10.6
https://download.uipath.com/automation-suite/2024.10.6/embedded-helm-charts.txt
Linux:
To downloadembedded-helm-charts.txton a Linux machine, run the following command from the terminal:wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.6/embedded-helm-charts.txtwget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.6/embedded-helm-charts.txt -
Windows:
2024.10.5
https://download.uipath.com/automation-suite/2024.10.5/embedded-helm-charts.txt
Linux:
To downloadembedded-helm-charts.txton a Linux machine, run the following command from the terminal:wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.5/embedded-helm-charts.txtwget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.5/embedded-helm-charts.txt -
Windows:
2024.10.4
https://download.uipath.com/automation-suite/2024.10.4/embedded-helm-charts.txt
Linux:
To downloadembedded-helm-charts.txton a Linux machine, run the following command from the terminal:wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.4/embedded-helm-charts.txtwget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.4/embedded-helm-charts.txt -
Windows:
2024.10.3
https://download.uipath.com/automation-suite/2024.10.3/embedded-helm-charts.txt
To download
Linux:
embedded-helm-charts.txton a Linux machine, run the following command from the terminal:wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3/embedded-helm-charts.txtwget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.3/embedded-helm-charts.txt -
To download
Windows:
2024.10.2
https://download.uipath.com/automation-suite/2024.10.2/embedded-helm-charts.txt
To download
Linux:
embedded-helm-charts.txton a Linux machine, run the following command from the terminal:wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2/embedded-helm-charts.txtwget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.2/embedded-helm-charts.txt -
To download
Windows:
2024.10.1
https://download.uipath.com/automation-suite/2024.10.1/embedded-helm-charts.txt
To download
Linux:
embedded-helm-charts.txton a Linux machine, run the following command from the terminal:wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.1/embedded-helm-charts.txtwget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.1/embedded-helm-charts.txt -
To download
Windows:
embedded-helm-charts.txton a Windows machine, access this linkand rename the file toas-helm-charts.txt.
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txt
To download
Linux:
embedded-helm-charts.txton a Linux machine, run the following command from the terminal:wget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txtwget -O as-helm-charts.txt https://download.uipath.com/automation-suite/2024.10.0/embedded-helm-charts.txt -
To download
Windows:
as-fs.tar.gz contains the Helm charts and images to deploy the shared components and the service components in offline mode.
2024.10.7
https://download.uipath.com/automation-suite/2024.10.7/as-fs-2024.10.7.tar.gz
For the checksum file, access this link.
Linux:
To downloadas-fs.tar.gzon a Linux machine, run the following command from the terminal:wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.7/as-fs-2024.10.7.tar.gzwget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.7/as-fs-2024.10.7.tar.gz -
Windows:
To downloadas-fs.tar.gzon a Windows machine, access this link.
2024.10.6
https://download.uipath.com/automation-suite/2024.10.6/as-fs-2024.10.6.tar.gz
Linux:
To downloadas-fs.tar.gzon a Linux machine, run the following command from the terminal:wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.6/as-fs-2024.10.6.tar.gzwget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.6/as-fs-2024.10.6.tar.gz -
Windows:
2024.10.5
https://download.uipath.com/automation-suite/2024.10.5/as-fs-2024.10.5.tar.gz
Linux:
To downloadas-fs.tar.gzon a Linux machine, run the following command from the terminal:wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.5/as-fs-2024.10.5.tar.gzwget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.5/as-fs-2024.10.5.tar.gz -
Windows:
2024.10.4
https://download.uipath.com/automation-suite/2024.10.4/as-fs-2024.10.4.tar.gz
Linux:
To downloadas-fs.tar.gzon a Linux machine, run the following command from the terminal:wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.4/as-fs-2024.10.4.tar.gzwget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.4/as-fs-2024.10.4.tar.gz -
Windows:
2024.10.3
https://download.uipath.com/automation-suite/2024.10.3/as-fs-2024.10.3.tar.gz
Linux:
To downloadas-fs.tar.gzon a Linux machine, run the following command from the terminal:wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.3/as-fs-2024.10.3.tar.gzwget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.3/as-fs-2024.10.3.tar.gz -
Windows:
2024.10.2
https://download.uipath.com/automation-suite/2024.10.2/as-fs-2024.10.2.tar.gz
Linux:
To downloadas-fs.tar.gzon a Linux machine, run the following command from the terminal:wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.2/as-fs-2024.10.2.tar.gzwget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.2/as-fs-2024.10.2.tar.gz -
Windows:
2024.10.1
https://download.uipath.com/automation-suite/2024.10.1/as-fs-2024.10.1.tar.gz
Linux:
To downloadas-fs.tar.gzon a Linux machine, run the following command from the terminal:wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.1/as-fs-2024.10.1.tar.gzwget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.1/as-fs-2024.10.1.tar.gz -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/as-fs-2024.10.0.tar.gz
Linux:
To downloadas-fs.tar.gzon a Linux machine, run the following command from the terminal:wget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.0/as-fs-2024.10.0.tar.gzwget -O as-fs.tar.gz https://download.uipath.com/automation-suite/2024.10.0/as-fs-2024.10.0.tar.gz -
Windows:
Needed to perform prerequisite checks and installation steps.
