- Overview
- Glossary
- Automation Suite products
- Cross-product dependencies
- Cross-deployment feature comparison
- Security and compliance
- Certificates overview
- Requirements
- Recommended: Deployment templates
- Step 1: Configuring the OCI-compliant registry for offline installations
- Step 2: Configuring the external objectstore
- Step 3: Configuring High Availability Add-on
- Step 4: Configuring Microsoft SQL Server
- Step 5: Configuring the load balancer
- Step 6: Configuring the DNS
- Step 7: Configuring the disks
- Step 8: Configuring kernel and OS level settings
- Step 9: Configuring the node ports
- Step 10: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Applying a patch
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- ArgoCD login failed
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- After Disaster Recovery Dapr is not working properly for Process Mining
- Task Mining troubleshooting
- Exploring Logs
Automation Suite on Linux Installation Guide
Last updated Jan 22, 2025
This table compares the feature availability across the following deployment methods:
- the AWS, Azure, and GCP cloud templates, which provision the infrastructure and install Automation Suite in a short amount of time. Templates are the recommended option.
the manual installation provisioning method, which requires more technical expertise and is considerably more time-consuming.
Feature
AWS template
Azure template
GCP template
Manual installation provisioning
Deploy to existing Virtual Network
Single-node evaluation vs. lite mode vs. multi-node HA-ready production
Can set number of instances
Air-gapped
A-la-carte product selection
Custom domain (cloud-provided DNS service or not)
Custom certificates
Deploy to existing SQL Server
Hardware requirements validation
Template uses cloud-native availability zones
N/A
Proxy configuration
Optional bastion host
N/A
Instance refresh
N/A
Backup and restore cluster
N/A
Remove nodes
N/A
