- Overview
- Requirements
- Deployment templates
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Step 13: Generating cluster_config.json
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- Monitoring configuration
- Running uipathctl
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating from in-cluster registry to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Step 9: Migrating standalone Test Manager
- Step 10: Deleting the default tenant
- Upgrading Automation Suite
- Executing the upgrade
- Configuring appSettings
- Configuring NLog
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to reduce permissions for an NFS backup directory
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- How to deploy Insights in a FIPS-enabled cluster
- How to migrate to cgroup v2
- How to push a local Docker image to the in-cluster registry
- How to exclude buckets from backup
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- In-cluster registry seeding fails due to insufficient memory
- Prerequisite checks fail when Document Understanding modern projects is enabled and AI Center is disabled
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- Upgrade failure during posthook import
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Accessing FQDN returns RBAC access denied error
- Redis probe failure
- RKE2 server fails to start
- ArgoCD repo-server pod in CrashLoopBackOff
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- Backup operations fail with PartiallyFailed status
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
To configure an external OCI-compliant registry, update the following parameters in the cluster_config.json file:
| Keys | Value |
registries.docker.url | Default value: registry.uipath.com The URL or FQDN of the registry to be used by Automation Suite to host the container images. |
registries.docker.username registries.docker.password | Authentication information to be used for pulling the Docker images from the registry. If one of the values is found in the input file, you must provide both of them when configuring the external registry. |
registries.docker.pull_secret_value | The registry pull secret. This field is optional. |
registries.helm.url | Default value: registry.uipath.com The URL or FQDN of the registry to be used by Automation Suite to host the Helm chart of the service. |
registries.helm.username registries.helm.password | Authentication information to be used for pulling Helm charts from the registry. If one of the values is found in the input file, you must provide both of them when configuring the external registry. |
registries.trust.enabled | Enable or disable Connaisseur. Possible values: true and false. |
registries.trust.public_key | The public key in Base64-encoded format used to validate image signatures. By default, it is set to the public part of the private key used to sign images in Azure Credential Registry. |
registries.trust.detection_mode | If enabled, Connaisseur only warns when it cannot validate images. It does not block the create/update request. Possible value: true and false. |
registry_ca_cert | The location of the CA file corresponding to the certificate configured for the registry. If the registry is signed by a private certificate authority hosted on your premises, you must provide it to establish the trust. |
Note:
You can use different methods to generate the encoded version of the pull_secret_value, including the one using Docker. For details, refer to How to generate the encoded pull_secret_value for external registries.
The following configuration sample shows a typical OCI-compliant registry setup:
"registries": {
"docker": {
"url": "registry.domain.io",
"username": "username",
"password": "password",
"pull_secret_value": "pull-secret-value"
"helm": {
"trust": {
"enabled": true,
"public_key": "LS0tLS1CRUdJTiBQVUJMSUMgS0VZLS0tLS0KTUZrd0V3WUhLb1pJemowQ0FRWUlLb1pJemowREFRY0RRZ0FFNE4vSzNzK2VXUTJHU3NnTTJNcUhsdEplVHlqRQp1UC9sd0dNTnNNUjhUZTI2Ui9TTlVqSVpIdnJKcEx3YmpDc0ZlZUI3L0xZaFFsQzlRdUU1WFhITDZ3PT0KLS0tLS1FTkQgUFVCTElDIEtFWS0tLS0tCg==",
"detection_mode": false
"registry_ca_cert": "/etc/pki/ca-trust/extracted/ca-bundle.trust.crt"
"registries": {
"docker": {
"helm": {
"trust": {
"enabled": true,
For registries such as Harbor, which require using a project, you must append the project name to the registry URL. The requirement applies to the registries.docker.url and registries.helm.url parameters in the cluster_config.json file, as shown in the following example:
"registries": {
"docker": {
"url": "registry.domain.io/myproject",
"helm": {
"trust": {
"enabled": true,
"registries": {
"docker": {
"helm": {
"trust": {
"enabled": true,
