- Overview
- Requirements
- Deployment templates
- Q&A: Deployment templates
- Release notes
- Azure deployment architecture
- Step 1: Preparing the Azure deployment
- Step 2: Deploying Automation Suite to Azure
- Step 3: Post-deployment steps
- Completing an upgrade
- Step 2: Configuring the OCI-compliant registry for offline installations
- Step 3: Configuring the external objectstore
- Step 4: Configuring High Availability Add-on
- Step 5: Configuring SQL databases
- Step 6: Configuring the load balancer
- Step 7: Configuring the DNS
- Step 8: Configuring the disks
- Step 9: Configuring kernel and OS level settings
- Step 10: Configuring the node ports
- Step 11: Applying miscellaneous settings
- Cluster_config.json Sample
- General configuration
- Profile configuration
- Certificate configuration
- Database configuration
- ArgoCD configuration
- Kerberos authentication configuration
- AI Center-specific configuration
- Monitoring configuration
- Cluster administration
- Managing products
- Migrating Redis from in-cluster to external High Availability Add-on
- Migrating to an external OCI-compliant registry
- Scaling a single-node (evaluation) deployment to a multi-node (HA) deployment
- Monitoring and alerting
- Migration and upgrade
- Upgrading Automation Suite
- Executing the upgrade
- Troubleshooting
- How to clear Redis data
- How to enable Istio logging
- How to check the TLS version
- How to schedule Ceph backup and restore data
- How to clean up unused Docker images from registry pods
- Temporary registry installation fails on RHEL 8.9
- Frequent restart issue in uipath namespace deployments during offline installations
- DNS settings not honored by CoreDNS
- Unable to install temporary registry
- Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
- Unable to access Automation Hub following upgrade to Automation Suite 2024.10.0
- RKE2 not getting started due to space issue
- In-place upgrade timeouts
- AI Center provisioning failure after upgrading to 2023.10 or later
- SQL validation fails during upgrade
- Failure to upgrade to Automation Suite 2024.10.1
- Upgrade fails due to Velero migration issue
- Upgrade stuck on rook-ceph application deletion
- ArgoCD login failed
- Robot cannot connect to an Automation Suite Orchestrator instance
- Partial failure to restore backup in Automation Suite 2024.10.0
- Redis probe failure
- RKE2 server fails to start
- Pods stuck in Init:0/X
- Mismatch in reported errors during diagnostic health checks
- No healthy upstream issue
- Log streaming does not work in proxy setups
- Failure to add agent nodes in offline environments
- Node becomes unresponsive (OOM) during large Document Understanding bundle upload
- After Disaster Recovery Dapr is not working properly for Process Mining
- Exploring Logs
- Exploring summarized telemetry
After setting up the Azure environment, navigate to one of the following links to install Automation Suite:
The following table provides an overview of the parameters used in the deployment:
Parameter name |
Description |
The Azure subscription. |
The Azure Resource Group, under the subscription. |
The name of the resource group where the cluster is deployed. |
The default region of the Resource Group. |
A valid Azure Region where the infrastructure is deployed. Make sure that the region has enough cores for the instance types used. You can use the
[resourceGroup().location] if this is the same as the Resource Group’s region.
The version of Automation Suite. Example:
21.10.2 |
Choose whether Automation Suite should be installed after the infrastructure is provisioned. |
By setting the parameter as true, you agree to the applicable license agreement. |
The prefix used for the load balancer subdomain. If you use a custom domain you will only be able to access the cluster through the custom domain, not directly using the load balancer's domain (eg. <prefix>.<region>.cloudapp.azure.com). |
Parameter indicating whether the Virtual Network used for the deployment should be created or if it already exists. |
Resource group where the existing Virtual Network you want to use is deployed. Parameter used only if the
Virtual Network New Or Existing parameter is set to existing.
Name of the existing Virtual Network used for deployment. Parameter used only if the
Name of an existing subnet inside the previously mentioned Virtual Network. The subnet must satisfy these requirements. Parameter used only if the
Deploy a Bastion Host on the Virtual Network. Parameter used only if Virtual Network New Or Existing is set to new. |
Set to
true if you want to use your own custom domain. The needs post-install configuration.
This is the domain you want to use for the cluster. Post-installation, create two CNAME/A records that will point to the public load balancer. See DNS configuration. |
Set to
true if you want to use your own custom certificates for your own domain. Make sure to use this together with the Enable Custom Domain parameter set to true.
This is a
base64 encoded string.
Encode the contents of the
.crt server certificate to a base64 string. The server certificate should have the following properties.
This is a
.key server certificate key, to a base64 string. This is the private key from the Custom Server Certificate parameter.
This is a
Create a
.crt file containing all public certificates (.crt) from all of the CA certificates in the Server Certificate chain (excluding the server certificate).
Create a
base64 string from the contents of this file.