2024.10.7
https://download.uipath.com/automation-suite/2024.10.7/versions.json
Linux:
To downloadversions.jsonon a Linux machine, run the following command from the terminal:wget -O versions.json https://download.uipath.com/automation-suite/2024.10.7/versions.jsonwget -O versions.json https://download.uipath.com/automation-suite/2024.10.7/versions.json -
Windows:
To downloadversions.jsonon a Windows machine, access this link.
2024.10.6
https://download.uipath.com/automation-suite/2024.10.6/versions.json
Linux:
To downloadversions.jsonon a Linux machine, run the following command from the terminal:wget -O versions.json https://download.uipath.com/automation-suite/2024.10.6/versions.jsonwget -O versions.json https://download.uipath.com/automation-suite/2024.10.6/versions.json -
Windows:
2024.10.5
https://download.uipath.com/automation-suite/2024.10.5/versions.json
Linux:
To downloadversions.jsonon a Linux machine, run the following command from the terminal:wget -O versions.json https://download.uipath.com/automation-suite/2024.10.5/versions.jsonwget -O versions.json https://download.uipath.com/automation-suite/2024.10.5/versions.json -
Windows:
2024.10.4
https://download.uipath.com/automation-suite/2024.10.4/versions.json
Linux:
To downloadversions.jsonon a Linux machine, run the following command from the terminal:wget -O versions.json https://download.uipath.com/automation-suite/2024.10.4/versions.jsonwget -O versions.json https://download.uipath.com/automation-suite/2024.10.4/versions.json -
Windows:
2024.10.3
https://download.uipath.com/automation-suite/2024.10.3/versions.json
Linux:
To downloadversions.jsonon a Linux machine, run the following command from the terminal:wget -O versions.json https://download.uipath.com/automation-suite/2024.10.3/versions.jsonwget -O versions.json https://download.uipath.com/automation-suite/2024.10.3/versions.json -
Windows:
2024.10.2
https://download.uipath.com/automation-suite/2024.10.2/versions.json
Linux:
To downloadversions.jsonon a Linux machine, run the following command from the terminal:wget -O versions.json https://download.uipath.com/automation-suite/2024.10.2/versions.jsonwget -O versions.json https://download.uipath.com/automation-suite/2024.10.2/versions.json -
Windows:
2024.10.1
https://download.uipath.com/automation-suite/2024.10.1/versions.json
Linux:
To downloadversions.jsonon a Linux machine, run the following command from the terminal:wget -O versions.json https://download.uipath.com/automation-suite/2024.10.1/versions.jsonwget -O versions.json https://download.uipath.com/automation-suite/2024.10.1/versions.json -
Windows:
2024.10.0
https://download.uipath.com/automation-suite/2024.10.0/versions.json
Linux:
To downloadversions.jsonon a Linux machine, run the following command from the terminal:wget -O versions.json https://download.uipath.com/automation-suite/2024.10.0/versions.jsonwget -O versions.json https://download.uipath.com/automation-suite/2024.10.0/versions.json -
Windows:
rke2-killall.sh on a Linux machine, run the following command from the terminal:
wget -O /usr/bin/rke2-killall.sh https://raw.githubusercontent.com/UiPath/automation-suite-support-tools/refs/heads/main/Scripts/GeneralTools/rke2-killall.sh
chmod +x /usr/bin/rke2-killall.shwget -O /usr/bin/rke2-killall.sh https://raw.githubusercontent.com/UiPath/automation-suite-support-tools/refs/heads/main/Scripts/GeneralTools/rke2-killall.sh
chmod +x /usr/bin/rke2-killall.sh/usr/bin/rke2-killall.sh.
- as-installer.zip
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- uipathctl
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- Full as.tar.gz
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- Split as.tar.gz
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- du-ondemand.tar.gz
- dumodernexperience.tar.gz
- cv-ondemand.tar.gz
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- UiPath.OrganizationMigrationApp
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- uipathtools
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- objectstore-migration.sh
- automation-suite-util.tar.gz
- mirror-registry.sh
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- hydrate-registry.sh
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- as-images.txt
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- as-helm-charts.txt
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- as-fs.tar.gz
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- versions.json
- 2024.10.7
- 2024.10.6
- 2024.10.5
- 2024.10.4
- 2024.10.3
- 2024.10.2
- 2024.10.1
- 2024.10.0
- rke2-killall.sh
