- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
This page provides instructions on the operations you can perform after deploying Automation Suite to AWS.
- Under CloudFormation > Stacks, you can find all of your deployments.
- Select the stack you deployed, a status of CREATE_COMPLETE indicates the deployment has completed successfully.
The installation process generates self-signed certificates on your behalf. By default, these certificates are compliant with FIPS 140-2 and expire after 1825 days, but you can choose any of the following expiry periods at the time of deployment: 90, 365, 730, 1825, or 3650 days.
You must replace the self-signed certificates with certificates signed by a trusted Certificate Authority (CA) as soon as the installation completes. If you do not update the certificates, the installation will stop working after the certificate expiry date.
If you installed Automation Suite on a FIPS 140-2-enabled host and want to update the certificates, make sure they are compatible with FIPS 140-2.
For instructions, see Managing certificates.
After completing an Automation Suite installation using the AWS deployment template, you can enable FIPS 140-2 on your machines. For instructions, see Security and compliance.
/root/installer directory.
The Cluster Administration portal is a centralized location where you can find all the resources required to complete an Automation Suite installation and perform common post-installation operations. For details, see Getting started with the Cluster Administration portal.
To access the Cluster Administration portal, take the following step:
https://${CONFIG_CLUSTER_FQDN}/uipath-management.The general-use Automation Suite user interface serves as a portal for both organization administrators and organization users. It is a common organization-level resource from where everyone can access all Automation Suite areas: administration pages, platform-level pages, service-specific pages, and user-specific pages.
To access Automation Suite, take the following steps:
- Go to the following URL:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Default organization.
- The username is orgadmin.
- Retrieve the password by selecting the secrets link provided in the output table for AutomationSuiteSecret. Go to Retrieve Secret Value for the credentials.
The host portal is where system administrators configure the Automation Suite instance. The settings configured from this portal are inherited by all your organizations, and some can be overwritten at the organization level.
To access host administration, take the following steps:
https://{CONFIG_CLUSTER_FQDN}. - Switch to the Host organization.
- The username is admin.
- Retrieve the password by selecting the secrets link provided in the output table for HostAdministrationSecret. Go to Retrieve Secret Value for the credentials.
You can use the ArgoCD console to manage installed products.
To access ArgoCD, take the following steps:
https://alm.${CONFIG_CLUSTER_FQDN}. - The username is admin if you want to use the ArgoCD admin account, or argocdro if you want to use the ArgoCD read-only account.
- Retrieve the password by selecting to the secrets link provided in the output table for ArgoCdSecret. Go to Retrieve Secret Value for the credentials.
To access the monitoring tools for the first time, log in as an admin with the following default credentials:
- Username: admin
- Password: to retrieve the
password , run the following
command:
kubectl get secrets/dex-static-credential -n uipath -o "jsonpath={.data['password']}" | base64 --decodekubectl get secrets/dex-static-credential -n uipath -o "jsonpath={.data['password']}" | base64 --decode
To update the default password used for Dex authentication while accessing the monitoring tools, take the following steps.
Run the following command by replacing
newpasswordwith your new password:password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]"password="newpassword" password=$(echo -n $password | base64) kubectl patch secret dex-static-credential -n uipath --type='json' -p="[{'op': 'replace', 'path': '/data/password', 'value': '$password'}]" -
Run the following command to update the password:
./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json./bin/uipathctl manifest apply /opt/UiPathAutomationSuite/cluster_config.json --versions versions/helm-charts.json
The templates provide automations for cluster operations leveraging Systems Manager documents.
Using Systems Manager documents
To use the Systems Manager documents, take the following steps:
UpdateAMIDocument
The SSM document creates a new Launch Template version for the server and agent Automatic Scaling Groups with an updated AMI ID.
Usage
The document exposes 2 parameters:
ImageName(e.g.:RHEL-8.6*_HVM-20*) – If theImageNameparameter is provided and AMI that matches theImageNamewill be set on the Automatic Scaling Groups;AmiId(e.g.:ami-032e5b6af8a711f30) – If provided, theAmiIdtakes precedence overImageNameand is set on the Automatic Scaling Groups.
ImageName stored in Parameter Store is used as default value.
RegisterAiCenter
The SSM document registers AI Center to the external Orchestrator provided at deployment time.
Usage
IdentityToken, which is an installation access token generated by the external Identity service. Since the token has a short availability
(approximately 1-2 hours), we recommend generating it just before running the SSM document. For instructions, see Installation key.
OnDemandBackup
Creates a snapshot of the Automation Suite cluster. Does not perform a backup on the SQL server.
Usage
This SSM document does not require any parameters.
Execution logs
captureOnDemandBackup step.
GetAllBackups
Lists all snapshot available in the Automation Suite cluster.
Usage
Execution logs
getSnapshotList step.
OnDemandRestore
Restores the Automation Suite cluster to a snapshot.
Usage
SnapshotName parameter. To get a snapshot, use the GetAllBackups document and check the logs.
Execution logs
To view the execution logs, take the following steps:
After performing an Automation Suite cluster upgrade, AWS template deployments require some changes to ensure a new node joins the cluster correctly. To automate the changes, we recommend using the dedicated script. For instructions, see the AWS deployment template docs.
- Validating the installation
- Updating certificates
- Enabling FIPS 140-2
- Accessing the installer package
- Accessing the deployment outputs
- Accessing the Cluster Administration portal
- Accessing the Automation Suite portal
- Accessing host administration
- Accessing ArgoCD
- Accessing the monitoring tools
- Accessing cluster VMs
- Performing cluster operations
- Using Systems Manager documents
- UpdateAMIDocument
- RegisterAiCenter
- OnDemandBackup
- GetAllBackups
- OnDemandRestore
- Completing an upgrade