Optional: The link to the Automation Suite installation package. Changing this parameter overwrites the
Automation Suite version parameter and install the version specified in this URL.
Keep set to
None if not used.
This is a valid
json string that will be merged in the cluster_config.json file that is being built by the template. Will overwrite existing settings.
See advanced installation experience for details. |
The number of VMs created to work as the servers for the cluster. Should be an odd number. |
The instance type for the server nodes. Example:
Standard_D16s_v3 |
Server node hostname/computer name prefix. For details on the appended sequence, see Azure documentation. |
Enable to use ultra disks for
etcd (server nodes). Should only be disabled if the region you are deploying to does not have zones support.
The number of VMs created to serve as the agent nodes for the cluster. If 0, an empty agent scale set is still created. |
The instance type for the agent nodes. Example:
Standard_D16s_v3 |
Agent node hostname/computer name prefix. For details on the appended sequence, see Azure documentation. |
The number of VMs with GPU created to be the agents for the cluster. Designed for ML workloads. If 0, no GPU scale set is created. |
The type of instances with GPU to be provisioned and to be the agents for the cluster. Example:
Standard_NC12s_v2 |
GPU node hostname/computer name prefix. For details on the appended sequence, see Azure documentation. |
Optional: Instance type of the task mining node. This will only be used if you enable the Task Mining service. Example:
Standard_B20ms |
Task Mining node hostname/computer name. |
The number of dedicated Automation Suite Robots nodes. If 0, the scale set is still created. |
The instance type for the dedicated Automation Suite Robots nodes. Example:
Standard_D16s_v3 |
Automation Suite Robots node hostname/computer name prefix. For details on the appended sequence, see Azure documentation. |
Parameter indicating whether the SQL Server used for the deployment should be created or it already exists. For SQL server requirements, see our documentation . |
FQDN or IP associated with the SQL Server. This is only used if the
SQLNewOrExisting parameter is set to existing.
SQL Server user login. If the
SQL new or existing parameter is set to existing, this is the user for the existing SQL server. Otherwise, this username will be set on the SQL server created. For details
on the required permissions, see our documentation for permissions.
SQL Server user password. If the
SQL new or existing parameter is set to existing, this is the user password for the existing SQL server. Otherwise, this password is set on the created SQL server.
SQL Server port. If the
SQLNewOrExisting parameter is set to existing, this port is used.
FQDN or IP associated with the Warehouse SQL Server. This is only used if the
SQLNewOrExisting parameter is set to existing, and you want to install Process Mining.
Warehouse SQL Server user login. This is only used if you want to install Process Mining. If the
SQLNewOrExisting parameter is set to existing, this is the user for the existing SQL server. Otherwise this username is set on the created SQL Server. For details on permissions,
see Configuring Microsoft SQL server.
Warehouse SQL Server user password. This is only used if you want to install Process Mining. If the
SQLNewOrExisting parameter is set to existing, this is the user password for the existing SQL server. Otherwise this password is set on the created SQL server.
Warehouse SQL Server port. This is only used if you want to install Process Mining. If the
The admin username to be set on all nodes. This is also used as the host tenant admin. |
The password for the node admin user. This is also used as the host tenant admin password. |
The admin username to be used in the virtual machine instances. |
The admin password to be used in the virtual machine instances. |
Set to
true if you want to deploy the external NFS file share. Also, the backup will be enabled at cluster level if the Run Automation Suite Install parameter is set to true.
Choose if the specific service is installed in the cluster. |
externalRegistryFQDN | The external registry FQDN. |
externalRegistryUsername | The external registry username. |
externalRegistryPassword | The external registry password. |
Flag which determines whether AI Center connects to an external Orchestrator. Only works if
AiCenterInstallFlag is set to 'true'. You need to specify how AI Center connects to the Orchestrator in the following parameters.
The URL for Orchestrator to which AI Center connects. Fill this in only if you want to install AI Center and connect it to an external Orchestrator and Identity Service. |
The URL for the Identity Service to which AI Center connects. Fill this in only if you want to install AI Center and connect it to an external Orchestrator and Identity Service. |
The Certificate in Base64 for the Orchestrator to which AI Center connects. Fill this in only if you want to install AI Center and connect it to an external Orchestrator and Identity Service. |
The Certificate in Base64 for the Identity Service to which AI Center connects. Fill this in only if you want to install AI Center and connect it to an external Orchestrator and Identity Service. |
Optional: Tags per resource. Can be empty or have the following format: { "Microsoft.Web/serverFarms": { "<TagName>": "<TagValue>" }, "Microsoft.Insights/components": { "<TagName>": "<TagValue>"
Set to
true to enable FIPS 140-2 for the Automation suite installation.
Important:
Insights does not work with FIPS 140-2 enabled. If you want to enable FIPS-2, make sure to disable Insights before starting the installation. |
