- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- Moving Ceph out of read-only mode
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
Steps to update external Redis credentials by regenerating cluster_config.json and applying changes in Automation Suite.
Generating the cluster_config.json file
Generate the latest cluster_config.json file using the following command:
./bin/uipathctl manifest get-revision >> ./cluster_config.json
Note:
For details on how to configure the cluster_config.json parameters, refer to Advanced installation experience.
Providing the new credentials for Redis
Update the following section in the cluster_config.json file with the new password and/or hostname:
"fabric": {
"redis": {
"hostname": "new_hostname",
"password": "new_password",
"port": 6380,
"tls": true
"fabric": {
"redis": {
"port": 6380,
"tls": true
Running the installer
To run the installer, use the following command:
cd /opt/UiPathAutomationSuite/{version}/installer
./bin/uipathctl manifest apply ./cluster_config.json --versions versions/helm-charts.json
